Amazon.com had them but may be out of stock.If I may ask my first of many dumb questions, where can I get more go!bus cables?
Nwazet.com had them in 3 sizes.
Introducing Netduino Go
Started by Chris Walker, Apr 04 2012 08:29 AM
153 replies to this topic
#81Posted 14 April 2012 - 03:07 PM Amazon.com had them but may be out of stock. Nwazet.com had them in 3 sizes. #82Posted 14 April 2012 - 09:06 PM
Hi Corey,
To add to what Carb said, here you go... Amazon Nwazet Proto-Advantage #83Posted 15 April 2012 - 02:53 AM
Is a module with an High-Ampere Relay also in the list? In one of my Netduino projects I had to drive a 300W motor (startup peak power of 1KW) and I had really hard time finding a relay module that interfaced with the Netduino and had a good electrical separation between high and low voltage. Only one guy from China made those modules for the Arduino/Netduino and I bought a bucketful of those just in case. But it will be nice to see more mainstream support for those of us who want to interface with 100~250VAC devices. #84Posted 15 April 2012 - 08:40 AM Absolutely, www.nwazet.com has it already for pre-order.
My .NETMF projects: .NETMF Toolbox / Gadgeteer Light / Some PCB designs #85Posted 15 April 2012 - 11:20 AM
First of all, this is an amazing, clever and scalable project!
But i cannot buy it until ethernet module is ready, whet it will be?
Thank you
Gerardo
#86Posted 15 April 2012 - 08:36 PM
Hi Gerado,
Thank you very much for the feedback. I'm sure the team will appreciate it! The Ethernet module will be available soon. We're using a groundbreaking new microcontroller on it, so the module couldn't make it quite in time for launch. I'll keep you all apprised. We designed the Netduino Go (mainboard) to support this and a whole array of new module types over the next few years. Chris #87Posted 17 April 2012 - 12:54 PM
Just taken delivery of my shiny new Go kit now who can send me (or direct me to) the current API for it?
Thanks in advance,
Mike
#88Posted 17 April 2012 - 01:39 PM Hi Mike, Check out http://forums.netdui...d-instructions/ you'll find the files there
My .NETMF projects: .NETMF Toolbox / Gadgeteer Light / Some PCB designs #89Posted 17 April 2012 - 05:40 PM
Well I pulled the trigger and ordered a GO Starter Kit from Amazon. Haven't messed with the microframework in quite awhile, but the GO seems to have a huge amount of potential, I couldn't help but get one for myself.
Now I need to order one of the mounting plates and a display from http://www.nwazet.com/ and I'll be all set.
-Eric
#90Posted 17 April 2012 - 11:03 PM
Wow Chris and team. This is an great advancement over the previous models. I cant wait to get a hold of one and come up with a project worthy of it :-)
- Jarrod Sinclair
http://jarrodsinclair.wordpress.com// #91Posted 18 April 2012 - 11:45 AM
No mentions of H modules what type is that? Be really cool if we could make use of the camera module or even bas a new module on one: http://www.coolcompo...dule-p-834.html #92Posted 18 April 2012 - 08:24 PM
Hi Mike,
Good question. "H" is a Gadgeteer socket type for USB Host. A Gadgeteer-compatible mainboard doesn't need to just have a USB Host-enabled socket though...it also needs to support the particular USB profile of that USB camera. Also, several Gadgeteer modules only work with a specific model of mainboard or require confidential software drivers. That's one of the nice things about using go!bus virtualization on Netduino Go. You can pick up any go!module and, given enough flash and RAM and power supply, you just plug it in and go. I would bet that someone ships a camera go!module sometime this year. I'm looking forward to playing with one for sure. Chris #93Posted 20 April 2012 - 01:05 AM Thanks! that exactly what I need. I wish the Netduino Go would have been available six months ago. It would have save me a ton of time. #94Posted 20 April 2012 - 10:40 AM
Is the TCP stack more stable in the face of high traffic? This is looking phenomenal. My significant other will go berserk when she finds out my workshop needs a total refit. Just thinking about go!bus and Gadgeteer and prototyping in general, and here's a silly question for you: having prototyped and got everything to work, are there any tools for the transition from prototype to production? If I have Eagle files for all the modules, is there some software you can tell "I have these boards connected thusly, here are the eagle files for them, now give me one big board layout and bill of materials" ? Certainly there are companies in China that will take an eagle file and a credit card number and post you finished boards.
#95Posted 20 April 2012 - 11:35 AM That's part of the reason for the change. We can't guarantee against DDoS, but the distributed networking MCU design should help. We've designed Netduino Go to support this type of scenario. You can use go!bus on your custom circuit board...but in many cases it'll probably make the most sense to pick up the appropriate STM32F2/4 chip (with up to 170 pins or so) which has the pins and features you need...and then reuse your code with an integrated design there. [And if you need the virtualization for your production product...that's fine too!] Chris #96Posted 22 April 2012 - 07:10 PM
Will the Ethernet ENC28 Module (Type S) from GHI, or the ethernet shield work with the GO? I just ordered mine from Amazon.
#97Posted 23 April 2012 - 04:16 PM
Hi LenR,
With the Ethernet Gadgeteer modules, there are a few of them and they all seem to require specific boards to make them work. An "S" on a Gadgeteer module does not mean that it will work with any S-capable Gadgeteer socket. The "E" ones only work with certain boards. And the "Z" ones can be board-specific. If you'd like to use that module in Gadgeteer mode (i.e. using 4 sockets), you could compile in the ENC28J60 driver for NETMF 4.2 and have networking. We actually did this with that module during development, as a test...and it seemed to work. If you have one of the old DFRobot or old Arduino Ethernet shields (the ones that don't need the ICSP headers) you'll be able to use that with the Shield Base soon... Also, the newer Arduino Ethernet shields will work if you sandwich a MakerShield in the middle (so that you get the ICSP headers). My personal recommendation is to wait for the Netduino Go Ethernet module...we'll have support for that in the core SDK. Chris #98Posted 25 April 2012 - 04:21 PM
I just received my NetduinoGo with a Rgb Led & Button modules and I can't get them to work. When you first power up the Netduino the 8 Leds come on then go off and only the power led stays on even though the RgbLed & Button module are connected. This is the program I am using:
using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoGo; //using NetduinoGo; namespace NetduinoGoFirstApp { public class Program { public static void Main() { // write your code here var led = new RgbLed((GoBus.GoSocket)8); led.SetColor(255, 40, 0); } } }I get the error messag saying RgbLed namespace is not recognized. What am I doing wrong? Any help would be greatly appreciated. Thank you, Mike (motor900)
Edited by Chris Walker, 27 April 2012 - 02:08 AM.
#99Posted 25 April 2012 - 06:12 PM Hi Mike, Welcome to the Netduino Community. It looks like you have not added the reference to NetduinoGo.RgbLed. To do this right click on the "Reference" in the Solutions Explorer. Then "Add Reference" and you should see the NetduinoGo.RgbLed listed in the .Net tab if you have installed the Netduino Go firmware found on the downloads page. In your code you have this statement commented out : //using NetduinoGo; If you uncomment, your code should work fine. Alternatively, and without uncommenting the use statement, you can use: var led = new NetduinoGo.RgbLed((GoBus.GoSocket)8); Hopefully this should do the trick. Cheers, Steve Twiiter: https://twitter.com/Gutworks #100Posted 27 April 2012 - 12:58 AM
In another thread I asked Chris about tools for the transition from prototype to production, but it occurs to me that cheap virtualisation relieves the need to a great extent; single board manufacture is cheap but modules make for fine grained testing and replacement. For small run vertical market production, I think it may be economic to design a go!bus device with such custom hardware as is necessary for a given project.
Is it a long discussion that is documented anywhere?
This sounds to me like you have some kind of addressing scheme and a corresponding discovery mechanism as well as I/O queuing to prevent collisions on shared channels - essentially a small network. Is that right? The STM32F2 and 4 both have an onboard RTC. I hope you're surfacing this.In fact the datasheet I'm looking at says it supports ethernet. But I understand why you'd want to offload this to other hardware.
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
