Use MAX521 DAC with i2c
7 replies to this topic
#1 gnomathibus
gnomathibus
  • 13 posts
  • LocationFrance
Posted 16 April 2012 - 02:02 PM
Hello,
I want to use a MAX521 in I2C with my Netduino, I use the class I2CBus found on the forum, but I am having dificulties with the function to write a value to a regitre
here is my code:
using NetduinoPlusTesting;
namespace Maxdac
    public class Maxdacdevice
        private I2CDevice.Configuration _slaveConfig;
        private const int TransactionTimeout = 3000; // ms
        private const byte ClockRateKHz = 100;
        public byte Address { get; private set; }
        public Maxdacdevice(byte address)
            Address = address;
            _slaveConfig = new I2CDevice.Configuration(address, ClockRateKHz);
        public void write()
         //Send command write Full Power DAC0
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { 0x07 , 0x00 }, TransactionTimeout);
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { 0xFF }, TransactionTimeout);
in fact I try to do a translation of an existing library for Arduino, but since I'm a beginner it was not easy for me
The link from the site of the library MAX520 / 1 for Arduino
and the to linkthe documentation of the IC
Sorry for my poor English I use Google to translate if someone could help me it would be super cool!
#2 gbreder
gbreder
  • 53 posts
  • LocationGermany
Posted 16 April 2012 - 06:16 PM
Hi, the first common mistake of I2C devices is to take all eight bits of the address. Please take only the most significant 7 and shift them one place to the right. The datasheet says that the address is someting like: 0, 1, 0, 1, ADR2, ADR1, ADR0, R/W This results in addresses between: 0x28 and 0x2F (these address values are hexadecimal) Is your address in this range? The first write statement writes zero to DAC7. Is this right? What should the second write statement do? Regards Guido
#3 gnomathibus
gnomathibus
  • 13 posts
  • LocationFrance
Posted 16 April 2012 - 07:10 PM
thank you very much for the interest in my problem Guido, effectively addresses are possible for the MAX521 0x28, 0x29, 0x2A, 0x2B
I in my promgram instantiates as:
using System.Net;
using System.Net.Sockets;
using Maxdac;
namespace NetduinoPlusApplication5
            // write your code here
            Maxdacdevice Max = new Maxdacdevice(0x2A);
            Max.write();
                led.Write(true);
                Thread.Sleep(250);
                led.Write(false);
                Thread.Sleep(250);
As I said in my topic I used the existing Arduino library that works fine as an example for me is a 0x07 B00000111 "Bitwise"? , 0x00 DAC0 and 0xFF has a full power
here the example of the library in Arduino Cpp:
maxdac::maxdac(byte address) //address should be 7 bits
  Wire.begin();
  _address = address;
void maxdac::write(int port, int value) //port is 0-7 for MAX521 and 0-3 for MAX520
  Wire.beginTransmission(_address); //tell the device we are ready to begin transmitting
  Wire.send((B00000111 & port)); //use some BitWise "&" to combine the command to write to a port with the port you wish to write to
  Wire.send(value); //send the actual value to the port
  Wire.endTransmission(); //stop communication
thank you again !
#4 gbreder
gbreder
  • 53 posts
  • LocationGermany
Posted 16 April 2012 - 07:34 PM
the Arduino code
would translate to
I2CBus.GetInstance().Write(_slaveConfig, new byte[] { (byte)(0x07 & port) }, TransactionTimeout);
where "port" is 0x00 for DAC0.
Maybe this will work :)
Regard
Guido
#5 gnomathibus
gnomathibus
  • 13 posts
  • LocationFrance
Posted 16 April 2012 - 07:48 PM
I had already tried but unfortunately it does not work, I have the following error message: throw new Exception ("Could not write to device."); :(
#6 gbreder
gbreder
  • 53 posts
  • LocationGermany
Posted 17 April 2012 - 07:27 PM
Hi gnomathibus,
after I read the datasheet of your DAC again I realized I've made a mistake:
The code on the Netduino should be something like this:
var slaveConfig = new I2CDevice.Configuration(0x28, 100);
byte port = 0x00;
var i2CAdapter = I2CAdapter.Instance;
i2CAdapter.WriteBytes(slaveConfig, new byte[] {(byte)(0x07 & port), 0xFF});
The "(0x07 & port)" ensures that only the 3 smallest bits can be set as port. The "(byte)" converts the resulting integer back to one byte and "0xFF" sets the DAC0 to full power.
As far as I understand the datasheet this should work.
Regards
Guido
#7 gnomathibus
gnomathibus
  • 13 posts
  • LocationFrance
Posted 17 April 2012 - 07:59 PM
Thank you very much for your help Guido, but I solved my problem in the afternoon if I had not put pull-up resistor to the SDA and SCL ports on my arduino while I did not need to Max521 one, here is the wiring diagram that works impeccably well now and for me and my code snippet :)
namespace Maxdac
            Address = address;
        public void write(byte port, byte value)
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { (byte)(0x07 & port), value }, TransactionTimeout);
        public void reset()
            I2CBus.GetInstance().Write(_slaveConfig, new byte[] { (byte)(0x10) }, TransactionTimeout);
        public void shutDown(Boolean shutdown)
            if (shutdown == true)
                I2CBus.GetInstance().Write(_slaveConfig, new byte[] { (byte)(0x08), (byte)(0x00) }, TransactionTimeout);
            else
                I2CBus.GetInstance().Write(_slaveConfig, new byte[] { (byte)(0x00), (byte)(0x00) }, TransactionTimeout);
and the progam
using System.Net;
using Maxdac;
            Maxdacdevice Max1 = new Maxdacdevice(0x2A);
            Maxdacdevice Max2 = new Maxdacdevice(0x29);
            Max1.reset();
            Max2.reset();
            Thread.Sleep(500);
            //Set FULLPOWER to MAX521 Adress(0x2A) DAC04
            Max1.write(4,255);
            //Set FULLPOWER to MAX521 Adress(0x29) DAC01
            Max2.write(1, 255);
            Thread.Sleep(5000);
            //resets all registers to off
            Max1.reset();
            Max2.reset();
            Thread.Sleep(5000);
            //shuts down the DAC into power save mode
            Max1.shutDown(true);
            Max2.shutDown(true);
            Thread.Sleep(5000);
            //wakes the DAC. Any write command will also wake the DAC from power save mode
            Max1.shutDown(false);
            Max2.shutDown(false);
            Thread.Sleep(5000);
           //Set HALFPOWER to MAX521 Adress(0x2A) DAC04
            Max1.write(4, 127);
           //Set HALFPOWER to MAX521 Adress(0x2A) DAC01
            Max2.write(1, 127);
            Thread.Sleep(5000);
                led.Write(true);
                Thread.Sleep(250);
                led.Write(false);
                Thread.Sleep(250);
#8 gbreder
gbreder
  • 53 posts
  • LocationGermany
Posted 18 April 2012 - 07:52 AM
Excellent! Thanks for your feedback. Guido
