Use Pins Enum in clas constructor
5 replies to this topic
#1 JR.NET
JR.NET
  • 15 posts
Posted 02 November 2011 - 08:24 PM
Hello,
I would like to set certain pins in my class constructor. I've tried the following but without any luck:
        PWM PWMpinENA;
        InputPort DirectionPinIN1;
        InputPort DirectionPinIN2;
        SecretLabs.NETMF.Hardware.AnalogInput ReadmAPin;
        InterruptPort RPMpin;
        public MotorControl(Pins pwmpin, Pins Direction1, Pins Direction2, Pins mapin, Pins rpmpin)
            PWMpinENA = new PWM(pwmpin);
            DirectionPinIN1 = new InputPort(Direction1, true, ResistorModes.PullUp);
            DirectionPinIN2 = new InputPort(Direction2, true, ResistorModes.PullUp);
            ReadmAPin = new SecretLabs.NETMF.Hardware.AnalogInput(mapin);
            RPMpin = new InterruptPort(rpmpin, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLevelHigh);
            RPMpin.OnInterrupt += new NativeEventHandler(RPMpin_OnInterrupt);
The class initiation would be:
MotorControl MotorLeft = new MotorControl(Pins.GPIO_PIN_D6, Pins.GPIO_PIN_D9, Pins.GPIO_PIN_D5, Pins.GPIO_PIN_A1, Pins.GPIO_PIN_D10);
However this is not correct. Can anyone point me in the right direction?
Thanks in advance.
#2 Stefan
Stefan
    Moderator
  • 1961 posts
Posted 02 November 2011 - 08:38 PM
Strange, that should work. I've done the same here:
http://netmftoolbox....iew/8751#134105
Which 'using' lines do you have? The Pins enumeration requires SecretLabs.NETMF.Hardware.
#3 CW2
  • 1392 posts
Posted 02 November 2011 - 08:43 PM
The type of Pins enumeration values is actually Cpu.Pin, so you'd need to change constructor prototype like the following:
public MotorControl(Cpu.Pin pwmpin, Cpu.Pin direction1, Cpu.Pin direction2, Cpu.Pin mapin, Cpu.Pin rpmpin)
#4 Stefan
Stefan
    Moderator
  • 1961 posts
Posted 02 November 2011 - 08:51 PM
Oh true, missed that! :o
#5 JR.NET
JR.NET
  • 15 posts
Posted 02 November 2011 - 09:01 PM
Thanks (and to Stefan: Dank je!!)
I am writing (yet another probably) a motor driver that can also maintain a certain RPM (using an encoder) instead of only PWM values.
I am building a (quite big) tank (with massive DIY tracks) that use two motors to drive it. With an earlier version that only used PWM I has speed sync issues.
Cheers.
#6 Stefan
Stefan
    Moderator
  • 1961 posts
Posted 02 November 2011 - 09:13 PM
Yep, you're correct :D I recognise your code and have written something simular once myself. But it's very educating writing code. Helps you understand the device. :)
