BitBanger Driver
#21
Posted 19 October 2010 - 07:08 AM
#22
Posted 19 October 2010 - 11:00 PM
Hookedup: if you want to flash this you will need to reflash your bootloader (tinybooterdecompressor.bin is included) and then flash the hex files included.
-(e)
Thank you very much for providing the files and for contributing such a great updates. I am super busy for a couple of days but will work to do the updates and test usage asap.
I enjoy working with netduino and have high hopes that using your code will get me over the minor bump in the road to doing really cool stuff with the netduino
#23
Posted 20 October 2010 - 06:12 PM
Chris:
I have taken the liberty of moving the code into the SecretLabs.NETMF.Hardware namespace.
Attached is a zip that should be extracted into the Solutions\Netduino\ folder and will:
- update the Solutions\Netduino\DeviceCode\SecretLabs_NETMF_Hardware folder with the bitbang code
- add the managed project source code into the C:\MicroFrameworkPK_v4_1\Solutions\Netduino\ManagedCode\SecretLabs_NETMF_Hardware folder
I tested the firmware against the LED matrix code and it all seems to work nicely.
Hookedup:
I hope this works for you, let me know how it goes.
-(e)
#24
Posted 27 October 2010 - 03:06 PM
#25
Posted 01 November 2010 - 08:59 AM
Take a seat, I'll be right with you.
#26
Posted 01 November 2010 - 10:16 AM
Folks,
After much frustration I've found out (think) my LCD won't work because of how I am talking to it. It would appear this is my solution.
Any chance of a nice step by step walkthrough on how to get this working? I've flashed the new bootloader and flashed the firmware with sweetlilmre copy but am non the wiser as to how to proceed.
after much searching on my machine for anything that resembled "C:\MicroFrameworkPK_v4_1\Solutions\Netduino\ManagedCode" I worked out I actually had to install the Porting kit from MS. From there, I am still lost.
Any help for a total noob at this? Any hint as to when it would be in the native firmware, even as an alpha? I would be happy to use that.
CP
If you have flashed the firmware I provided then in the zip file should be an assembly that you can reference.
Once you've referenced the assembly in your project you can call the bitbanger driver (you don't need the porting kit etc. unless you want to compile your own firmware).
You are looking for "NetDuino.Hardware.BitBang.dll" in the zip file. Reference that and then instantiate the class and call appropriate methods to setup the gpios etc.
-(e)
#27
Posted 01 November 2010 - 08:33 PM
#28
Posted 05 November 2010 - 10:22 PM
Ahh, thanks. I'll try that then.
If it works I shall name my first born sweetlilmre
Watch this space
No Joy
I can add the code in and that all seems well but I cannot get the LCD to play nice. It's all a bit beyond me on how to talk LCD..
Cheers,
Crispin
#29
Posted 10 November 2010 - 07:54 PM
No Joy
Cheers,
Crispin
Do you have any specifics on the issue? What LCD, wiring etc?
Maybe we can figure this out.
-(e)
#30
Posted 25 November 2010 - 01:05 PM
-(e)
Hi Sweetlilmre,
If you have the time can you please explain to me how I can get this bitbanger driver to work with the Dot Matrices from Sure Electronics? or can you update your example of the Led Matrices with this driver?
Ramon
#31
Posted 26 November 2010 - 08:09 AM
Hi Sweetlilmre,
Ramon
Hi Ramon,
I will try to get to this as soon as possible, unfortunately life is a little crazy at the moment
-(e)
#32
Posted 26 November 2010 - 08:16 AM
#33
Posted 30 November 2010 - 08:53 PM
#34
Posted 16 December 2010 - 11:18 PM
#35
Posted 23 December 2010 - 10:22 AM
#36
Posted 05 January 2011 - 09:16 PM
#37
Posted 06 January 2011 - 06:38 AM
Hi
Does the Bitbanger need an external clock signal to work (that is what i beleive)?
How is the performans, how long from a clock until output, how fast can the next output bee, and so on ?
Does it sit in a tight loop doing the work, or is it interupt driven? I have seen an issue with Interupt latency but perhaps that is only for managed code.
Would it be possible to have it internally clocked, something like the OutputCompare, were you have an array of delays and the bit values.
/Jan Olof
The BitBang will toggle the clock line for each bit of data output, in a tight loop, as fast as possible.
This is handled by the interop layer and is written in raw C code (well a C++ function, but effectively raw C) and should have a very low latency i.e. this is about as fast as it is possible to toggle pins without offloading to something like SPI.
Internal clock could be possible but is probably somewhat out of scope for the BitBang code. Perhaps there could be an extra parameter to introduce a fixed per bit delay if this was a valid use-case? i.e. delay X microseconds after each clock pulse.
-(e)
#38
Posted 06 January 2011 - 06:39 AM
Does this BitBanger project have a home page and more information ?
No it doesn't but should
-(e)
#39
Posted 02 February 2011 - 04:17 PM
Hi all,
I've attached the latest code which I got a chance to test last night. It seems to perform well (and work!)
Source is in the archive as well.
Chris, now I just need to rename / whatever to make this an appropriate fit for the firmware.
-(e)
I've arrived late to the party. The use case outlined is just what I'm experiencing. I've used 8 bit stuff in the past (Arduino), and I find, as an example, that I just can't drive bits fast enough. I have an Arduino-based project which uses four 0832 displays, but the Netduino version of it is too slow to be usable. Sending 32 bytes isn't so bad, but sending 128 means that you can actually see the updates taking place, so not ideal.
I'd prefer to use only SecretLabs stock firmware if possible, so including this in the firmwaare for the various Netduino models would be an easy solution. Is there a timeline for this?
Steve S
#40
Posted 13 September 2011 - 01:24 PM
