I'm trying to be able to deploy to the netduino via the MFDeploy. My project deploys and runs fine when I run it from vs.net. However, when I load up mfdeploy and look for a .hex file, none are anywhere to be seen. I realize I'm probably missing something really obvious here, but where is the .hex file created?
hex image file and deployment
Started by allen, Mar 10 2012 06:21 AM
1 reply to this topic
Posted 10 March 2012 - 06:21 AM
Posted 10 March 2012 - 07:48 AM
Hi allen,
The deployment file is created by Visual Studio's build process and written directly via MFDeployEngine.
If you want, you can create a copy of it by reading it off your device using MFDeploy. [Use the "Create Application Deployment" feature]
If you poke around the Mono forum here, you'll find a manual build process which you can use as well, if desired.
Does that help?
