Visual Basic vs C Sharp
#1 carb
carb
  • 352 posts
Posted 21 April 2012 - 12:52 AM
I have 2 versions of the same program, one written in Visual Basic the other in C Sharp. Both versions do the same thing, they use a Poteniometer, Button & RGBLed module. Push the button cycles through 7 color then off, turn the pot changes the intensity of the Led.
The problem is when run with Visual Basic I get 4 warning errors (see attached image), when run with C Sharp it runs clean. Other than the warnings everything works the way I want it to.
Is there something missing from the references that would cause me to get the warnings. I am using the provided Netduino Go template.
      ColorValue = CByte(255 * Pot.GetValue) 'Warnings 1 & 3 at start of line
      If (PB.ButtonState Or OPB.Read) Then ' Use either button to change color
        i += 1 'Warnings 2 & 4 at start of line
        If i > 7 Then
          i = 0
        End If
Chuck
Posted 21 April 2012 - 01:14 AM
Hi carb, The warnings are a feature of the Visual Basic compiler, telling you about differences between C# and VB. They're IL warnings. These warnings should only be cosmetic in most cases (unless you're working with edge cases or your counters are depending on an overflow sceanrio). We might be able to pool some ideas together on how to suppress them if they worry you :) Chris
#3 carb
carb
  • 352 posts
Posted 21 April 2012 - 02:25 AM
Hi carb,
No that's all right, I will pretend that they are coming from a wife and ignore them! :lol:
Just mentioned it in case it was an indication of something more serious.
Chuck
