SPI, Netduino, and RGB LED Strip
63 replies to this topic
#61 sky
sky
  • 6 posts
  • LocationMoscow, Russia
Posted 09 December 2011 - 02:01 PM
The level converter fits perfectly.
However, about the MOSI is correct to wire it to TX1, but you must do the same thing with SCLK to TX2.
Your circuit uses only two outputs coming from Netduino: why do you need the RX?
Please, also note that such a converter is made by pull-up resistors, thus its speed won't be so much. At this point I'd try to get the SPI rate even slower than 1MHz, try to set at 100KHz.
Very interesting. Perhaps i'm going to solve the similar problem. In the near future I'll have to try to connect Netduino and digital led strip via SPI. The led strip is WS2801-powered and has a 5V level logic, but Netduino has a 3.3V. There is a strong requirement to the project to have a very fast SPI communication (one-way; only send data). So, what converter is the best suitable for this case?
#62 ryanhl
ryanhl
Posted 11 July 2012 - 08:10 AM
I got my WS2801 strip and Netduino Mini last week. I found that CLK is never low for 500us or more ( except when intended to start the first bit ) it seems it would be possible to output each bit at a snail's pace so even 4MHz operation would be possible if desired.
#63 MrSmoofy
MrSmoofy
  • 47 posts
  • LocationOdessa, FL
Posted 25 November 2014 - 11:17 PM
I know this is an old thread but I'm heading down the path of driving LED strips with my netduino and wanted to find some examples of how to do it.
My lights will be 12v which I will have to power outside of the netduino.  It looked like the OP was going write a tutorial on how to use a netduino with SPI and LED lights but doesn't look like he ever came back and posted about it.
Would be really interested in some working sample code to look at.
#64 iukpo
iukpo
  • 85 posts
Posted 26 November 2014 - 12:47 AM
Hi! Wow...this thread is still active?? Haha. ;)
Unfortunately, I had some more trouble with the Netduino chip and ultimately wound up switching to a different device for control.
BUT!
I still have my last working code. Here you go-it was written in C# for a WS8201.
Good luck!
using System.IO;
using SecretLabs.NETMF.Hardware.NetduinoMini;
namespace NetduinoMiniApplication1
            static UInt16 numLEDs;
            static SPI.Configuration xSPIConfig;
            static SPI xspi;
             static byte[] colors;
             static byte[] zeroes;
             static byte[] attentionSequence = new byte[] { 0, 0, 0, 0 };
             static int numChannelsPerPixel = 3;
             static void writeColors()
                 xspi.Write(colors);
             static void writezeros(int n)
                 while (n>0)
                     xspi.Write(zeroes);
                     n--;
             //Order is R (0), G (1), B (2).
             static byte[] getRGBChannelsFromColor(UInt32 color)
                 byte[] buffer = new byte[numChannelsPerPixel];
                 buffer[0]=(byte)((color >> 16) | 0x80);//g
                 buffer[1]=(byte)((color >> 8) | 0x80);//r
                 buffer[2] = (byte)(color | 0x80);//b
                 return buffer;
             static void setPixelColor(UInt16 n, UInt32 c)
                 if (n >= numLEDs) return; // '>=' because arrays are 0-indexed
                 colors[n*numChannelsPerPixel] = (byte)((c >> 16) | 0x80);//g
                 colors[n * numChannelsPerPixel + 1] = (byte)((c >> 8) | 0x80);//r
                 colors[n * numChannelsPerPixel + 2] = (byte) (c | 0x80);//b
             static void setPixelColor(UInt16 n, byte r, byte g, byte b)
                 colors[n * numChannelsPerPixel] = (byte)(g  | 0x80);
                 colors[n * numChannelsPerPixel + 1] = (byte)(r | 0x80);
                 colors[n * numChannelsPerPixel + 2] = (byte)(b | 0x80);
             //Used to send command to change color.
             static void latch()
                 //writezeros(1);
                 xspi.Write(zeroes);
             static void clearColorArrayValues()
                 for (UInt16 i = 0; i < colors.Length; ++i)
                     colors[i] = (byte)0x80 | 0;
                     //Debug.Print("colors[i]=" + colors[i]);
                 writeColors();
                 latch();
             static void doPulseTransition(UInt32[] pulse_colors)
                 clearColorArrayValues();
                 for (byte j = 0; j < pulse_colors.Length; j++)
                     for (byte i = 0; i < numLEDs; ++i)
                         setPixelColor(i, pulse_colors[j]); //j
                     writeColors();
                     //Send latch so can write.
                     latch();
                     //writezeros(numLEDs);
                     //Thread.Sleep(5000 / numLEDs);
             //Algorithm: break each color down into RGB components, then decrement/increment each channel value until it matches the destination RGB value.
             static void doPulseTransition(UInt32 initial_color, UInt32 final_color, int refresh)
                 UInt32 a, b, i, tmp_color;
                 a = initial_color;
                 b = final_color;
                 byte[] initial_rgb = getRGBChannelsFromColor(initial_color);
                 byte[] final_rgb = getRGBChannelsFromColor(final_color);
                 for (i=0; i<numChannelsPerPixel; i++)
                     while (initial_rgb[i] != final_rgb[i])
                         if (initial_rgb[i] < final_rgb[i])
                             initial_rgb[i]++;
                         else if (initial_rgb[i] > final_rgb[i])
                             initial_rgb[i]--;
                         tmp_color = RgbToColor(initial_rgb[1], initial_rgb[0], initial_rgb[2]);
                         setColor(tmp_color,refresh);
             static void setColor(UInt32 col)
                     setPixelColor(i, col);
                 writeColors();
                 Refresh();
             static void setColor(UInt32 col, int refreshInMS)
                 writeColors();
                 Refresh(refreshInMS);
             static void initializeZeroArray()
                 for (byte j = 0; j < zeroes.Length; j++)
                     zeroes[j] = 0x00;
             static void reset()
                 for (byte j = 0; j < colors.Length; j++)
                     colors[j] = 0x00;
             static void clearALLLEDs()
                 Refresh();
             static UInt32 RgbToColor(byte r, byte g, byte b)
                 // Take the lowest 7 bits of each value and append them end to end
                 // We have the top bit set high (its a 'parity-like' bit in the protocol and must be set!
                 UInt32 color;
                 color = (UInt32)(g | 0x80);
                 color <<= 8;
                 color |= (UInt32)(r | 0x80);
                 color <<= 8;
                 color |= (UInt32)(b | 0x80);
                 return color;
             static void Refresh()
                 xspi.Write(attentionSequence);
                 xspi.Write(colors);
                 var ledLatchCount = numLEDs * 2;
                 for (var i = 0; i < ledLatchCount; i++)
                     latch();
                 //Need to wait a little after setting to allow values to go all the way down.
                 //TODO: consider adding a value to function that accepts how long to wait. If it is not specified, use a default value. 500-1000ms work. Try to find 30<x<500 such that change is
                 //not too quick
                 Thread.Sleep(500);//
             static void Refresh(int waitInMS)
                 xspi.Write(colors);
                     latch();
                 //not too quick
                 Thread.Sleep(waitInMS);//
                numLEDs = 32;
                xSPIConfig = new SPI.Configuration(Cpu.Pin.GPIO_NONE, false, 0, 0, false, true, 20000, SPI.SPI_module.SPI1);
                 * public SPI.Configuration (
                     Pin ChipSelect_Port,
                     bool ChipSelect_ActiveState,
                     UInt16 ChipSelect_SetupTime,
                     UInt16 ChipSelect_HoldTime,
                     bool Clock_IdleState,
                     bool Clock_Edge,
                     UInt16 Clock_Rate,
                     SPI_module SPI_mod
                xspi = new SPI(xSPIConfig);
                zeroes = new byte[numChannelsPerPixel * ((numLEDs + 63) / 64)];
                colors = new byte[numChannelsPerPixel * numLEDs];
                //0x00FF0000=Green, 0x000000FF=Blue, 0x0000FF00=Red
                UInt32[] pulse_cols = { 0x000000FF, 0x0000FF00, 0x00FF0000 };
                Debug.Print("Zeroes length=" + zeroes.Length);
                reset();
                initializeZeroArray();
                    doPulseTransition(RgbToColor(0, 0, 255), RgbToColor(0, 255, 0),2);
                    doPulseTransition(RgbToColor(0, 255, 0),RgbToColor(255, 0, 0),2);
                    setColor(RgbToColor(255, 0, 0));
                    setColor(RgbToColor(0, 255, 0));
                    setColor(RgbToColor(0, 0, 255));
