I got myself a Netduino and have been having a good bit of fun with it. Since robots are so 21st century I wanted to build one.
The kids over at Pololu had a Tamiya 70168 and a SMC05A Dual Serial Motor Controller on sale.
The controller is discontinued, but for what it's worth here is a driver I wrote for it.
/// <summary>
/// This class is intended to allow a Netduino to drive a
/// Pololu Low-Voltage Dual Serial Motor Controller (DSMC) Pololu item #: 120 (SMC05A)
/// This class requires a reference to Microsoft.SPOT.Hardware.SerialPort as part of the project
/// </summary>
/// <remarks>
/// The SMC50A holds state. When a motor is given a direction and speed the settings hold
/// until it recieves another set of parameters.
/// </remarks>
using System.IO.Ports;
using System.Text;
namespace MotorTest
class DualSerialMotorController
/// <summary>
/// The four-byte motor controller command
/// byte 1: Start Byte - Always 0x80 (128) to signify the beginning of a command
/// byte 2: Device Type - This should always be 0x00 for commands sent to the SMC05a
/// byte 3: Motor and Direction - This byte has three parts
/// bit 0 - Specifies the direction of the motor 1 = forward, 0 = backwards
/// bits 1 - 6 - Specifies the motor number. All motors respond to 0 and 1 if in dual-motor mode
/// bit 7 - Must always be 0
/// To calculate byte 3 (motor number x 2) + ( zero for forward or one for reverse)
/// byte 4: Motor Speed - The most significant bit (MSB) must always be 0. Range 0x00 - 0x7F
/// 0x00 = STOP
/// 0x7F = Full Speed
/// </summary>
SerialPort serialPort;
static byte[] stopMotor0 = new byte[4] { 0x80, 0, 0x00, 0 }; // Stop Motor Zero
static byte[] stopMotor1 = new byte[4] { 0x80, 0, 0x02, 0 }; // Stop Motor One
static byte[] forwardMotor0 = new byte[4] { 0x80, 0, 0x00, 0 }; // Forward speed passed by caller
static byte[] forwardMotor1 = new byte[4] { 0x80, 0, 0x02, 0 }; // Forward speed passed by caller
static byte[] reverseMotor0 = new byte[4] { 0x80, 0, 0x01, 0 }; // Reverse speed passed by caller
static byte[] reverseMotor1 = new byte[4] { 0x80, 0, 0x03, 0 }; // Reverse speed passed by caller
public DualSerialMotorController(string portName = SerialPorts.COM1, int baudRate = 9600, Parity parity = Parity.None, int dataBits = 8, StopBits stopBits = StopBits.One)
serialPort = new SerialPort(portName, baudRate);
serialPort.Open();
// Motor Zero forward
public void Forward0(int speed)
forwardMotor0[3] = (byte)speed;
serialPort.Write(forwardMotor0, 0, 4);
// Motor One forward
public void Forward1(int speed)
forwardMotor1[3] = (byte)speed;
serialPort.Write(forwardMotor1, 0, 4);
// Motor Zero and One forward
public void ForwardAll(int speed)
// Motor Zero backward
public void Reverse0(int speed)
reverseMotor0[3] = (byte)speed;
serialPort.Write(reverseMotor0, 0, 4);
// Motor One backward
public void Reverse1(int speed)
reverseMotor1[3] = (byte)speed;
serialPort.Write(reverseMotor1, 0, 4);
// Motor Zero and One backward
public void ReverseAll(int speed)
// Motor Zero forward and One backward
public void SpinLeft(int speed)
// Motor Zero backward and One forward
public void SpinRight(int speed)
// Stop both motors
public void Stop()
serialPort.Write(stopMotor0, 0, 4);
serialPort.Write(stopMotor1, 0, 4);
All my little bot does now is run a little test pattern when you turn him on.
namespace MotorTest
Thread.Sleep(500);
DualSerialMotorController dsmc = new DualSerialMotorController();
led.Write(true); // turn on the LED
dsmc.ForwardAll(127); // Tell the controller to spin motor Zero forward and motor One forward
Thread.Sleep(1000);
dsmc.Stop(); // All stop
dsmc.ReverseAll(127); // Tell the controller to spin motor Zero backward and motor One backward
Thread.Sleep(1000);
dsmc.SpinLeft(127); // Tell the controller to spin the robot left
Thread.Sleep(1000);
dsmc.SpinRight(127); // Tell the controller to spin the robot left
Thread.Sleep(1000);
led.Write(false); // turn off the LED
If I'm going to let him out of my office I'd better figure out a way to make him "see".
PenZenMaster
