Directions to use Cellular Shield with SM5100B
Posted 27 October 2011 - 10:02 PM
Posted 28 October 2011 - 12:00 PM
Posted 29 October 2011 - 11:12 AM
Hello Dan and welcome to the forum.
The SM5100B (as long as most GSM/GPRS modules) are modems, fully Hayes compatible.
So, you don't need anything else that connect the RXD/TXD lines from your Netduino to the shield, taking care that RXD-->TXD and vice-versa.
Afterward, you may write a very basic C# program that opens the COM1, and sends an AT-command like this one:
ATV1E0
terminated by CR (=carriage return).
If you are not in a hurry, I may post a brief snipped showing ho to configure the UART.
Thank you very much Mario for the help, after a while studying micro .Net i realize that I will need study a little (or lot) about electronics ... If you can give me some directions (websites, articles, anything) on how I can get started with the basics of eletronic, will be great. Thanks again.
Posted 29 November 2011 - 11:53 PM
Hi Dan,
Check out http://www.electroni...NICS/cindex.htm
Thanks a lot for the link and sorry for the late thanks.
Posted 01 December 2011 - 06:28 PM
I have used an old Siemens TC35 GSM module, which is targeted for industrial application. It is old, but still good.
My module has a RS232 connection, thus I must added a level converter, using a very common MAX232.
For the schematic, see Fig.5, Page 17.
To make a basic test, you may wire just the RXD and the TXD.
Attached, you'll find a small program that posts a basic AT command to the modem, then dumps the answer as hex string.
NOTE: at the moment I haven't still the circuit ready to test, thus the program *MAY* not fully work.
Hope it helps.
Posted 01 December 2011 - 06:31 PM
Hello Dan, and my apologies again for being so in late.
Hope it helps.
Thanks a lot Mario, i will analyze your attachment and make a try. Thanks.
