Powering SM5100 with ND+
#1 Miha
Miha
  • 94 posts
Posted 20 October 2011 - 11:46 AM
Hi! I'm using SM5100D 3.3V shield with netduino. I am not using it directly on top of netduino, but it is connected via wires. ND+ is powered with 9V via connector. If I connect ND+ 5V pin to 5V pin on a cellular shield, it does not work (I get just some gibberish on a serial interface). But if I connect 5V pin from ND+ to VIN pin on cellular shield, the shield starts working. This is somewhat unexpected, since if I put it on top of ND+, VIN from ND+ would become VIN on cellular shield, and that does not work, since VIN is much higher than 5V (9+ V in my case) and I tried that as well, and it does not work. I was afraid for a second that I might have damaged the cellular shield, but it is still working. What am I doing wrong? Regards, Miha.
#2 Stefan W.
Stefan W.
  • 153 posts
Posted 20 October 2011 - 03:34 PM
The Vin pin on the shield goes to a voltage regulator, that outputs ~3.8V, while the 5V and 3.3V pins are not connected on the shield. So you *have* to power it via vin. It's a low-drop regulator, so it's normal that it works with 5V (as Vin would be 5V also when the (net/ar)duino are powered via usb. However, it should also work fine if you connect +9V to it ... http://www.sparkfun.... shield-v12.pdf shows you which pins are connected (top right of the schematics).
#3 Mario Vernari
Posted 20 October 2011 - 06:00 PM
Nothing related to the problem itself, but if is involving the Netduino Plus it's better to file the thread under the proper category. Cheers
#4 Miha
Miha
  • 94 posts
Posted 20 October 2011 - 08:10 PM
Thank you for the explanation.
Cool. I found out that I needed to connect rx/tx to pins 2 and 3 by trying, as I didnt understand this schematic. I don't have any jumpers on the board that I could move around... and I didn't really understand the UART positioning. Can you explain the UART part to me please, so I can understand it (hopefully) in the future schematics? Thanks.
Edit: on second thought, while reexamining the schematic and the breakout board, I guess the jumpers are "things" that looke like small SMD stuff near D pins? And by removing solder and applying it differently, I can change which RX/TX is the real RX/TX... Not important for me really, but I think I understand. It is just that I expected a jumper to be similar to a jumper seen in 286 and 386 computers, where you had pins sticking out, and you put this plastic cap on top of two pins... :)) (
Re: Mario: I know, but I figured this part is probably the same, and since ND forum is a bit more frequent that ND+ forum, I hoped to get a faster answer here :). Thanks for the heads up, though.
Miha.
