Gadgeteer Light
Posted 16 April 2012 - 07:59 AM
It supports both the .NET Micro Framework 4.1 as well as 4.2.
I did this because there are a lot of nice modules that could make prototyping a bit faster and with drivers ready for them, it can save quite some time for quick project building.
For this I decided a pin set on th Netduino Classic, which creates up to 3 sockets;
Socket 1 with SUXY support (pins D4, D1, D0, D6, D11, D12, D13)
Socket 2 with AIX support (pins A0, A1, A2, A3, A4, A5)
Socket 3 with PUXY support (pins D7, D3, D2, D8, D5, D9, D10)
This occupies all Netduino pins, but the ones not used aren't locked by the Gadgeteer Light Framework. So if you use an P-module on socket 3, you can still use COM2 on a shield.
To connect a Gadgeteer module to your Netduino, there are a few approaches possible:
- A Netduino Go - IDC Cable Breakout Board
- A Gadgeteer Expansion and Debug Module
I used three of those Netduino Go! breakouts as you can see here:
gadgeteerlight.jpg 253.51KB 124 downloads
Also, in the Gadgeteer Light repository is a shield design which could be of use for this:
gadgeteerlight-shield.png 129.78KB 119 downloads
Downloads can be found at http://gadgeteerlight.codeplex.com/
Posted 17 April 2012 - 05:47 PM
Posted 17 April 2012 - 07:46 PM
That would be really cool. We might be a bit too tight on flash to accomodate the virtual I/O stack but we can do some tests to find out a bit later in the year.That is awesome! Is a Go Light also possible for the Plus?
Posted 19 April 2012 - 06:42 PM
Posted 19 April 2012 - 08:17 PM
Gadgeteer has sockets which can contain specific types of modules. This is classified with letters. S=SPI, U=UART, X=4 GPIOs, Y=7 GPIOs, A=ADC, I=I²C, P=PWMThanks for that. More choice in perpherals is always good.
What does SUXY, AIX and PUXY mean though?
Posted 19 April 2012 - 08:58 PM
Posted 23 April 2012 - 08:23 PM
Posted 23 April 2012 - 08:36 PM
Posted 24 April 2012 - 01:08 AM
Yes, absolutely. Since go!bus is an IO virtualization technology, you can bridge to just about any pin assignment form factor: Arduino Shield, TinkerKit, Gadgeteer, and more are all possible.Would it be possible to create a Gadgeteer base similar to the Shield base? One that would give us access to more Gadgeteer module types? I'm pretty certain that something like this is technically possible, not sure if anyone is motivated enough to build one though.
You could plug in several adapter boards at the same time, of course. As long as you stay within the 500mA (@ 3.3V) current limit of the power supply.
Posted 25 April 2012 - 08:19 PM
