I2C
#1 Stari
Stari
  • 26 posts
Posted 23 February 2012 - 11:24 AM
Hello I just finished a few things, thanks to this community. I wonder if anyone has made ​​communication with the DS1307 in VB ? In C# all things are working well, but if anyone has example in Vb, i will be very happy. Stari http://www.zlatnajedra.com
#2 mimtarsden
mimtarsden
  • 8 posts
Posted 27 February 2012 - 09:24 PM
This is the code i used, I found it in the C# forum I 'think' it was originally by Fabien Royer, I quickly translated it to VB it seems to work perfectly...
Namespace netduino.helpers.Hardware
    ''' <summary>
    ''' This class implements a complete driver for the Dallas Semiconductors / Maxim DS1307 I2C real-time clock: http://pdfserv.maxim-ic.com/en/ds/DS1307.pdf
    ''' </summary>
    Public Class DS1307
        Implements IDisposable
        ' Defines the frequency of the signal on the SQW interrupt pin on the clock when enabled
        <Flags()> _
        Public Enum SQWFreq
            SQW_1Hz
            SQW_4kHz
            SQW_8kHz
            SQW_32kHz
            SQW_OFF
        End Enum
        ' Defines the logic level on the SQW pin when the frequency is disabled
        <Flags()> _
        Public Enum SQWDisabledOutputControl
            Zero
            One
        End Enum
        ' Real time clock I2C address
        Public Const DS1307_I2C_ADDRESS As Integer = &H68
        ' I2C bus frequency for the clock
        Public Const DS1307_I2C_CLOCK_RATE_KHZ As Integer = 100
        ' Allow 10ms timeouts on all I2C transactions
        Public Const DS1307_I2C_TRANSACTION_TIMEOUT_MS As Integer = 10
        ' Start / End addresses of the date/time registers
        Public Const DS1307_RTC_START_ADDRESS As Byte = &H0
        Public Const DS1307_RTC_END_ADDRESS As Byte = &H6
        ' Square wave frequency generator register address
        Public Const DS1307_SQUARE_WAVE_CTRL_REGISTER_ADDRESS As Byte = &H7
        ' Start / End addresses of the user RAM registers
        Public Const DS1307_RAM_START_ADDRESS As Byte = &H8
        Public Const DS1307_RAM_END_ADDRESS As Byte = &H3F
        ' Total size of the user RAM block
        Public Const DS1307_RAM_SIZE As Byte = 56
        ' Instance of the I2C clock
        Private clock As I2CDevice
        Public Sub New()
            clock = New I2CDevice(New I2CDevice.Configuration(DS1307_I2C_ADDRESS, DS1307_I2C_CLOCK_RATE_KHZ))
        End Sub
        ''' <summary>
        ''' Gets the date / time in 24 hour format.
        ''' </summary>
        ''' <returns>A DateTime object</returns>
        Public Function [Get]() As DateTime
            Dim clockData As Byte() = New Byte(6) {}
            ' Read time registers (7 bytes from DS1307_RTC_START_ADDRESS)
            Dim transaction = New I2CDevice.I2CTransaction() {I2CDevice.CreateWriteTransaction(New Byte() {DS1307_RTC_START_ADDRESS}), I2CDevice.CreateReadTransaction(clockData)}
            If clock.Execute(transaction, DS1307_I2C_TRANSACTION_TIMEOUT_MS) = 0 Then
                Throw New Exception("I2C transaction failed")
            End If
            ' year
            ' month
            ' day
            ' hours over 24 hours
            ' minutes
            ' seconds
            Return New DateTime(BcdToDec(clockData(6)) + 2000, BcdToDec(clockData(5)), BcdToDec(clockData(4)), BcdToDec(clockData(2) And &H3F), BcdToDec(clockData(1)), BcdToDec(clockData(0) And &H7F))
        End Function
        ''' <summary>
        ''' Sets the time on the clock using the datetime object. Milliseconds are not used.
        ''' </summary>
        ''' <param name="dt">A DateTime object used to set the clock</param>
        Public Sub [Set](ByVal dt As DateTime)
            Dim transaction = New I2CDevice.I2CWriteTransaction() {I2CDevice.CreateWriteTransaction(New Byte() {DS1307_RTC_START_ADDRESS, DecToBcd(dt.Second), DecToBcd(dt.Minute), DecToBcd(dt.Hour), DecToBcd(CInt(dt.DayOfWeek)), DecToBcd(dt.Day), _
             DecToBcd(dt.Month), DecToBcd(dt.Year - 2000)})}
                Throw New Exception("I2C write transaction failed")
            End If
        End Sub
        ''' <summary>
        ''' Enables / Disables the square wave generation function of the clock.
        ''' Requires a pull-up resistor on the clock's SQW pin.
        ''' </summary>
        ''' <param name="Freq">Desired frequency or disabled</param>
        ''' <param name="OutCtrl">Logical level of output pin when the frequency is disabled (zero by default)</param>
        Public Sub SetSquareWave(ByVal Freq As SQWFreq, Optional ByVal OutCtrl As SQWDisabledOutputControl = SQWDisabledOutputControl.Zero)
            Dim SqwCtrlReg As Byte = CByte(OutCtrl)
            SqwCtrlReg <<= 3
            ' bit 7 defines the square wave output level when disabled
            ' bit 6 & 5 are unused
            If Freq <> SQWFreq.SQW_OFF Then
                SqwCtrlReg = CByte(SqwCtrlReg Or 1)
            End If
            SqwCtrlReg <<= 4
            ' bit 4 defines if the oscillator generating the square wave frequency is on or off.
            ' bit 3 & 2 are unused
            SqwCtrlReg = SqwCtrlReg Or CByte(Freq)
            ' bit 1 & 0 define the frequency of the square wave
            WriteRegister(DS1307_SQUARE_WAVE_CTRL_REGISTER_ADDRESS, SqwCtrlReg)
        End Sub
        ''' <summary>
        ''' Halts / Resumes the time-keeping function on the clock.
        ''' Calling this function preserves the value of the seconds register.
        ''' </summary>
        ''' <param name="halt">True: halt, False: resume</param>
        Public Sub Halt(ByVal halt__1 As Boolean)
            Dim seconds = Me(DS1307_RTC_START_ADDRESS)
            If halt__1 Then
                ' Set bit 7
                seconds = CByte(seconds Or &H80)
            Else
                ' Reset bit 7
                seconds = CByte(seconds And &H7F)
            End If
            WriteRegister(DS1307_RTC_START_ADDRESS, seconds)
        End Sub
        ''' <summary>
        ''' Writes to the clock's user RAM registers as a block
        ''' </summary>
        ''' <param name="buffer">A byte buffer of size DS1307_RAM_SIZE</param>
        Public Sub SetRAM(ByVal buffer As Byte())
            If buffer.Length <> DS1307_RAM_SIZE Then
                Throw New ArgumentOutOfRangeException("Invalid buffer length")
            End If
            ' Allocate a new buffer large enough to include the RAM start address byte and the payload
            'Address byte
            Dim TrxBuffer = New Byte(1 + (DS1307_RAM_SIZE - 1)) {}
            ' Set the RAM start address
            TrxBuffer(0) = DS1307_RAM_START_ADDRESS
            ' Copy the user buffer after the address
            buffer.CopyTo(TrxBuffer, 1)
            ' Write to the clock's RAM
            Dim transaction = New I2CDevice.I2CWriteTransaction() {I2CDevice.CreateWriteTransaction(TrxBuffer)}
            End If
        End Sub
        ''' <summary>
        ''' Reads the clock's user RAM registers as a block.
        ''' </summary>
        ''' <returns>A byte array of size DS1307_RAM_SIZE containing the user RAM data</returns>
        Public Function GetRAM() As Byte()
            Dim ram = New Byte(DS1307_RAM_SIZE - 1) {}
            Dim transaction = New I2CDevice.I2CTransaction() {I2CDevice.CreateWriteTransaction(New Byte() {DS1307_RAM_START_ADDRESS}), I2CDevice.CreateReadTransaction(ram)}
            End If
            Return ram
        End Function
        ''' <summary>
        ''' Reads an arbitrary RTC or RAM register
        ''' </summary>
        ''' <param name="address">Register address between 0x00 and 0x3f</param>
        ''' <returns>The value of the byte read at the address</returns>
        Default Public ReadOnly Property Item(ByVal address As Byte) As Byte
            Get
                If address > DS1307_RAM_END_ADDRESS Then
                    Throw New ArgumentOutOfRangeException("Invalid register address")
                End If
                Dim value = New Byte(0) {}
                ' Read the RAM register @ the address
                Dim transaction = New I2CDevice.I2CTransaction() {I2CDevice.CreateWriteTransaction(New Byte() {address}), I2CDevice.CreateReadTransaction(value)}
                End If
                Return value(0)
            End Get
        End Property
        ''' <summary>
        ''' Writes an arbitrary RTC or RAM register
        ''' </summary>
        ''' <param name="val">The value of the byte to write at that address</param>
        Public Sub WriteRegister(ByVal address As Byte, ByVal val As Byte)
            End If
            Dim transaction = New I2CDevice.I2CWriteTransaction() {I2CDevice.CreateWriteTransaction(New Byte() {address, CByte(val)})}
            End If
        End Sub
        ''' <summary>
        ''' Takes a Binary-Coded-Decimal value and returns it as an integer value
        ''' </summary>
        ''' <param name="val">BCD encoded value</param>
        ''' <returns>An integer value</returns>
        Protected Function BcdToDec(ByVal val As Integer) As Integer
            Return (((val \ 16) * 10) + (val Mod 16))
        End Function
        ''' <summary>
        ''' Takes a Decimal value and converts it into a Binary-Coded-Decimal value
        ''' </summary>
        ''' <param name="val">Value to be converted</param>
        ''' <returns>A BCD-encoded value</returns>
        Protected Function DecToBcd(ByVal val As Integer) As Byte
            Return CByte(((val \ 10) * 16) + (val Mod 10))
        End Function
        ''' <summary>
        ''' Releases clock resources
        ''' </summary>
        Public Sub Dispose() Implements IDisposable.Dispose
            clock.Dispose()
        End Sub
    End Class
End Namespace
Hope that helps.
#3 Stari
Stari
  • 26 posts
Posted 28 February 2012 - 04:02 PM
Thank you. Very useful. Stari http://www.zlatnajedra.com
