Netduino Firmware v4.2.0 RC5 (Netduino + Netduino Plus) - Page 3 - Beta Firmware and Drivers - Netduino Forums
138 replies to this topic
#41 PhilG
PhilG
  • 42 posts
  • LocationMaine
Posted 14 May 2012 - 11:24 PM
Chris, I just re-flashed to 4.1.0.6 and it debugs OK with a test program compiled for 4.1. I have been using a different Plus board running 4.2 RC1 which works with my code (compiled for 4.2). I re-flashed to 4.2 RC1 and my code runs and debugs as it does on the other RC1 board. I will stick with this until there is a working 4.2 release.
#42 Laurelle
Laurelle
  • 16 posts
  • LocationFrance
Posted 20 May 2012 - 06:23 PM
I've upgrated to this RC and I ve lots of problems with Sockets. I've implemented a web server and I get random erros on sockets. The web server is running ok for couple of minutes and then raise Socket erros. I can'ts really test with previous versions but I can reinstall a previous version is needed. so it looks like there is a problem there. Looking at previous posts, it weems I'm not the only one with this problem. I can send the code if needed.
Doing dev is like doing sport. It's healthy :-)
#43 Laurelle
Laurelle
  • 16 posts
  • LocationFrance
Posted 21 May 2012 - 06:21 AM
OK, so I'm replying to myself... Yes, there are problems which seems to be random. And I found a solution in this thread http://forums.netdui...h__1#entry28943
Basically, using a try and catch and ignoring the error solve the problem.
#44 rcomeau
rcomeau
  • 3 posts
Posted 23 May 2012 - 04:23 PM
Ok as one new to the netduino plus, where do I find EXACT instructions on how to use SAM-BA to install the 4.2 bootloader? Then what files have to be MFDeployed?
#45 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 May 2012 - 05:29 PM
You can find all instructions at: http://wiki.netduino...ep-by-step.ashx and http://wiki.netduino...ep-by-step.ashx Good luck!
#46 Arbiter
Arbiter
  • 132 posts
  • LocationBrisbane, Australia
Posted 28 May 2012 - 12:57 PM
Since updating one of my N+ units to 4.2rc5 and retargeting a project to framework 4.2 the compiler reports
'AnalogInput' is an ambiguous reference between 'Microsoft.SPOT.Hardware.AnalogInput' and 'SecretLabs.NETMF.Hardware.AnalogInput'
The SecretLabs assembly does not define TristatePort, the MS one does, but the constructor my code uses exists only in the SecretLabs implementation of AnalogInput. Fully qualifying AnalogInput allowed my code to compile, but that makes me wonder if I'm not using some obsolete deprecated constructor or something like that. Can anyone advise me?
#47 Cabadam
Cabadam
  • 90 posts
Posted 28 May 2012 - 05:29 PM
Chris, I've attached a small sample project which I have replicated the problem on.
--snipped--
I just wanted to follow up on this to see if you have had any success in recreating this, or if there is anything else I can try to reproduce.
Thanks!
#48 Arbiter
Arbiter
  • 132 posts
Posted 28 May 2012 - 10:33 PM
Dns.GetHostEntry(name) works perfectly if I call it early but when it's called a couple of minutes later it hangs. Anyone seen similar behaviour? It seems to take about 70 sec to fail.
This is the code and trace.
using System.Net;
using System.Net.Sockets;
namespace ReproDnsBug
    static Timer __timer;
      DnsTest(null);
      __timer = new Timer(DnsTest, null, 10000, 10000);
    static void DnsTest(object state)
      try
        Debug.Print(Dns.GetHostEntry("whitehouse.podzone.net").AddressList[0].ToString());
      catch (Exception)
        Debug.Print("Fail");
Found debugger!
Create TS.
 Loading start at 155dd8, end 16ebfc
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0)Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: SecretLabs.NETMF.Hardware (4.2.0.0)
Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.2.0.0)Attaching deployed file.
Assembly: ReproDnsBug (1.0.0.0)Resolving.
Ready.
121.222.61.97
121.222.61.97
121.222.61.97
121.222.61.97
121.222.61.97
121.222.61.97
121.222.61.97
Fail
Fail
Fail
Fail
Fail
Fail
The program '[20] Micro Framework application: Managed' has exited with code 0 (0x0).
#49 tknman0700
tknman0700
  • 26 posts
Posted 29 May 2012 - 08:51 PM
There is a comment here:
Before deploying the attached firmware, you should erase your board completely and flash the v4.2 RC5 bootloader (included in the attached ZIP file).
Can you tell me how I might go about that? It isnt in your details unless I am missing it.
#50 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 29 May 2012 - 08:59 PM
Hopefully these instructions will work for you:
#51 Arbiter
Arbiter
  • 132 posts
Posted 30 May 2012 - 07:29 AM
Has anyone had a chance to confirm the Dns problem I reported?
#52 Chris Walker
Posted 30 May 2012 - 08:09 AM
Hi Arbiter, Is there any chance that you could take a quick WireShark log in both circumstances (both when DNS is working for you and when DNS is not working for you)? Chris
#53 Arbiter
Arbiter
  • 132 posts
Posted 30 May 2012 - 03:17 PM
Please find attached Wireshark capture. I filtered for host 192.168.0.100 which is the address statically configured on the N+
DNS is provided by a Netgear domestic router with the address 192.168.0.1
I ran the test app until it faulted. It was interesting to observe that only one ARP call occurred, right at the start.
#54 Valkyrie-MT
Valkyrie-MT
  • 315 posts
  • LocationIndiana, USA
Posted 31 May 2012 - 02:25 AM
I am not able to reproduce this on 4.2 RC3. It returned the correct IP in excess of 30 times. When I get a moment, I'll look at the wireshark file.
-Valkyrie-MT
P.S. I use 4.2 RC3 because I am still waiting for a firmware build with 1-wire...
#55 Valkyrie-MT
Valkyrie-MT
  • 315 posts
Posted 31 May 2012 - 02:35 AM
That Wireshark file has 4 irrelevant messages in it. I should see the 7 DNS requests and 7 responses before it starts to fail. Then comes the interesting part... Does Netduino continue to send the requests with no response? Does Netduino send a malformed response? Did an IP or MAC address change? That's what we are looking for...
Also, I tried this code with the Emulator and that worked fine as well. You should try it too and see what happens because the TCP/IP stack is different on the Emulator. If it works in the Emulator, it probably vindicates your network and points the finger at Netduino... maybe... :)
-Valkyrie-MT
#56 Arbiter
Arbiter
  • 132 posts
Posted 31 May 2012 - 06:59 AM
-Valkyrie-MT
This could also indicate incompetent use of Wireshark. I downloaded and installed it for the occasion, never having used it before. There was a surprising amount happening on our home network at 1am so after trawling the doco I added filter "host 192.168.0.100" started a capture and ran the app on the N+ but I am hardly expert in the use of it. I didn't have this network issue on this specific harware with 4.1.0.6, but I can tell you that the N+ didn't like my other router one little bit even with 4.1
It crosses my mind that the N+ has never been especially tolerant of busy networks and it is possible that I have actually run afoul of my stepson's enthusiasm for, ahem, torrents. I think that this evening I shall arrange for a quiet network and retry. If you have any instruction for me in the application of Wireshark to this problem, I should be grateful.
#57 Arbiter
Arbiter
  • 132 posts
Posted 31 May 2012 - 08:46 AM
Let's play "Spot the dumbass" !
Which genius didn't bother to check whether any other devices on his network had 192.168.0.100? Hmmmmm, that would be me.
On the bright side, now we all know that when DNS requests work for about 70 sec and then fail, it's probably an address collision.
Having resolved the address collision everything is now hunky dory.
On another note, Chris, you are a marvel, another 8K makes an unbelievable difference to my little logger.
#58 aalmada
aalmada
  • 44 posts
  • LocationPortugal
Posted 04 June 2012 - 03:56 PM
Anxiously awaiting for the final release... <_< Thanks
#59 billy
billy
  • 23 posts
Posted 04 June 2012 - 08:20 PM
Is the source available for RC5? Thanks
#60 Giuliano
Giuliano
  • 361 posts
  • LocationSimi Valley, CA
Posted 06 June 2012 - 04:54 AM
I followed the instructions but I get the following errors:
Posted Image
I already rebooted three times, plug and unplugged the netduino several times as well.
Here is the information about the MFDeploy I am using. I am able to ping the device though:
Posted Image
Posted Image
Posted Image
Please advise.
