over run?
8 replies to this topic
#1 k_madsen
k_madsen
  • 22 posts
  • LocationEsbjerg Denmark
Posted 30 January 2012 - 08:24 PM
httpserver
this program will show status of the led adress/internal/led but after few second it overrun.
program.cs
using System.Net;
using System.Net.Sockets;
namespace Oz1ldoHttpdServer
        { // write your code here
            Blinkingled blinkingled = new Blinkingled(led);
            Thread workerThread = new Thread(blinkingled.run);
            workerThread.Start();
            Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].EnableDhcp();
            Oz1ldoHttpServer oz1ldohttpserver = new Oz1ldoHttpServer(led);
            oz1ldohttpserver.ListenForRequest();
Oz1ldoHttpdServer.cs
using System.Net;
    class Oz1ldoHttpServer : IDisposable
        protected Socket socket = null;
        //open connection to onbaord led so we can blink it with every request
        protected OutputPort led;
        public Oz1ldoHttpServer(OutputPort ledfrommain)
            //Initialize Socket class
            led = ledfrommain;
            socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
            //Request and bind to an IP from DHCP server
            socket.Bind(new IPEndPoint(IPAddress.Any, 80));
            //Debug print our IP address
            Debug.Print(Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress);
            //Start listen for web requests
            socket.Listen(10);
            ListenForRequest();
        public void ListenForRequest()
                using (Socket clientSocket = socket.Accept())
                    //Get clients IP
                    IPEndPoint clientIP = clientSocket.RemoteEndPoint as IPEndPoint;
                    EndPoint clientEndPoint = clientSocket.RemoteEndPoint;
                    //int byteCount = cSocket.Available;
                    int bytesReceived = clientSocket.Available;
                    if (bytesReceived > 0)
                        Oz1ldoHandleRequest bearbejddetaljerne = new Oz1ldoHandleRequest(clientSocket, clientIP, led);
        #region IDisposable Members
        ~Oz1ldoHttpServer()
            Dispose();
        public void Dispose()
            if (socket != null)
                socket.Close();
        #endregion
Oz1ldoHandleRequest.cs
using System.Net;
using System.Text;
    class Oz1ldoHandleRequest : IDisposable
        OutputPort ledGem;
        public Oz1ldoHandleRequest(Socket clientSocket, IPEndPoint clientIP, OutputPort led)
            ledGem = led;
            byte[] buffer = new byte[bytesReceived];
            int byteCount = clientSocket.Receive(buffer, bytesReceived, SocketFlags.None);
            string request = new string(Encoding.UTF8.GetChars(buffer));
            if(0 == request.ToLower().IndexOf("get /")) {get(request,clientSocket,clientIP);}
        private void get(string request, Socket clientSocket, IPEndPoint clientIP)
            // internal harcoded code get register and so on
            if (5 == request.ToLower().IndexOf("internal/")) { intern(request, clientSocket, clientIP); }
            else
                if (0 == request.ToLower().IndexOf("get / http/1.1"))
                    //empty request send default text
                    string iptxt = clientIP.ToString();
                    Debug.Print(request);
                    string txt1 = "Senders IP Adress -> ";
                    string txt2 = "\r\n";
                    Debug.Print(txt1 + iptxt + txt2);
                    Debug.Print("200 Default text responece\r\n");
                    //Compose a response
                    string response = "Oz1ldo Test Server";
                    string header = "HTTP/1.0 200 OK\r\nContent-Type: text; charset=utf-8\r\nContent-Length: " + response.Length.ToString() + "\r\nConnection: close\r\n\r\n";
                    clientSocket.Send(Encoding.UTF8.GetBytes(header), header.Length, SocketFlags.None);
                    clientSocket.Send(Encoding.UTF8.GetBytes(response), response.Length, SocketFlags.None);
                else
                    // say somthing or get the code from sd card if there is one
                    unknowncmd(request, clientSocket, clientIP);
        private void intern(string request, Socket clientSocket, IPEndPoint clientIP)
            string test = "It is working";
            Debug.Print(test);
            string commando = request.Substring(14);
            if (commando.IndexOf("HTTP") != -1)
                string intcmd = commando.Substring(0, commando.IndexOf("HTTP"));
                switch (intcmd)
                    case "led ":
                         string ledstatus;
                         if (ledGem.Read())
                             ledstatus = " checked=true ";
                         }else
                             ledstatus = "";
                         string response = "<HTML><HEAD><META HTTP-EQUIV=CONTENT-TYPE CONTENT=text/html; charset=windows-1252><meta http-equiv= refresh content=1 /><TITLE>Led Status</TITLE><STYLE TYPE=text/css></STYLE></HEAD><BODY LANG=da-DK DIR=LTR><P ALIGN=CENTER STYLE=margin-bottom: 0cm><form><input type=radio name=diode id=lysdiode" + ledstatus + "/>Diode Status<br /></form></P><P AL1IGN=CENTER STYLE=margin-bottom: 0cm><BR></P></BODY></HTML>";
                         Debug.Print(ledstatus);
                     break;
                    default:
                        unknowncmd( request, clientSocket,  clientIP);
                     break;
            else unknowncmd(request, clientSocket, clientIP);
        private void unknowncmd(string request, Socket clientSocket, IPEndPoint clientIP)
            Debug.Print("404 file not found\r\n");
            string response = "404 File not found";
            string header = "HTTP/1.0 404 ERROR\r\nContent-Type: text; charset=utf-8\r\nContent-Length: " + response.Length.ToString() + "\r\nConnection: close\r\n\r\n";
        ~Oz1ldoHandleRequest()
            Dispose();
        #endregion
#2 Jamie Lewis
Jamie Lewis
  • 29 posts
Posted 30 January 2012 - 08:37 PM
can you clarify what you mean by overrun? If I understand you correctly it is because you need to make it multi threaded, the faster you can get a connection pushed off to its own thread so the main one can open accept the new connection will increase throughput (within memory extents anyway). hth. Jamie.
#3 k_madsen
k_madsen
  • 22 posts
Posted 30 January 2012 - 08:50 PM
hth.
Jamie.
You can get the led status between 2 to 10 times after that you just get error msg as retur.
#4 Jamie Lewis
Jamie Lewis
  • 29 posts
Posted 30 January 2012 - 09:15 PM
Ok well without knowing what error message is returned my best guess would still be that you need to implement multi threading on the accept connection ...
Maybe something like ....
                HttpThread ht = new HttpThread(clientSocket);
                Thread T = new Thread(ht.AcceptConnect)
                T.Start();
class HttpThread {
public Socket client;
HttpThread{Socket cli} {client = cli;}
void AcceptConnect() {
using (Socket clientSocket = socket.Accept()) {
//.... ur code here
This way the servers ready to carry on almost immediately and the thread still utilises Using on the socket so will dispose on when the thread dies.
#5 k_madsen
k_madsen
  • 22 posts
Posted 30 January 2012 - 09:19 PM
Thx I will trye it. to morrow, night time here in denmark -) regards Kim
#6 ErikN
ErikN
  • 119 posts
Posted 30 January 2012 - 10:59 PM
I'm going to have to start a list of Scandinavian users! Of which I'll only be an honorary member.
-Erik
#7 k_madsen
k_madsen
  • 22 posts
Posted 31 January 2012 - 11:03 AM
Hi
I changed Oz1ldoHttpServer.cs and it works 100%
For completeting the discussion I add the new class.
using System.Net;
    class Oz1ldoServerThread
               OutputPort led;
        public Oz1ldoServerThread(Socket cli, OutputPort ledadr)
        {   client = cli;
            led = ledadr;
        public void work()
            Debug.Print("Ny server thread \r\n");
                //Get clients IP
                IPEndPoint clientIP = client.RemoteEndPoint as IPEndPoint;
                EndPoint clientEndPoint = client.RemoteEndPoint;
                int bytesReceived = client.Available;
                    Oz1ldoHandleRequest bearbejddetaljerne = new Oz1ldoHandleRequest(client, clientIP, led);
            led = ledfrommain;
            socket.Listen(10);
            ListenForRequest();
                Socket clientSocket = socket.Accept();
                Oz1ldoServerThread thread = new Oz1ldoServerThread(clientSocket, led);
                Thread T = new Thread(thread.work);
                T.Start();
        ~Oz1ldoHttpServer()
            Dispose();
            if (socket != null)
                socket.Close();
        #endregion
#8 Jamie Lewis
Jamie Lewis
  • 29 posts
Posted 31 January 2012 - 01:16 PM
great stuff, glad i could help!
#9 k_madsen
k_madsen
  • 22 posts
Posted 08 February 2012 - 11:35 AM
To get the http server running without memory leaks
there is a change to Oz1ldoHttpServer.cs
using System.Net;
               OutputPort led;
        {   client = cli;
            led = ledadr;
        public void work()
                //Debug.Print("Ny server thread \r\n");
                //Get clients IP
                    try { Oz1ldoHandleRequest bearbejddetaljerne = new Oz1ldoHandleRequest(client, clientIP, led); }
                    catch (System.Exception e)
                        Debug.Print(e.Message+"\r\n");
                else
                    Debug.Print("Empty connection \r\n");
                    client.Close();
            led = ledfrommain;
            socket.Listen(6);
            ListenForRequest();
                try
                    try
                        T.Start();
                        Debug.Print(e.Message + "\r\n");
                catch (System.Net.Sockets.SocketException e)
        ~Oz1ldoHttpServer()
            Dispose();
            if (socket != null)
                socket.Close();
        #endregion
