Netduino Plus... disenchantment is the word
Posted 29 November 2011 - 11:06 PM
Posted 30 November 2011 - 10:59 AM
Posted 30 November 2011 - 12:58 PM
I have heard that netduino struggles on busy networks could this be the problem?
This is the cause of a number of the intermittent issues.
Posted 30 November 2011 - 04:36 PM
Posted 01 December 2011 - 06:59 AM
Posted 03 December 2011 - 02:03 AM
Posted 14 December 2011 - 05:44 AM
If it doesn't function on a network why put a NIC on it? If you wanted to do device to device comms point-to-point TCP would seem like a very heavy way to do it.
I have a seperate switch already.
i have a switch with my workstation and the netduino plus plugged in - the rest of the network is on another segment and simply uplinked into my desk switch.
I have tried many different simple approaches. I am now simply trying to make a socket connection to an IP on a port with a static IP address. DHCP doesn't work, DNS doesn't work.
i'm getting the following:
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (3) #### #### Message: #### Microsoft.SPOT.Net.SocketNative::connect [IP: 0000] #### #### System.Net.Sockets.Socket::Connect [IP: 001d] #### #### MoodMonitor.HumanInterface.WebService.HttpRequest::GetResponse [IP: 00e0] #### #### BMF.MoodMonitor.HumanInterface.Services.MoodMonitorService::TransmitMoodUpdate [IP: 004f] #### #### BMF.MoodMonitor.HumanInterface.Services.MoodMonitorService::SendMoodUpdate [IP: 000c] #### #### MoodMonitor.HumanInterface.Program::button1_OnInterrupt [IP: 0021] #### #### SocketException ErrorCode = 10053 #### SocketException ErrorCode = 10053 A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll #### SocketException ErrorCode = 10053 #### SocketException ErrorCode = 10053
Again, i'm seriously starting to think that for anything network related this product simply isn't ready.
Would love a hand, but i get the feeling
Posted 14 December 2011 - 06:09 AM
when i connect using MFDEPLOY i get the following:
DM9161_AutoNegotiate Valid PHY Found: 31 PHY: Vendor Number Model = 0xA PHY: Model Revision Number = 0x0 DM9161_DSCSR = 0xF3F6 DM9161_BMCR = 0x3100 DM9161_DSCR = 0x414 Error: AutoNegotiate TimeOut
This happens with DHCP on AND off with static address...
i have tried different ports on the switch, plugged into another switch. a switch that is off the network and on the network
thoughts?
Posted 14 December 2011 - 07:59 AM
Posted 15 December 2011 - 10:08 PM
Hi Doug Rathbone,
Appairently it can't auto detect it's settings (10/100Mbps, half/full duplex, etc.). Do you connect your Netduino with a switch or directly into the router? Could you please try a different switch? If you're switch is managed, can you modify the outlet settings and set it to 100Mbps full duplex?
Thanks so much for your help... after shifting a custom made HttpRequest to the built in HttpWebRequest, and using my newly purchased switch all seems fine.
THANK YOU FOR PUTTING UP WITH MY FRUSTRATION... lol
Do you think the NIC support will get better?
Posted 16 December 2011 - 11:56 AM
I'm glad I could help. I know the feeling of a purchase feeling a dissapointment and the Netduino Plus should never be one in my humble opinionTHANK YOU FOR PUTTING UP WITH MY FRUSTRATION... lol
The firmware still gets a lot of improvements, so I surely hope so!Do you think the NIC support will get better?
Posted 18 January 2012 - 09:05 AM
