Hi all,
I am trying to read the WHO_AM_I register from my ITG-3200 (Sparkfun breakout board: http://www.sparkfun.com/products/9801). I couldn't get this to work with 4.1.0.6 so I performed the required upgrade steps to get to 4.2:
- Netduino Plus
- .NET MF SDK 4.2 RTM
- Netduino SDK 4.2.0 June 11 Beta
- Updated tinybooterloader and firmware (4.2 RC3)
Now I'm trying with the following code:
var gyroscope = new I2CDevice(new I2CDevice.Configuration(0x69, 400));
var readBuffer = new byte[1];
var actions = new I2CDevice.I2CTransaction[] {
I2CDevice.CreateWriteTransaction(new byte[] { 0x00 }),
CreateReadTransaction(readBuffer, 0x00, 1)
var result = gyroscope.Execute(actions, 1000);
Where CreateReadTransaction is the method posted here: http://forums.netdui...rt-bit-support/
0x00 is the WHO_AM_I register address.
Previously (with 4.1.0.6), gyroscope.Execute(actions, 1000) would return 1, I'm assuming that the read action failed since the buffer remained zeroed.
With the new firmware, gyroscope.Execute(actions, 1000) returns 0 (implying that neither action is successful?).
Does anyone have any ideas?
thanks
The ITG-3200 datasheet is here:
http://invensense.co...200-00-01.4.pdf
ITG-3200 Repeated Start Bit
Started by spcboog, Oct 22 2011 10:01 PM
Posted 22 October 2011 - 10:01 PM
Posted 26 October 2011 - 10:04 AM
Sorry folks, I didn't have pullups, added 2 4k7's and the read works now. I had mistakenly thought that the sparkfun breakout board already had pullups included but there are just spots for you to add them yourself. I got a BlinkM to see if I could get anything I2C to work at all and when I couldn't get that to work either (also due to me thinking the pullups were already included), I read this: http://forums.netdui...__fromsearch__1 which pointed to the missing pullups.
Posted 09 October 2012 - 10:46 AM
I got this to work too, thanks to this forum entry and a host of other, unremembered, entries. I used 10k pull up resistors.
My horrible but work-in-progress, code.
Jack
using System; using System.Reflection; using System.Net; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoPlus; namespace NPlus_IT3200 { public class Program { //create a empty i2c device object static I2CDevice myI2C = new I2CDevice(new I2CDevice.Configuration(0, 0)); public static void Main() { int r; while (true) { r = (int)read_gyro_state(); //read value from gyro Debug.Print("R = " + r.ToString()); Thread.Sleep(1000); } } I2CDevice.I2CWriteTransaction CreateWriteTransaction(byte[] buffer, uint internalAddress, byte internalAddressSize) { I2CDevice.I2CWriteTransaction writeTransaction = I2CDevice.CreateWriteTransaction(buffer); Type writeTransactionType = typeof(I2CDevice.I2CWriteTransaction); FieldInfo fieldInfo = writeTransactionType.GetField("Custom_InternalAddress", BindingFlags.NonPublic | BindingFlags.Instance); fieldInfo.SetValue(writeTransaction, internalAddress); fieldInfo = writeTransactionType.GetField("Custom_InternalAddressSize", BindingFlags.NonPublic | BindingFlags.Instance); fieldInfo.SetValue(writeTransaction, internalAddressSize); return writeTransaction; } I2CDevice.I2CReadTransaction CreateReadTransaction(byte[] buffer, uint internalAddress, byte internalAddressSize) { I2CDevice.I2CReadTransaction readTransaction = I2CDevice.CreateReadTransaction(buffer); Type readTransactionType = typeof(I2CDevice.I2CReadTransaction); FieldInfo fieldInfo = readTransactionType.GetField("Custom_InternalAddress", BindingFlags.NonPublic | BindingFlags.Instance); fieldInfo.SetValue(readTransaction, internalAddress); fieldInfo = readTransactionType.GetField("Custom_InternalAddressSize", BindingFlags.NonPublic | BindingFlags.Instance); fieldInfo.SetValue(readTransaction, internalAddressSize); return readTransaction; } //Function to read value from ITG3200 gyro //16-bit value over two registers public static double read_gyro_state() { byte[] WHO_AM_I = new byte [] {0x00}; byte[] SMPLRT_DIV = new byte[] { 0x15 }; byte[] DLPF_FS = new byte[] { 0x16 }; byte[] GYRO_XOUT_H = new byte[] { 0x1D }; byte[] GYRO_XOUT_L = new byte[] { 0x1E }; byte[] GYRO_YOUT_H = new byte[] { 0x1F }; byte[] GYRO_YOUT_L = new byte[] { 0x20 }; byte[] GYRO_ZOUT_H = new byte[] { 0x21 }; byte[] GYRO_ZOUT_L = new byte[] { 0x22 }; byte[] readBuffer = new byte[1]; int val = 0; double readX = 0, readY = 0, readZ = 0; myI2C.Config = new I2CDevice.Configuration(0x69, 400); //Set i2c device configuration readX = ReadGyroAxis(GYRO_XOUT_H, GYRO_XOUT_L, readBuffer, val); readY = ReadGyroAxis(GYRO_YOUT_H, GYRO_YOUT_L, readBuffer, val); readZ = ReadGyroAxis(GYRO_ZOUT_H, GYRO_ZOUT_L, readBuffer, val); return readX; } private static int ReadGyroAxis(byte[] GYRO_XOUT_H, byte[] GYRO_XOUT_L, byte[] readBuffer, int val) { myI2C.Execute(new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(GYRO_XOUT_H) , I2CDevice.CreateReadTransaction(readBuffer) }, 5000); val = (sbyte)readBuffer[0] << 8; //bit shift first resiter value myI2C.Execute(new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(GYRO_XOUT_L) , I2CDevice.CreateReadTransaction(readBuffer) }, 5000); val = val | readBuffer[0]; //combined with second register value return (int) (val / 14.735); //apply scaling and return } } }
Jack
