Arduino body movement sensor does not work - General Discussion - Netduino Forums
5 replies to this topic
#1 tranceash
tranceash
  • 12 posts
Posted 11 April 2012 - 11:58 AM
I am have a problem connecting this PIR body PIR Sensor to work.
I cant get it to detect any movement. There are 3 wires blue,white,orange. I have connected the blue to the ground pin, white wire to digitalIO pin 5 and yellow wire to the 5v pin on the netduino board.
Is this wiring correct ?
I have this code but the interrupt never fires. Has anyone played with this Arduino body movement sensor and got it to work
namespace SensorTest
       static OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
        static InterruptPort port = new InterruptPort(Pins.GPIO_PIN_D5, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
            // write your code here
            Debug.Print("Application Start!");
            port.OnInterrupt += new NativeEventHandler(port_OnInterrupt);
        static void port_OnInterrupt(uint portId, uint state, DateTime time)
            Debug.Print("Interrupt fired");
            led.Write(true);
            Thread.Sleep(1000);
            led.Write(false);
            Thread.Sleep(1000);
#2 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 11 April 2012 - 12:18 PM
Is there silk screening on the board indicating which wires are +5, GND and OUT? I haven't found any good pictures or wiring diagrams for this sensor.
#3 ErikN
ErikN
  • 119 posts
Posted 11 April 2012 - 02:05 PM
Looking at the third picture on a site that sells them, it looks to me like maybe the connector is set up as |- DET +| when the jumper pins are to the left and the connector is on the bottom of the board facing you.
http://www.geeetech....odule-p-70.html
But otherwise I too can't find any documentation about the module in my, admittedly short, search. At least this suggests there IS a silkscreen on the board. Unless my eyes are really that bad!
#4 ErikN
ErikN
  • 119 posts
Posted 11 April 2012 - 02:08 PM
Looking further at the board, the output goes high when it detects. Your InterruptPort looks like it might be configured for the opposite...
#5 Geancarlo2
Geancarlo2
  • 70 posts
Posted 11 April 2012 - 02:59 PM
First, I suggest you experiment polling the sensor. Second, it seems to me there is a threshold potentiometer, so you should try playing with that...
#6 Giuliano
Giuliano
  • 361 posts
  • LocationSimi Valley, CA
Posted 12 September 2012 - 05:59 AM
Hi Tranceash, Are you using a 10K Ohms resistor? Did you get it to work? If so, how?
