Cannot find any entrypoint!
18 replies to this topic
#1 ColinR
ColinR
  • 142 posts
Posted 10 April 2012 - 04:27 AM
The debugger starts, then exits without hitting any breakpoints. The output window shows "Cannot find any entrypoint!"
I'm trying to work out what caused it. I've re-installed both .NetMF and NetduinoSDK. I was working happily, then took a break, and my laptop had frozen, so I restarted it, and have gotten this error since. Known working backups show the same error. But basic blinky works ok. :blink:
Micro Framework Device Deployment:
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 41108 bytes
Assemblies successfully deployed to device.
Debug Output:
Found debugger!
Create TS.
Loading start at 155b88, end 16e8e0
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching file.
Attaching deployed file.
Resolving.
Ready.
Done.
Waiting for debug commands...
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Diagnostics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded.
The program '[1] Micro Framework application: Managed' has exited with code 0 (0x0).
#2 ErikN
ErikN
  • 119 posts
Posted 10 April 2012 - 05:55 AM
This is what you'll see if you don't have a proper static main() method to start/run your project. Did something happen to it?
#3 ColinR
ColinR
  • 142 posts
Posted 10 April 2012 - 06:48 AM
First thing I checked. It's there.
#4 CW2
Posted 10 April 2012 - 06:56 AM
That error can also mean the runtime cannot locate the application main assembly, for example when it was not deployed successfully. Could you please try erasing the application via 'Erase' button in MFDeploy (next to 'Ping' button) and re-deploy?
#5 ColinR
ColinR
  • 142 posts
Posted 10 April 2012 - 06:59 AM
I'll try that when I get back home, what I did already try was a full erase, reload tinybootloader, RC4 and I got the same issue. If VS states "Assemblies successfully deployed to device." does it really mean it?
#6 Dan Morphis
Dan Morphis
  • 188 posts
Posted 10 April 2012 - 05:12 PM
You don't by chance have multiple projects loaded in your solution do you? If you have multiple projects in a solution, everyone of them gets deployed to your board, and then its luck of the draw as to which one actually gets executed.
-dan
#7 ColinR
ColinR
  • 142 posts
Posted 10 April 2012 - 07:32 PM
I erased the program, and deployed again; no change.
Only the one project in the solution, I also tried creating a new solution altogether and replacing the Program.cs file.
I'm thinking this has something to do with my machine, but if the blinky test works..
#8 Paul Csiki
Paul Csiki
  • 8 posts
  • LocationDublin, Ireland
Posted 11 April 2012 - 10:20 AM
Have you tried adding a breakpoint to see if breaks?
#9 ColinR
ColinR
  • 142 posts
Posted 11 April 2012 - 10:29 AM
Yeah. I tried a break point on Main, and on the first declaration as well. Never hits.
I've also now tried on a second machine - so it's not specific to my machine.
#10 Paul Csiki
Paul Csiki
  • 8 posts
Posted 11 April 2012 - 10:50 AM
I couldn't help to notice that you are using .NET MF 4.2, can you switch back to stable 4.1 and see if you can replicate the problem?
#11 Chris Walker
Posted 11 April 2012 - 08:27 PM
Also...did you make any changes recently (before this stopped working)?
When you updated to .NET MF 4.2, did you reflash TinyBooter...and then flash the matching TinyCLR (.NET MF firmware)?
There are a few reasons you could get this error. The most common:
  • No startup project and/or routine
  • Flash memory layout mismatch
  • Worn out flash (not likely)
Do you have another board to test the app on?
#12 ColinR
ColinR
  • 142 posts
Posted 11 April 2012 - 08:43 PM
No changes.
I did. I flashed TinyBooterDecompressor.bin from Firmware_NetduinoPlus_4.2.0.0_RC4 using SAMBA
  • Worn out flash (not likely) <-- I'm going with this option.
I do, tested on second board with the same solution - unplugged problem Netduino, plugged in new Netduino and it worked straight away. I then loaded Blinky test on the problem Netduino which worked, and also tried another program with smaller size (7KB vs 40KB) that has networking and SD code, all worked happily as well. It's as if the flash works ok in the 'lower' sections, but is worn out further on.
#13 Chris Walker
Posted 11 April 2012 - 08:53 PM
Hi Colin, I wish you were closer, I'd give you a trophy and a free Netduino. The SAM7X MCU on Netudino is rated for 10,000+ reflashing cycles. You've done a _lot_ of development if you've gotten that far. Impressive. I'm not sure if we've ever worn a flash sector (outside of testing scenarios). It's on the list of things that can happen, so I mentioned it, but wow... Chris
#14 ColinR
ColinR
  • 142 posts
Posted 12 April 2012 - 03:42 AM
My board has been used extensively for product development, 10 000 reflashing cycles is easily possible. The current solution is on revision 4817, and I'll typically deploy 3 or 4 times at least per revision.
Time for a new Netduino!
#15 Francisco
Francisco
  • 8 posts
Posted 12 April 2012 - 08:37 PM
Hi Colin,
I have a similar problem with my N+, the blinky program is working fine, but when I try to work with the serial ports, seems like the program hangs forever. This is what the aoutput windows says:
Rebooting...
TinyCLR (Build 4.1.2821.0)
Starting...
Found debugger!
Create TS.
Loading start at 14d324, end 162e8c
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
Attaching file.
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
Attaching file.
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) (512 RAM - 3488 ROM - 1543 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.Usb (4.1.2821.0) (580 RAM - 3740 ROM - 1844 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) (256 RAM - 1108 ROM - 491 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Diagnostics (4.1.0.0) (180 RAM - 440 ROM - 166 METADATA)
Assembly: SimpleBCreader (1.0.0.0) (256 RAM - 808 ROM - 363 METADATA)
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) (268 RAM - 816 ROM - 423 METADATA)
Resolving.
Total: (11012 RAM - 90556 ROM - 49856 METADATA)
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.1\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'SecretLabs.NETMF.Diagnostics'
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Users\Francisco Rascon\Documents\Visual Studio 2010\Projects\SimpleBCreader\SimpleBCreader\bin\Debug\le\SimpleBCreader.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.1\le\SecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded.
The next lines appear in the output windows when in the main Event reads the code: serial = new SerialPort(SerialPorts.COM1,9600);
Step into: Stepping over non-user code 'System.IO.Ports.SerialPort.SerialPort'
this is my full code:
using System.IO.Ports;
namespace SimpleBCreader
        static SerialPort serial;
            // write your code here
            serial = new SerialPort(SerialPorts.COM1,9600);	//Whit this line the program hangs
            serial.Handshake = Handshake.None;
            serial.Open();
            serial.DataReceived += new SerialDataReceivedEventHandler(serial_DataReceived);
            serial.ErrorReceived += new SerialErrorReceivedEventHandler(serial_ErrorReceived);
        static void serial_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
            //Debug.Print(e.ToString());
        static void serial_DataReceived(object sender, SerialDataReceivedEventArgs e)
            //Debug.Print("Data received");
            // create a single byte array
            byte[] bytes = new byte[1];
            // as long as there is data waiting to be read
            while (serial.BytesToRead > 0)
                // read a single byte
                serial.Read(bytes, 0, bytes.Length);
                // send the same byte back
                serial.Write(bytes, 0, bytes.Length);
I thought that maybe my N+ was damaged, so I orderer a new One, same problem.
Please Help.
Edited by Chris Walker, 13 April 2012 - 12:14 AM.
added [quote][/quote] and [code][/code] tags
#16 Chris Walker
Posted 13 April 2012 - 12:16 AM
Hi Francisco, If you set a breakpoint in your main routine and then step through it, how far does it get? If you set a breakpoint in your DataReceived event, does it get tripped when you send data to your Netduino Plus? Finally...what firmware version are you running? Did you update your Netduino Plus from the stock 4.1.0.6 firmware? Chris
#17 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 13 April 2012 - 12:36 AM
I'm having similar problems since flashing and moving to 4.2. I'm in the process of uninstalling .NETMF and the Netduino sdk once again to see if it makes a difference. The issue has also spilled over to my Netduino Go projects as well. I'll post my results a little later. Watching the Ottawa and New York hockey game at the moment. :)
#18 alesbedac
alesbedac
  • 63 posts
Posted 26 October 2013 - 08:13 PM
I get today the same bug...
problem was in projec tclass library where was assigned another project class library (ACL)...but this ACL was missing,
I have deleted this project from sollution, but reference wasn deleted.
after removing missing reference was everything OK
2013-10-25
sorry wrong..i have still the same error. but when is from main prohject removed one library is program working.
this library i am using for networking
#19 Lebeda
Lebeda
  • 5 posts
Posted 02 September 2014 - 06:57 AM
I got the same error when my project was targeting MF 4.3 but my Netduino2+ was running 4.2 firmware
