Script stops running after board is disconnected from computer
10 replies to this topic
#1 haxburgen
haxburgen
  • 21 posts
Posted 23 October 2011 - 02:31 PM
Hi All,
My script runs fine when I have my Netduino Plus plugged in and being debugged. But when I removed it from my computer and try to run the script independent of debugging, it stops running. I am using the board as a Web Client running on a continuous loop. I don't believe its code related but here is my code.
using System.IO;
using System.Net;
using System.Net.Sockets;
namespace myProgram
            WebCall webCall = new WebCall();
            TimerCallback timerDelegate = new TimerCallback(webCall.GetResponse);
            AutoResetEvent autoEvent = new AutoResetEvent(false);
            Timer programLoop = new Timer(timerDelegate, autoEvent, 1000, 60000);
            while (programLoop != null)
    public class WebCall
        OutputPort controlPort = new OutputPort(Pins.GPIO_PIN_D8, false);
        // produce request
        String requestUri = "http://www.mysite.com/somecall.php?ID=1";
        public void GetResponse(Object stateInfo)
            try
                using (var request = (HttpWebRequest)WebRequest.Create(requestUri))
                    request.Method = "GET";
                    // headers
                    request.ContentType = "application/x-www-form-urlencoded";
                    try
                        using (var response = (HttpWebResponse)request.GetResponse())
                            StreamReader reader = new StreamReader(response.GetResponseStream());
                            String returnString = reader.ReadToEnd();
                            if (returnString.Length > 0)
                                String[] array1 = returnString.Split(new Char[] { ',' });
                                for (int l = 0; l < array1.Length - 1; l++)
                                    String[] array2 = array1[l].Split(new Char[] { '-' });
                                    if (array2[1].Equals("0"))
                                        controlPort.Write(false);
                                    else
                                        controlPort.Write(true);
                    catch (WebException ex)
                        Debug.Print(ex.Message);
            catch (IOException ex)
#2 Stefan W.
Stefan W.
  • 153 posts
Posted 23 October 2011 - 04:34 PM
With "stops running", you mean it stops sending requests, or it stops execution completely? Did you try pulsing the onboard LED in another thread to see if execution completely stops, or just the web part? Also, to check if it's connected to debugging, you could just "deploy" it from VS and then reset the board, without starting the debugger ...
#3 haxburgen
haxburgen
  • 21 posts
Posted 23 October 2011 - 06:11 PM
Thanks for the reply Stefan. I have never worked with threading before, other than the main thread. How would I go about blinking the led on another thread? Thanks!
#4 CW2
Posted 23 October 2011 - 06:57 PM
It is only a wild guess, but could you try making programLoop a class member:
  private static Timer programLoop;
#5 haxburgen
haxburgen
  • 21 posts
Posted 24 October 2011 - 01:33 AM
Thanks CW2. That worked. I don't know why that made a difference though.
#6 Chris Walker
Posted 24 October 2011 - 01:46 AM
Thanks CW2.
You may want to try one of those changes (make the variable static) and then the other (just go to sleep forever) to identify which issue tweak fixed the issue. My guess is that the loop was exiting (also, the loop was just taking up a whole bunch of CPU cycles...going to sleep in the main thread is a better solution overall).
#7 haxburgen
haxburgen
  • 21 posts
Posted 24 October 2011 - 01:59 AM
I actually want to take that back my previous post. The web response seems to happen the first time after I pull the USB out of my computer. (I guess because its in the middle of the timer call?) After that its no good.
#8 Stefan W.
Stefan W.
  • 153 posts
Posted 24 October 2011 - 04:34 PM
Regarding the LED (stolen from http://nerduino.wordpress.com/)
  private static Thread flasher;
    flasher = new Thread(delegate(){ doFlash(); });
  public static void doFlash()
 OutputPort led = new OutputPort(Pins.GPIO_PIN_D13, false);
 led.Write(true);
 Thread.Sleep(250);
 led.Write(false);
 Thread.Sleep(250);
#9 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 24 October 2011 - 08:17 PM
 led.Write(true);
 Thread.Sleep(250);
 led.Write(false);
 Thread.Sleep(250);
I've taken to flashing the LED "on demand" as I find the constantly flashing LED can be distracting. I've done this by hooking into the on board button event handler and flash the LED when it's pushed. It has several advantages:
- It does not consume CPU time from the application when it's not needed
- It still allows to to detect if the board and app are still alive even if only in some limited form
- No flashing LED when it's not needed
- Can leave in production code if necessary as it does not consume any power when not used
#10 haxburgen
haxburgen
  • 21 posts
Posted 25 October 2011 - 06:22 AM
I figured out that execution stopss at the point at which I get the http response.
#11 haxburgen
haxburgen
  • 21 posts
Posted 01 November 2011 - 05:08 PM
UPDATE: After removing the 9V barrel connector I had to the netduino and connecting the Micro USB to an iPhone outlet, I can now successfully run my program independent from the computer. Thanks Chris!
