Newb question, RS232 or TTL
12 replies to this topic
#1 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 26 October 2011 - 08:27 PM
Hi, it's me, supernewbie ! ;) I'm playing with my mini atm, and I decided to use TTL to debug and deploy. This works great, but I was hoping I could use pins 1 to 3 in my code as GPIO while deploying over TTL. Appairently this is not the case. Am I wrong, am I doing something wrong, please explain :)
#2 Mario Vernari
Posted 27 October 2011 - 03:56 AM
Sorry, but...I suppose that "atm" stands for Netduino mini, and "TTL" for UART at TTL-level... If so, I don't mean the point at all...
#3 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 27 October 2011 - 05:39 AM
I think that pins 1-3 are reserved for RS232 only. You can switch to deploying/debugging over RS232 and this will free up pins 11 & 12.
ATM = At The Moment
Hope tis helps,
#4 Chris Walker
Posted 27 October 2011 - 05:46 AM
Advanced topic :) Actually, you can use pins 1-3 as GPIO (for pin 3, input only) if you use TTL for deploy/debug. However, they will be -5V/5V+ outputs (from the TTL-RS232 chip), not 0/3V3 outputs. And you'll need to reference them using (Cpu.Pin) casting, pulling their pin #s from the Netduino Mini schematic. Chris
#5 Nevyn
Nevyn
  • 1072 posts
Posted 27 October 2011 - 05:55 AM
Ooooooo - now I can see that being really handy to have access to.
#6 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 27 October 2011 - 06:27 AM
Advanced topic :)
Ahhh, so it's actually not such a newb-question :D
I was thinking, when using TTL for deployment, I only use 2 pins instead of 3, so it saves 1 pin. Also, my laptop has no serial port and I have a TTL-to-USB-breakout.
The -5V to +5V could be interesting to play with, just as the input port. But not for my current project.
From http://www.netduino....i/schematic.pdf:
DRXD -> PA27
DTXD -> PA28
DTR -> PA29
Am I correct that they're (cpu.pin)27 to (cpu.pin)29 ?
#7 Chris Walker
Posted 27 October 2011 - 06:50 AM
Precisely!
Also, be careful when using pin 29. The "DTR" pin -- (Cpu.Pin)29 -- is checked during boot. If it's active, then your Netduino Mini will go into bootloader mode :) It's available for your use in code...but only as an advanced hack ;)
BTW, you might notice that you can't create an OutputPort with that pin. .NET MF automatically protects you :)
#8 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 27 October 2011 - 07:44 AM
Cool! Going to play with it some day, for my current project, I stay at RS232-deployment then. I want to keep as many pins available as possible.
#9 cys
cys
  • 113 posts
  • LocationSoCal
Posted 23 July 2012 - 04:04 AM
I know this is an old thread, but has anyone played with pins 1-3 [(cpu.pin)27 to (cpu.pin)29] for anything other than RS232 deployment?
#10 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 July 2012 - 08:24 AM
I've considered it, but because it outputs -5V to +5V (if I'm correct) I didn't found a good use for it. It is possible though, to drive them that way!
#11 cys
cys
  • 113 posts
  • LocationSoCal
Posted 23 July 2012 - 07:48 PM
I was hoping someone might have come up with an application for the +/-5V. I guess I'm going to try incorporating a sub-circuit on my pcb that converts rs232 to ttl.
#12 cys
cys
  • 113 posts
  • LocationSoCal
Posted 20 September 2012 - 03:07 AM
I'm working on using pins 1 and 2. I need one more pin for my project.
If I create an output port as: OutputPort _output = new OutputPort((Cpu.Pin)27, false); or OutputPort _output = new OutputPort((Cpu.Pin)27, true);, a DVM shows that nothing changes on pin 1 or pin 2. DRXD is shown on the schematic as "G3 PA27/PGMD15."
If PA27/DRXD is (Cpu.Pin)27, then what would then be the (Cpu.Pin) identity of PB27/ADO D9?
[Note added: Per a recent thread, PA references PIO controller A multiplexing and PB controller B multiplexing -- pages 31-33 of the ARM document.]
#13 cys
cys
  • 113 posts
  • LocationSoCal
Posted 20 September 2012 - 03:20 AM
In case anyone is interested, my mini project is a scuba diving computer that tracks decompression obligation, and controls a rebreather solenoid based on voting logic input from three oxygen sensors. I need one more pin to control the spi bus to use a flash memory chip (I understand that the new firmware will give access to flash, but I don't want to change firmware yet). Chris
