How to back to alive from firmware updating failure
#1 yiulsup
yiulsup
  • 34 posts
Posted 03 April 2012 - 02:34 AM
I tried to update the firmware in Netduino Plus. 1. To fuse the ER_CONFIG with MFDEPLOY : completed 2. To fuse the ER_FLASH with MFDEPLOY : Incompleted After that, there was message which is "Deploy Error" on updating firmware. now, MFDeploy cann't fuse the flash with ER_CONFIG.hex anymore. and ping didn't get the answer from Netduino plus in MFDeploy.
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 03 April 2012 - 06:16 AM
Hi yiulsup and welcome to the Netduino forums! Which firmware did you try to flash? Don't worry, it's not easy to break a Netduino, so we'll probably be able to fix this. First, start flashing the tinybootloader according to this tutorial: http://wiki.netduino...ep-by-step.ashx Second, flash the firmware: http://wiki.netduino...ep-by-step.ashx Doing that will probably save it!
#3 yiulsup
yiulsup
  • 34 posts
Posted 05 April 2012 - 09:32 AM
My Firmware Version is version 4.1.0.6. Your advice is right for me with all working.
I tried like belows.
1. To connect the samba to my netduino plus. : completed
2. To write tinybooterdecompressed.bin to my netduino : completed.
3. To power off the netduino.
4. To plug the usb cable to my laptop.
5. To connect the mfdeploy : completed
6. To connect the mfdeploy with USB : completed
7. To write ER_CONFIG and ER_FLASH : incompleted.
I think that problem 7 is occurred by address collide in link.
Is it right for my thinking?
I also tried firmware which you recommended on forum at several times.
How to solve it?
Thanks ahead.
