LCD-Boost library for Netduino
Posted 12 February 2012 - 03:49 PM
http://highfieldtale...y-for-netduino/
Have fun!
Posted 12 February 2012 - 06:05 PM
Posted 30 July 2013 - 12:15 PM
Hello
One question:is possible to control the backlight using the bit 8 of 74HC595 in this circuit ?
Best Regards
Posted 30 July 2013 - 01:43 PM
Hello Djeizan.
First answer: no, it's not possible, because the 8th bit is reserved for the latch enable. This trick is the fundamental way for achieving a much faster speed.
Second answer: instead of using a classic output, consider using any PWM output. With the same effort in terms of hardware, you'll have a brightness control for free!
Posted 24 August 2013 - 12:43 AM
Thanks Mario
Posted 22 February 2014 - 03:14 AM
Posted 22 February 2014 - 04:46 AM
Hi Mario! Would the LCD-Boost library work with a 128x64 LCD like this one: http://www.fractroni...12864b_full.pdf It uses two KS0108B controllers, one for the left and right half part of the display respectively.
Hello Hanzibal.
The short answer is: yes and no.
Yes, because the E-signal driving mechanism is the same as the HD44780 LCD modules. No, because the trick (with just one 74HC595) leverages on a 4-bit data transfer.
If you accept to use two 74HC595 chained, that's fine!
...worthwhile?
Posted 22 February 2014 - 09:44 AM
Posted 22 February 2014 - 10:58 AM
Since I'm dealing with a graphic display (equipped with a graphic engine), I'd discourage you from driving such a module in a raw-fashion. I mean using C#.
The sh-reg trick is valuable for a "stupid" char-module, which is very limited, but even "as is": you couldn't extract wine from water (unless you're God).
If you have in mind of writing a kind of API layer, I'd suggest to use a small MCU, and write the HAL onto that chip using C (or C++). Try yourself to have a peek at the several functions of a graphics driver, and you'll mean there's no chances to make it working "fast-enough" in managed C#.
Instead, you could write some helper in the proxy-MCU (e.g. Arduino mini), then use some SPI/I2C/UART-commands from the C# code.
Finally, I'd strongly suggest to have a look at the awesome FT800 Eve board, because it's pretty cheap yet very powerful. With roughly 50 Euro you can have a 3.5" TFT display, with touch, sound and the engine ready to mount somewhere.
Posted 22 February 2014 - 12:46 PM
Posted 22 February 2014 - 01:39 PM
The GDI library of the LCD-boost is something to play with, not a serious thing if you need to create even a pretty decent project. That's because I didn't put so much effort around it: a char-module is limited by itself, and a led-matrix (led, not lcd) has typically a different target than a touch display.
Let's say the Lcd-boost could be used either for char-modules (HD77480-like) or led-matrix modules (e.g. scrollers, alerts, etc). In both cases, the graphics capabilities are pretty limited.
Well, about an "engine-surrogate" made by a MCU, isn't simple at all. You should know in advance what to implement (that is, what you need), and create a protocol of commands. Those commands should be as smart as possible, yet also raw-enough to be flexible.
I never created such a protocol, because it's an hard task and I never had this need. Just have a peek at the Eve commands: they done it, although is not so clear. Few docs, some command undocumented, and your mind should think as the engine does. I suppose the commands are close to the OpenGL pipelining, but I don't know that. For sure, there are commands clearly referring to the OpenGL specs.
I'd suggest to consider the Eve, just because the price is worthwhile respect to the "huge" amount of function the board does for you. The "huge" term should be meant as the time you should spend to implement something similar by yourself. Furthermore, I believe the engine core is 32-bit, because almost everything "speaks at 32-bit chunks".
Anyway, if you aren't in hurry, I want just to demonstrate how easy is creating a small home-automation project using the Eve and the Netduino. I suggest to wait a little bit more, then you'll decide.
Yes, the usb plug is just for the supply.
SPI is almost perfect for this board. From the command perspective, I'd like more the UART, but the achievable speed (30M) is not reachable.
The "hardest" part of Eve to deal with is the circular buffer used for the data transfer. Since you may transfer even streamed data (e.g. pictures), the physical buffer is just 4k, and the host should fill-and-wait the actual engine data consumption.
I don't have deal with it using C# yet!
Feel free to contact me via e-mail or Skype, if you have something concrete in mind.
Posted 22 February 2014 - 02:16 PM
Posted 19 October 2015 - 02:57 AM
Not sure if this will get picked up cause this post is pretty old. I really need to get some more performance out of a HD44780 I'm using over spi. I'm just using the stefan's .netmftoolbox at the moment to drive it using the 74hc595 class. I thought the perfomance would be ok except that it is not really. I've got the code copied into my project but have to change it because the wiring is different on the custom PCB i have made. can anyone help me modify the code to allow for my different wiring? Bit_shifting is a little out of my depth. All though, come to think of it. I would still need to use the 74ch595 class because the are three 595's in the chain. if I were to go and use the spi directly it would write random stuff to the next 2 chips in the chain. Which brings me to the next question. would using this display driver get me anymore performance. seeing that It would have to write to the spi over the 74hc595 class from the netmftoolbox anyway. Anybody?
//#define CRONO using System; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using System.Threading; using Cet.HW.GDI; /* * Copyright 2012, 2013 by Mario Vernari, Cet Electronics * Part of "Cet Open Toolbox" (http://cetdevelop.codeplex.com/) * * Licensed under the Apache License, Version 2.0 (the "License"); * you may not use this file except in compliance with the License. * You may obtain a copy of the License at * * http://www.apache.org/licenses/LICENSE-2.0 * * Unless required by applicable law or agreed to in writing, software * distributed under the License is distributed on an "AS IS" BASIS, * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. * See the License for the specific language governing permissions and * limitations under the License. */ namespace Cet.HW.Drivers { /// <summary> /// Driver for a generic HD44780-based character-matrix LCD module. /// It takes advantage of the DMA SPI's buffer-transfer, /// achieving a very good performance /// </summary> /// <remarks> /// See HD44780 specs at: http://www.adafruit.com/datasheets/HD44780.pdf /// For the char-maps see: http://web.alfredstate.edu/weimandn/lcd/lcd_addressing/lcd_addressing_index.html /// </remarks> public sealed class BoostHD44780 : ICompositionRenderer//, IDisposable { //some ready-to-use display configurations public static readonly LayoutConfig Layout16x2 = new LayoutConfig { LogicalSize = 0x0210, PhysicalColumns = 0x10, PhysicalRow0 = 0x00000000, PhysicalRow1 = 0x00000100, }; public static readonly LayoutConfig Layout20x4 = new LayoutConfig { LogicalSize = 0x0414, PhysicalColumns = 0x14, PhysicalRow0 = 0x02000000, PhysicalRow1 = 0x03000100, }; //bit-masks for the control pins of the LCD module private const int LcdEnable = 0x40; private const int LcdRead = 0x20; private const int LcdRegSel = 0x10; //codes defined for the HD44780 interfacing private const int LcdSendCommand = 0x80; private const int LcdSendData = 0x80 | LcdRegSel; private const int LcdSetFunc8 = LcdSendCommand | 0x03; //set DL=8 bit private const int LcdSetFunc4 = LcdSendCommand | 0x02; //set DL=4 bit private const uint LcdSendDataMask = unchecked((uint)(LcdSendData * 0x1010101)) | (LcdEnable * 0x10001); private const uint LcdSendCommandMask = unchecked((uint)(LcdSendCommand * 0x1010101)) | (LcdEnable * 0x10001); //character map's address displacement between rows private const int AddressStep = 0x40; //the SPI's clock frequency in kHz //NOTE: the HD44780 execution time is about 37us (max) //A 600KHz setting allows a decent speed //together with a good reliability private const uint SpiClockRate = 400; //avoid greater /// <summary> /// Create an instance of driver /// </summary> /// <param name="cspin">The output port used for the SS signal</param> public BoostHD44780( Cpu.Pin cspin, LayoutConfig config) { this.Height = config.LogicalSize >> 8; //rows this.Width = (byte)config.LogicalSize; //columns //a "physicalRow" is kinda row that can be written sequentially //to the LCD module, by taking advantage of its auto-increment //that is, a contiguous-address array of characters //each physicalRow is made of one or two "physicalBlocks" //a "physicalColumns" is the size of a physicalBlock this._physicalColumns = config.PhysicalColumns; this._physicalRow0 = config.PhysicalRow0; this._physicalRow1 = config.PhysicalRow1; //this indicates how many visible rows takes a single physicalRow int physicalBlocks = (config.PhysicalRow0 < 0x10000) ? 1 : 2; this._buffer = new byte[config.PhysicalColumns * physicalBlocks * 4 + 4]; //all phy-cells + 1 cmd //defines the first SPI slave device configuration this._spiConfig = new SPI.Configuration( cspin, // SS-pin false, // SS-pin active state 0, // The setup time for the SS port 0, // The hold time for the SS port true, // The idle state of the clock true, // The sampling clock edge (this must be "true" for the 74HC595) SpiClockRate, // The SPI clock rate in KHz (avoid faster speed) SPI_Devices.SPI1 // The used SPI bus (refers to a MOSI MISO and SCLK pinset) ); } private readonly SPI.Configuration _spiConfig; private int _lastHash; //related to the data exchange private readonly byte[] _buffer; private int _bufferIndex = -1; //some physical mapping info about the LCD layout, //such as the rows displacement, interleaving, etc. private readonly int _physicalColumns; private readonly int _physicalRow0; private readonly int _physicalRow1; #if CRONO private OutputPort _test2 = new OutputPort(Pins.GPIO_PIN_D2, false); #endif /// <summary> /// Gets the actual number of rows managed /// for the connected LCD module /// </summary> public readonly int Height; /// <summary> /// Gets the actual number of columns managed /// for the connected LCD module /// </summary> public readonly int Width; /// <summary> /// Init the LCD module /// </summary> private void Init() { /** * According to the HD44780 specs (page 46), the init for * 4-bit interface should be done as follows: * - the chip could be either in the 8-bit mode, or in the 4-bit * depending on the power-on status * - send just a byte, then wait at least 4.1 ms * - send another a byte, then wait at least 100 us * doing so the chip is always under control, regardless its mode * - send one byte, and immediately the byte for the 4-bit mode * - the chip is now working in 4-bit mode **/ this._bufferIndex = 0; this.WriteByte(LcdSetFunc8); this.Send(); //this yields a small pause Thread.Sleep(4); this.WriteByte(LcdSetFunc8); this.Send(); //this yields a small pause Thread.Sleep(1); this.WriteByte(LcdSetFunc8); this.WriteByte(LcdSetFunc4); //at this point the HD44780 is working in 4-bit mode //complete the init WriteCommand(0x28); //set 2 rows (and 4-bit mode again) WriteCommand(0x0C); //turn on the display WriteCommand(0x06); //inc cursor, but don't shift the display WriteCommand(0x02); //return home this.Send(); } /// <summary> /// Defines the pattern for a custom character /// </summary> /// <param name="code">The character code which the pattern is related to</param> /// <param name="pattern">The bit pattern which defines the aspect</param> /// <remarks> /// There are up to 8 codes available for custom characters: /// the codes span from 0 to 7, inclusive. /// Upon the display type, a character can be composed either /// by a 5x8 pixel matrix (most common), or a 5x10 pixel matrix. /// However, the most bottom row is reserved for cursor. /// Also see the HD44780 datasheet /// </remarks> /// <example> /// Suppose you would like to define the following /// 5x7 custom pattern for the code 0x02: /// /// ##### /// # /// # /// ### /// # /// # /// # /// /// Note: each '#' symbol is actually a pixel /// /// The related code to define the pattern will be: /// <code> /// driver.DefineCustomCharacter( /// 0x02, //the address of the character /// new byte[7] { 0x1F, 0x10, 0x10, 0x1C, 0x10, 0x10, 0x10 } /// ); /// </code> /// </example> public void DefineCustomCharacter( int code, byte[] pattern) { //checks for driver initialization if (this._bufferIndex < 0) { this.Init(); } int address = 0x40 + ((code << 3) & 0x38); WriteCommand(address); int count = pattern.Length; if (count > 10) count = 10; for (int i = 0; i < count; i++) WriteData(pattern[i]); this.Send(); } #if false /// <summary> /// Dump the entire local cache to the physical LCD module /// </summary> /// <param name="cache">The logical video-cache to be dumped</param> public void Dump(LcdBoostVideoCache cache) { //physical row #0 (always present) int row = this._physicalRow0; int address = 0x80; WriteCommand(address); this.DumpPhysicalRow( cache, (short)row, (row >> 16)); //physical row #1 if ((row = this._physicalRow1) != 0) { address += AddressStep; WriteCommand(address); this.DumpPhysicalRow( cache, (short)row, (row >> 16)); } } #endif /// <summary> /// Performs a dump of single physical row /// </summary> /// <param name="cache"></param> /// <param name="block0"></param> /// <param name="block1"></param> private void DumpPhysicalRow( byte[][] cache, int block0, int block1 ) { this.DumpPhysicalBlock( cache[block0 >> 8], (byte)block0); if (block1 != 0) { this.DumpPhysicalBlock( cache[block1 >> 8], (byte)block1); } this.Send(); } /// <summary> /// Deploys the data for the dumping of a single physical block /// </summary> /// <param name="vrow"></param> /// <param name="offset"></param> private void DumpPhysicalBlock( byte[] vrow, int offset) { for (int idx = offset, count = this._physicalColumns + offset; idx < count; idx++) this.WriteData(vrow[idx]); } /// <summary> /// Perform the buffer transfer to the LCD module /// </summary> /// <remarks> /// This function resets the buffer index /// </remarks> private void Send() { //open the SPI using the specified configuration, //manage the buffer transfer, finally release the port using (var spi = new SPI(this._spiConfig)) { spi.WriteRead( this._buffer, 0, this._bufferIndex, this._buffer, 0, 0, 0); } //reset buffer index this._bufferIndex = 0; System.Math.Cos(4.5); } /// <summary> /// Compose the bytes-pattern for sending the specified command /// to the LCD module /// </summary> /// <param name="value">The command to be sent</param> private void WriteCommand(int value) { uint magic = LcdSendCommandMask | (uint)(value >> 4) | (uint)((value & 0x0F) << 16); Utility.InsertValueIntoArray( this._buffer, this._bufferIndex, 4, magic); this._bufferIndex += 4; } /// <summary> /// Compose the bytes-pattern for sending the specified data /// to the LCD module /// </summary> /// <param name="value">The data to be sent</param> private void WriteData(int value) { uint magic = LcdSendDataMask | (uint)(value >> 4) | (uint)((value & 0x0F) << 16); Utility.InsertValueIntoArray( this._buffer, this._bufferIndex, 4, magic); this._bufferIndex += 4; } /// <summary> /// Compose the bytes-pattern for latching just a nibble (4 bits) /// to the LCD module (ref to the 74HC595 schematic) /// </summary> /// <param name="data">The encoded nibble to be sent</param> private void WriteByte(int data) { this._buffer[this._bufferIndex + 0] = (byte)(data | LcdEnable); this._buffer[this._bufferIndex + 1] = (byte)data; this._bufferIndex += 2; } #region ICompositionRenderer members CompositionTargetBase ICompositionRenderer.CreateTarget() { return new CompositionTargetHD44780( this.Width, this.Height); } void ICompositionRenderer.Dump(CompositionTargetBase composition) { //checks for driver initialization if (this._bufferIndex < 0) { this.Init(); } //checks whether something in the cache has changed var target = composition as CompositionTargetHD44780; int hash = target.GetCacheHash(); if (hash == this._lastHash) return; else this._lastHash = hash; //physical row #0 (always present) int row = this._physicalRow0; int address = 0x80; WriteCommand(address); this.DumpPhysicalRow( target.GetBuffers(), (short)row, (row >> 16)); //physical row #1 if ((row = this._physicalRow1) != 0) { address += AddressStep; WriteCommand(address); this.DumpPhysicalRow( target.GetBuffers(), (short)row, (row >> 16)); } } #endregion #region Driver config public struct LayoutConfig { public short LogicalSize; public byte PhysicalColumns; public int PhysicalRow0; public int PhysicalRow1; } #endregion } }
Posted 20 October 2015 - 12:00 PM
Sorry for being in late.
The boost library leverages its performance by a hardware trick: you must use it, otherwise the library not only won't help you, but even won't work at all.
The Stefan's library is more intuitive and maybe more straightforward to wire, but you can't get it faster because the interpreted framework. That's because I used a hardware solution as a workaround.
From your photo I realize that you already finalized the hardware. I believe there's no clues for pushing the speed greater...
Posted 20 October 2015 - 11:23 PM
Thanks Again Mario. I thought that might be the case. But thanks for confirming it.
