Netduino Firmware v4.2.0 RC4 (Netduino + Netduino Plus)
#141
Posted 07 May 2012 - 08:40 PM
#142
Posted 07 May 2012 - 09:37 PM
#143
Posted 08 May 2012 - 03:25 PM
it is just 8KBHow big is the application you are trying to deploy?
#144
Posted 08 May 2012 - 04:23 PM
Hello,
I just upgraded my netduino plus to 4.2 RC4 and the MFDeploy says everything is OK, but in VS, i keep getting "An error has occurred: please check your hardware."
i already updated the drivers, so i don't know what is the problem cause it does not give a detalied info about the error.
Please help and thanks.
I got it working now, a reference i added is causing the error, but i don't know why, it worked fine on 4.1.0.6. do you think is about the size or just that the 4.2 doesn't support this reference?
i really want to use that reference, please help and thanks.
#145
Posted 08 May 2012 - 04:24 PM
#146
Posted 08 May 2012 - 04:28 PM
I think I found an issue. Not sure this has been reported. The following code worked in 4.1, but in 4.2 it fails:
double Temperature = 79.78374927437; string formattedTemp = Temperature.ToString().Substring(0,5) + "F"; Debug.Write(formattedTemp);For some reason it seems to think Temperature.ToString() is null however, reworking the code this way works:
double Temperature = 79.78374927437; string formattedTemp = Temperature.ToString(); Debug.Write(formattedTemp.Substring(0,5) + "F");
Is there somewhere that we are supposed to report 4.2 Errors? I had posted this a couple days ago and I think it got lost.
#147
Posted 08 May 2012 - 05:10 PM
The best place for general .NET MF bugs like this is netmf.codeplex.com. That way it can get attention from the Microsoft .NET MF team as well.Is there somewhere that we are supposed to report 4.2 Errors? I had posted this a couple days ago and I think it got lost.
Thank you for the excellent detective work
Posted 08 May 2012 - 05:50 PM
I'll get it up there. Thanks Chris!
#149
Posted 09 May 2012 - 01:36 PM
KodeDaemon.NETMF.systemWhich reference did you add?
It used to work on 4.1.0.6
#150
Posted 09 May 2012 - 02:47 PM
#151
Posted 09 May 2012 - 07:40 PM
Hi not4now,
The math library I wrote was never included in the official firmware releases. I will have to port the library to the 4.2.0 RC4 release for this to work for you.
WOW! Thanks a lot!!!
i greatly appreciate it!!!
Please tell me if you need any kind of help or anything!
#152
Posted 10 May 2012 - 10:02 PM
#153
Posted 10 May 2012 - 10:12 PM
Sweet... Lets see if I can break my Netduino again trying to upgrade.Quick update: the .NET MF 4.2 RC5 firmware is now posted:
http://forums.netdui...-netduino-plus/
