Netduino Go Firmware v4.2.0
Posted 12 April 2012 - 05:08 AM
Posted 12 April 2012 - 06:15 AM
Here is the Netduino Go firmware.
Version: 4.2.0 (version 4.2.0.0)
Is this what is already flashed on the boards or did they ship with a beta of somesort?
Posted 12 April 2012 - 06:25 AM
Good question!Is this what is already flashed on the boards or did they ship with a beta of somesort?
All Netduino Go mainboards shipped with production firmware. There's no need to upgrade anything at this time... I just wanted to be thorough in case someone wanted to erase and reflash their Netduino Go as a learning experience
Posted 12 April 2012 - 06:30 AM
Posted 12 April 2012 - 04:04 PM
Posted 12 April 2012 - 08:39 PM
Hahaha defiantly a learning experience for me.
Posted 13 April 2012 - 12:12 AM
The Netduino Go firmware is release firmware.So is this 4.2 Release Candidate 4 like all the other latest board downloads?
There are still a few glitches in .NET MF 4.2 which are affecting the SAM7X and other micros, so the classic Netduino and Netduino Plus are RC for a little while longer.
Posted 14 April 2012 - 10:47 AM
384KB Flash
100KB+ RAM
To find the current version of your Netduino Go firmware:
3. Plug your Netduino Go into your PC using a Micro USB cable.
4. In the Device section at top, select USB instead of Serial. Your Netduino Go should appear in the drop-down; if not, select it.
*** reflashing instructions (on wiki) coming soon ***
I don't c my Netduino Go and version 4.2.0 on visual studio 2010. I downloaded yesterday(fri 13th) with 4.1. then today i downloaded 4.2.0. But i was wondering if my VS2010 is still 4.2 or not? Do i have to remove 4.1 on start up menu?
All i c on my vs2010 is netduino and netduino plus. But y not netduino go on my VS 2010?
BR
Posted 14 April 2012 - 09:08 PM
To get started with your Netduino Go, here are some instructions and the assemblies you need:All i c on my vs2010 is netduino and netduino plus. But y not netduino go on my VS 2010?
http://forums.netdui...d-instructions/
We're testing a new SDK installer that includes a template for Netduino Go as well. It should be ready and posted within a few days...and then you'll have a "Netduino Go" entry in Visual Studio too.
Posted 20 April 2012 - 10:28 AM
Just to let u know that Ver 4.2.0 must comes with either 32 bit or 64 bit. This is y not seeing NETDUINO GO in template. I deleted 4.1 and but i had to deleted VS2010. Because it can't opened vs2010. I had to started all over again
Btw, I'm still waiting for released. And very deeply interesting NGO too.
supra
Posted 20 April 2012 - 04:15 PM
Hey neighbour,Just to let u know that Ver 4.2.0 must comes with either 32 bit or 64 bit. This is y not seeing NETDUINO GO in template. I deleted 4.1 and but i had to deleted VS2010. Because it can't opened vs2010. I had to started all over again
supra
Chris Walker just posted the new SDK early this morning for both 32 and 64 bit systems:
The Netduino v4.2.0 SDK (including Netduino Go support and signed drivers) is now posted:
http://www.netduino.com/downloads/
Cheers,
Steve
Posted 04 June 2012 - 10:44 AM
Posted 04 June 2012 - 11:07 AM
What issues are you having? If the scatter file for MDK differs from the RVDS one, it usually helps to use the RVDS version (copy scatterfile_tinyclr_rvds.xml to scatterfile_tinyclr_mdk.xml, overwrite if asked).Has any one else had issues compiling the firmware using MDK? I keep getting scatter file issues when i try and compile?
Posted 04 June 2012 - 02:02 PM
The exact issues i am having are these:
EXEC : error : L6220E: Load region LR_FLASH size (366612 bytes) exceeds limit (327680 bytes). Region contains 445 bytes of padding and 0 bytes of veneers (total 445 bytes of linker generated content). [D:\netmf\4.2\NetduinoGO-MDK\solutions\NetduinoGo\TinyCLR\TinyCLR.proj] EXEC : error : L6221E: Load region LR_FLASH with Load range [0x07ff0000,0x08049814) overlaps with Load region LR_CONFIG with Load range [0x08040000,0x0804090c). [D:\netmf\4.2\NetduinoGO-MDK\solutions\NetduinoGo\TinyCLR\TinyCLR.proj] EXEC : error : L6221E: Execution region ER_FLASH with Execution range [0x07ff0000,0x080491d0) overlaps with Execution region ER_CONFIG with Execution range [0x08040000,0x0804090c). [D:\netmf\4.2\NetduinoGO-MDK\solutions\NetduinoGo\TinyCLR\TinyCLR.proj] EXEC : error : L6221E: Execution region ER_RAM_RW with Execution range [0x20000000,0x20006730) overlaps with Execution region ER_CUSTOM_HEAP_BEGIN with Execution range [0x20005e00,0x20005f54). [D:\netmf\4.2\NetduinoGO-MDK\solutions\NetduinoGo\TinyCLR\TinyCLR.proj] EXEC : error : L6221E: Execution region ER_RAM_RW with Execution range [0x20000000,0x20006730) overlaps with Execution region ER_STACK_BOTTOM with Execution range [0x20006000,0x20006004). [D:\netmf\4.2\NetduinoGO-MDK\solutions\NetduinoGo\TinyCLR\TinyCLR.proj]
However your suggestion to use the RVDS scatter file resolved it
So now my firmware builds properly, i really wish i had diffed between the 2 scatter files as they are massivly different.
Cheers again:)
Nak.
Posted 06 August 2012 - 01:09 AM
