Here is my program code:
namespace Photocell
// write your code here
OutputPort led2 = new OutputPort(Pins.GPIO_PIN_D0, false);
AnalogInput analog0 = new AnalogInput(Pins.GPIO_PIN_A0);
//Read value of Analog 0
int light = 0;
light = analog0.Read();
Debug.Print("Value of light is: " + light.ToString());
//Action depending on voltage of Analog0
if (light > 300)
led2.Write(true);
else
led2.Write(false);
Thread.Sleep(500);
I have tried commenting the line with Debug.Print with no change.
Here is the messages in the Output Debug window:
Attaching deployed file.
Assembly: Photocell (1.0.0.0) (240 RAM - 588 ROM - 294 METADATA)
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) (268 RAM - 816 ROM - 423 METADATA)
Resolving.
Total: (10996 RAM - 90336 ROM - 49787 METADATA)
The debugging target runtime is loading the application assemblies and starting execution.
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.1\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'SecretLabs.NETMF.Diagnostics'
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Users\Jackie\documents\visual studio 2010\Projects\Photocell\Photocell\bin\Debug\le\Photocell.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.1\le\SecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded.
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
Value of light is: 601
Done.
Waiting for debug commands...
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
The program '[14] Micro Framework application: Managed' has exited with code 0 (0x0).
Jackie
