http://www.amazon.co...s00_i00_details
will this board work with with PLUS?
WIFI
Started by ErikOwsiak, Mar 07 2012 01:10 AM
8 replies to this topic
Posted 07 March 2012 - 01:10 AM
Posted 07 March 2012 - 12:32 PM
The Microchip Wifi-chip fitted on the board uses an SPI interface and Netduino supports that. However, the chip is rather dumb in the sense that it doesn't do TCP/IP internally so you must implement that on the Netduino which is much work and would yield quite poor performance.
I would recommend you take a look at another wifi board that has TCP/IP built in. For instance, have a look at this thread:
http://forums.netdui...h__1#entry15767
Posted 08 March 2012 - 10:09 AM
Thank you.
What do you think about this?
http://www.linksprit...p?id=48&lang=en
Posted 08 March 2012 - 11:10 AM
In the end I will try using this:
http://www.amazon.co...s00_i01_details
Posted 08 March 2012 - 11:21 AM
Yup, that would probably be the absolutely simplest solution.
Posted 17 March 2012 - 10:05 PM
I have purchased a Netduino Plus and awaiting delivery.
Was wondering if any had used an IOGEAR GWU627 Universal Wi-Fi N Adapter Network adapter with this board, I have serval that I use with about everything form video cameras to computers.
They are relatively cheap < $35.00 including shipping, come with power supply or can run off of a supplied USB cable (5 volt). They provide 802.11n - 300 Mbps - WEP - WPA - WPA2.
Thanks for the information provided in your forum, I will try the WiFi card when the Netduino Plus comes in on Monday.
Posted 22 March 2012 - 11:47 PM
I haven't used that particular product but I have used a similar product from Dlink.
My Dlink device worked well so I doubt you will have any problems with yours, especially since the whole purpose is transparency.
Good luck!
Posted 23 March 2012 - 04:52 PM
I did get a chance to try the WiFi adapter, it worked seamlessly with the Netduino Plus. I had the card up and working in about a half hours time.
The adapter and the Netduino are about the same size. The hardest part was that I missed the instructions on how to change the IP address for the Netduino. The range of addresses for the card DHCP was outdide the ones that my Cisco router would take. After that was changed all I had to do was plug them in.
Posted 23 March 2012 - 05:50 PM
That's great!
