How do I change the project template so that the newly created project defaults to Transport = USB instead of emulator? I've poked around at the template file and am not spotting anything likely.
Change VS template defaults to USB/Netduino?
Started by Llaves, Feb 19 2012 10:16 PM
1 reply to this topic
Posted 19 February 2012 - 10:16 PM
Posted 19 February 2012 - 10:55 PM
Hmm, that isn't part of the actual template file (.csproj) itself. Instead it is part of the .csproj.user file that gets created as you start using it. Create a project based on the template, set the properties to go over USB and save. Then go open up the .csproj.user file. You should see something like:
<?xml version="1.0" encoding="utf-8"?> <Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|AnyCPU'"> <DeployTransport>USB</DeployTransport> <DeployDevice>NetduinoPlus</DeployDevice> </PropertyGroup> </Project>
You could try adding the .csproj.user file into the template zip file. You would also need to update the ".vstemplate" file that comes inside the template. You need to add a <ProjectItem> line for the new file.
I have no idea if it will let you embed the .user file like that, it is intended to be workstation specific. I'm honestly not sure what it'll do
