Thanks guys
Very cool, Pete.
With pin compatibility for Gadgeteer S, U, and X module types...it looks like you were able to just plug in your Gadgeteer Midi module. Sweet.
Thanks for testing this! We'll have to add your Midi module to our upcoming "compatible Gadgeteer modules" list and drivers.
Thanks. To be clear, the driver is different. I shared almost all the code, but Gadgeteer uses a higher-level Serial class, not the base NETMF one. So any serial interface code had to change slightly. The driver I'm using on the GO here is almost identical to the one I wrote for the Netduino/Netduino Plus. I can't imaging using an actual Gadgeteer driver, as they're pretty huge when you look at the dependencies and deployment size.
BTW, if you want we can create a simple wrapper for your Gadgeteer Midi module which takes a socket #, switches that go!bus channel to exclusive mode, and turns on the LED
I'd love to do this myself. Pointers on where to start looking?
Pete
Pete Brown -
http://10rem.net (NETMF, C++, Windows, C64, and general geekery) Twitter:
@pete_brown
