Hardware Details: Shield Base
#21
Posted 20 May 2012 - 07:55 AM
#22
Posted 20 May 2012 - 06:03 PM
#23
Posted 22 May 2012 - 01:31 AM
#24
Posted 22 May 2012 - 06:34 AM
UART, SPI, and I2C aren't exposed on the Shield Base (in proxy mode) quite yet. You can use UART and SPI if you deploy code directly to it, if you want to hack away that way for the moment.What are the proper pin locations to use the PWM channels? I know PWM3 is on Digital 10, but how about the others? Also is I2C available on the shield base currently? If so what pins are SDA and SCL? Is it analog 4/5 similar to the netduino plus? Would it be possible to release a pinout diagram to negate these questions in the future? It would make it much easier to work with.
We currently have channels 1-4 mapped to the four PWM channels as on Netduino and the other 2 PWM channels to the remaining 2 Arduino PWMs. But we've gotten feedback that this is a bit confusing, so we may remap those in a beta update to be sequential on the headers (and also add a method which lets you specify a pin instead of a channel #).
Posted 22 May 2012 - 11:57 AM
Just a thought on the remapping/confusion. Which is more important for the user base - compatibility with the Arduino platform / shields or a sequential set of pins for a function.We currently have channels 1-4 mapped to the four PWM channels as on Netduino and the other 2 PWM channels to the remaining 2 Arduino PWMs. But we've gotten feedback that this is a bit confusing, so we may remap those in a beta update to be sequential on the headers (and also add a method which lets you specify a pin instead of a channel #).
I never remember these things unless I use them every day and so use things like the pinout cards which have been created for the Netduino and Mini.
Maybe just producing a pinout card for the Shieldbase would be adequete. I know I'd be happy with that as a solution. In fact I'd prbably prefer this as it reduces the risk of compatibility problems.
#26
Posted 25 May 2012 - 05:16 AM
#27
Posted 25 May 2012 - 07:37 PM
#28
Posted 25 May 2012 - 07:53 PM
Very unlikely. In fact, it should be pretty much impossible to brick them. Worst case we can reflash something. They both have 10,000+ or 100,000+ rewrite cycles.Edit: I see the early module flashing utility posted earlier. What's the chance it'll brick the main or shield boards?
Here's the link to reflash the shield base to its production firmware (easier than deploying virtual i/o code etc.)
http://forums.netdui...-based-modules/
Posted 25 May 2012 - 07:55 PM
The easiest way is to use the reflashing tool:1) I'd like to reflash the sheild base back to the proxy, as above.
That should be it. You also need to provide 3.3V and GND from a regulated power source (on the 3V3/GND pins). And double-check that TX/RX are crossed correctly between your FTDI and the Shield Base. But otherwise you should be good to go.2) How did you get the hello world to work - did you flash the board? I plugged in the FTDI to d0/d1 rx/tx and 3.3v ground from a working board
Posted 25 May 2012 - 08:18 PM
#31
Posted 25 May 2012 - 09:13 PM
Hmm, that sounds like one of the protection modes kicking in and resetting the mainboard repeatedly.Edit: reflashed the GO. GO's OK (I think it was OK beforehand). But pluggin in the shield base give the all blue lights flashing thing.
If you unplug the shield base, does the mainboard reboot okay?
If you deploy the reflash app to the mainboard with the shield base detached, does the mainboard still start up okay?
If you then attach the shield base and repower the mainboard, does it flash the Shield Base alright?
The mainboard will keep the shield base turned off by default at boot...so there should be a good way to orchestrate this
Posted 25 May 2012 - 09:31 PM
1. If you unplug the shield base, does the mainboard reboot okay?
2. If you deploy the reflash app to the mainboard with the shield base detached, does the mainboard still start up okay?
3. If you then attach the shield base and repower the mainboard, does it flash the Shield Base alright?
The mainboard will keep the shield base turned off by default at boot...so there should be a good way to orchestrate thisWe built in several failure and backup modes.
In response to the renumbered list:
1) Yes
2) "Assemblies successfully deployed to device." Socket 5 is lit (that's the one I selected for the reflash) Then I unplug the USB.
3) Plug it in, all lights flash, then socket 5 steady. Wait a long time. Get bored. Reboot. Chip on Shield Base gets very hot.
Performed the same procedure. Changed the socket number to 4. Same result: plug in the shield base to 4, turn on the GO. All lights flash. Then 4 light only - steady, no flashing. Processor on shield base gets too hot to touch.
#33
Posted 25 May 2012 - 11:02 PM
#34
Posted 26 May 2012 - 05:40 AM
#35
Posted 26 May 2012 - 05:45 AM
Applying 5V power to a 3V3 chip probably wouldn't be goodI try to avoid things like that but it's possible. It's possible that I've put 5V down the 3.3V rail too. My problem is that in the UK, at the moment, the shield base isn't available separately.
You can pick up the Shield Base and individual modules from UAE, although I'm not sure how much shipping costs...
http://shop.microfra...ctOut.aspx/3798
In any case, I'll send back my shield base to help your diagnosis.
If you don't mind waiting 2 weeks for delivery, I'd be happy to send you a replacement board via USPS Global Priority Mail.
Posted 26 May 2012 - 09:43 PM
#37
Posted 27 May 2012 - 07:41 AM
I used an FTDI breakout like Chris described, and just used the template for a Microsoft .NET Micro Framework 4.2 Console Appplication (no Netduino Go references). Made sure the settings were to deploy to Serial, and joy it worked. And created a prototype shield for the shield base to do all the wiring from FTDI cable with 3.3V regulator. That worked too. I can share that later.
Then I tried a new program using GPIO pins 2, 11, 12, 13 (wasn't quite sure how the pins are numbered??) and I've gotten the shield hung up where it won't respond to mfdeploy ping. Putting it aside for now and will try reseting and reflashing tomorrow.
#38
Posted 27 May 2012 - 02:43 PM
Reflashing using STM32ReflashApp worked. The instructions say to connect the shield base to socket 4 but the code says socket 5. Nice to have the leds next to the sockets to give an indication of who is talking to what. Easy enough to switch sockets and re-run.
Thanks!
#39
Posted 27 May 2012 - 03:21 PM
Trying to blink Cpu.Pin.GPIO_Pin13 (13) isn't working for me when using the shield as a standalone netduino (without the Go).
What are the proper pin definitions for D0..D13 and A0..A5 for using the bonus 512K shield base as a separate netduino? Where are these defined? Is there a good place to look in the shield base firmware?
Thanks in advance.
#40
Posted 27 May 2012 - 04:39 PM
... created a prototype shield for the shield base to do all the wiring from FTDI cable with 3.3V regulator. That worked too. I can share that later.
Plugging this into the shield base by itself, and plugging FTDI Cable 5V into the six pin right angle jack, this provides power and access to the 512K shield base via USB to serial. This way the 512K shield base can be used separate from the Go, as a low priced Netduino.
The 3.3V regulator is LM1117MPX-3.3/NOPB (SOT-223), with a 10uF tantalum capacitor on 5V input, and 22uF tantalum capacitor on 3.3V output. I used the freetronics prototype shield and populated it with a reset button, power LEDs, 0.1uF filter capacitors, and Arduino style headers (sorry IOREF, SCL, SDA). TX and RX from the FTDI are connected to D0 and D1 of the Netduino.
(click on pictures to see larger)
- Gutworks likes this
