a class like the following will most possibly fit your requirement:
using System.Reflection;
namespace Netduino.Extender.TransferAdapters
/// <summary>
/// Wire-up the I2C device to the Netduino as follows:
/// SDA -> Analog Pin 4;
/// SCL -> Analog Pin 5;
/// GND -> GND.
/// </summary>
public sealed class I2CAdapter
private static readonly Object _I2CLock = new object();
private static readonly I2CAdapter _Instance = new I2CAdapter();
private readonly I2CDevice _I2CDevice;
/// <summary>Creates a new <see cref="I2CAdapter"/> instance </summary>
/// <remarks>
/// At this time the .NET Micro Framework only supports a single I2C bus.
/// Therefore, creating more than one I2CAdapter instance will generate an
/// exception.
/// </remarks>
private I2CAdapter()
//Initialize the I2CDevice with a dummy configuration
_I2CDevice = new I2CDevice(new I2CDevice.Configuration(0, 0));
public static I2CAdapter Instance
get { return _Instance; }
private I2CDevice.I2CWriteTransaction CreateInternalAddressWriteTransaction(byte[] buffer, uint internalAddress,
byte internalAddressSize)
I2CDevice.I2CWriteTransaction writeTransaction = I2CDevice.CreateWriteTransaction(buffer);
ModifyToRepeatedStartTransaction(internalAddress, internalAddressSize, writeTransaction,
typeof (I2CDevice.I2CWriteTransaction));
return writeTransaction;
private I2CDevice.I2CReadTransaction CreateInternalAddressReadTransaction(byte[] buffer, uint internalAddress,
I2CDevice.I2CReadTransaction readTransaction = I2CDevice.CreateReadTransaction(buffer);
ModifyToRepeatedStartTransaction(internalAddress, internalAddressSize, readTransaction,
typeof (I2CDevice.I2CReadTransaction));
return readTransaction;
/// <summary>
/// To use the new I2C InternalAddress feature (repeated start bit) in the v4.1.1 alpha,
/// add the following method to your code...
/// and then call it instead of built-in I2CDevice.CreateWriteTransaction/CreateReadTransaction functions when appropriate.
/// </summary>
/// <param name="internalAddress"></param>
/// <param name="internalAddressSize">The InternalAddressSize parameter defines
/// the # of bytes used to represent the InternalAddress. The InternalAddress is a set of bytes sent to a device before the
/// buffer--often a register # or memory location to write/read. When used in an I2C ReadTransaction, an extra start bit will
/// be sent to the I2C device after the InternalAddress (followed by the traditional buffer read/write).</param>
/// <param name="transaction"></param>
/// <param name="transactionType"></param>
private static void ModifyToRepeatedStartTransaction(uint internalAddress, byte internalAddressSize,
I2CDevice.I2CTransaction transaction, Type transactionType)
FieldInfo fieldInfo = transactionType.GetField("Custom_InternalAddress",
BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(transaction, internalAddress);
fieldInfo = transactionType.GetField("Custom_InternalAddressSize", BindingFlags.NonPublic | BindingFlags.Instance);
fieldInfo.SetValue(transaction, internalAddressSize);
public int WriteInternalAddressBytes(I2CDevice.Configuration i2CConfiguration, byte[] bytesToWrite,
uint internalAddress, byte internalAddressSize)
int bytesTransfered = ExecuteI2CTransactions(i2CConfiguration,
CreateInternalAddressWriteTransaction(bytesToWrite, internalAddress,
internalAddressSize));
// I2CDevice.Execute returns the total number of bytes transfered in BOTH directions for all transactions
if (bytesTransfered < (bytesToWrite.Length))
Debug.Print("WriteInternalAddressBytes: I2C expected + '" + bytesToWrite.Length + "' but could write + '" +
bytesTransfered + "'.");
return bytesTransfered;
public int ReadInternalAddressBytes(I2CDevice.Configuration i2CConfiguration, byte[] bytesToRead, uint internalAddress,
CreateInternalAddressReadTransaction(bytesToRead, internalAddress,
if (bytesTransfered < (bytesToRead.Length))
Debug.Print("ReadInternalAddressBytes: I2C expected + '" + bytesToRead.Length + "' but could read + '" +
public int WriteBytes(I2CDevice.Configuration i2CConfiguration, byte[] bytesToWrite)
int bytesTransfered = ExecuteI2CTransactions(i2CConfiguration, I2CDevice.CreateWriteTransaction(bytesToWrite));
Debug.Print("WriteBytes: I2C expected + '" + bytesToWrite.Length + "' but could write + '" + bytesTransfered + "'.");
public int ReadBytes(I2CDevice.Configuration i2CConfiguration, byte[] bytesToRead)
int bytesTransfered = ExecuteI2CTransactions(i2CConfiguration, I2CDevice.CreateReadTransaction(bytesToRead));
Debug.Print("ReadBytes: I2C expected + '" + bytesToRead.Length + "' but could read + '" + bytesTransfered + "'.");
/// <summary>
/// </summary>
/// <param name="configuration">Netduino needs only the 7 most significant bits for the address e.g. 0x91 >> 1 = 0x48.</param>
/// <returns></returns>
private int ExecuteI2CTransactions(I2CDevice.Configuration configuration, I2CDevice.I2CTransaction transaction)
lock (_I2CLock)
_I2CDevice.Config = configuration;
// Execute the read or write transaction, check if byte was successfully transfered
int bytesTransfered = _I2CDevice.Execute(new[] {transaction}, 100);
This class takes a I2CDevice.Configuration for each read and write and can be used multiple times for diffrent devices. It should be tread-safe. To get an instance of this class please call "I2CAdapter.Instance" (singleton pattern). The Read/WriteInternalAddressBytes methods are used in Firmware 4.1.1 beta 1 and 4.2.0 RCx. They won't work in 4.0. If there are errors in my code or if there are suggestions for improvement please let me know.
Now you should be able to use the one I2C bus of your Netduino with ease for diffrent devices.
Regards
Guido
