Hardware Classes For Netduino
Posted 25 October 2011 - 04:17 PM
Posted 26 October 2011 - 01:07 AM
Posted 26 October 2011 - 03:22 AM
To go further I think I need the listing and description of the classes in "using..."
Hey, Vinh,
First, let me recommend the book Getting Started with the Internet of Things by Cuno Pfister. Check out this site's Download page for sample chapters. This book is perfect for learning about the power of NetduinoPlus (it requires Plus for networking).
Second, our very own Chris Walker is publishing a book any day now...
Hey, Chris. Wasn't your book due out 3 days ago?
...called Getting Started with Netduino. THAT should be another good resource.Finally, I agree. There seems to be an API or users manually missing. .NETMF provides most of the documentation, but Netduino is a scaled DOWN version of .NETMF. (Which is serious, since .NETMF is already a miracle of miniaturization - it has "micro" in its name for a reason. Perhaps Netduino has created the .NET Nano Framework or Pico Framework?) Regardless, there should be comprehensive documentation on the differences between .NETMF and Netduino's "Port" of .NETMF because the differences are significant. Maybe the community will provide this before Secret Labs does.
Welcome to the forum.
Posted 27 October 2011 - 03:45 AM
Posted 29 October 2011 - 01:07 PM
Posted 29 October 2011 - 04:43 PM
Posted 01 November 2011 - 12:11 PM
Posted 03 November 2011 - 01:45 PM
Hi Vinh,
What version of the Netduino firmware are you running on your board? Which Netduino (Netduino, Netduino Plus, or Netduino Mini)?
Hi Chris
I am using simple NETDUINO. Below is firmware info.
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Netduino by Secret Labs LLC
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.0.6
SolutionReleaseInfo.solutionVendorInfo: Netduino by Secret Labs LLC
SoftwareVersion.BuildDate: Feb 14 2011
SoftwareVersion.CompilerVersion: 400902
Regards
Posted 03 November 2011 - 03:02 PM
Posted 04 November 2011 - 02:03 AM
Hi Vinh,
For some odd reason, Visual Studio seems to be wanting to debug into the source code. If you want to create that folder and drop the source (from the downloads page) into it, or ask Visual Studio to ignore its request to debug...you should be good to go.
Were you trying to step into the behind-the-scenes managed code?
Hi Chris
I am not that knowledgeable to step into the behind-the-scenes managed code.
I copy the source files into that directory and I have this response:
Locating source for 'C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs'. Checksum: MD5 {5d 7 45 ef 1c c7 cd 32 65 20 c a0 5 7c 1a 6b}
The file 'C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs' exists.
Looking in script documents for 'C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs'...
Determining whether the checksum matches for the following locations:
1: C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs Checksum: MD5 {55 b6 55 e 46 5 5d 41 11 69 56 40 2f e8 7 16} Checksum doesn't match.
Looking in the projects for 'C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs'.
The file was not found in a project.
Looking in directory 'C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\vc7\atlmfc'...
Looking in directory 'C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\vc7\crt'...
The debug source files settings for the active solution indicate that the debugger will not ask the user to find the file: C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs.
The debugger could not locate the source file 'C:\Documents\Secret Labs\Projects\Production\SecretLabs.NETMF.Hardware\PWM.cs'.
Vinh
Posted 04 November 2011 - 02:17 AM
