I am totally new to the netduino world as well as coding. I am wanting to know a couple things. Is there an application that is used to control all of the digital outputs and are the analog inputs able to do output? I have ordered a c# book and waiting for it to come in the mail. I am just eager to get started. Any help is much appreciated. I have the netduino plus and have upgraded the firmware to 4.2.
Application to run I/O ports
Started by duinoman, Mar 24 2012 07:42 PM
Posted 24 March 2012 - 07:42 PM
Posted 25 March 2012 - 03:51 AM
Hello,
Probably the easiest way to control all of the output pins is to create an array for OutputPins, and create a output pin for each output. Then loop through the array to set the value for each.
The analog inputs can output like a DIO i believe.
I hope that helps,
Ralim
Posted 25 March 2012 - 02:31 PM
Hello,
I hope that helps,
Ralim
You can also create a dictionary of type outputpins, this way you can access all the properties and methods without having to cast them back into their types and address them using a key rather than an index into an array. I also belive that the Analogue pins can act as both Input and output pins like any other I/O pin in the system.
Pete.
The world will have to wait.
