NETDUINO and SERIAL CAMERA
5 replies to this topic
#1 Simone
Simone
Posted 11 April 2012 - 07:46 PM
Hi to all ... i know c# and vb.net i've some problem in hardware site!!! :) Im new in netduino, i've only a question ( 4 now ) :), but every serial component, like this camera ( http://bansky.net/bl...ro-framework-2/ ) i can add in netduino 's hardware direct in D0, D1 only and i inizialize with : static SerialPort port = new SerialPort("COM1", 115200, Parity.None, 8, StopBits.One); and later i work whit byte data i think .. Can i have up to one serial controller to connect ? Can use netduino mini as the same of netduino ... ? Yes i think .. tnx 1000
#2 Arron Chapman
Arron Chapman
  • 289 posts
  • LocationOregon, USA
Posted 11 April 2012 - 11:08 PM
On the Netduino and Netduino Plus you can have up to 2 UART devices, UART 1 is on Digital Pins 0 & 1, UART 2 is on Digital Pins 2 & 3. The hardware page for the Netduino shows the pin assignments and is the same as the Netduino Plus. The Netduino Mini however only has 1 UART on pins 11 & 12. The hardware page for the mini has all of its pin assignments.
There are devices which will allow you to add more UARTs via an SPI interface, which will work with all of the Netduinos.
#3 awaiK
awaiK
  • 90 posts
Posted 12 April 2012 - 06:24 AM
the Wiki says netduino mini has one TTL and one R232, so in total two UARTs or not?
#4 Chris Walker
Posted 12 April 2012 - 06:26 AM
Hi awaiK,
It has two UARTs...but you'll generally use one of them for deploy/debug. So there is one UART remaining for your code.
#5 Simone
Simone
Posted 13 April 2012 - 05:20 PM
Thanks, now i've only to try when camera will arrive !! :)
#6 Jeffistan
Jeffistan
Posted 20 May 2012 - 03:37 PM
Hi awaiK,
What if I wanted to download the code over USB, but have my Netduino app use the serial port to pass data back to the PC for data logging? It seems like I should be able to do this without a USB to Serial chip, by using the PC's COM port directly. True or false?
Jeff
