Read Resources
Posted 11 October 2011 - 05:10 PM
Posted 11 October 2011 - 05:30 PM
Posted 11 October 2011 - 06:26 PM
Thanks!Hi Sprinter,
I'm not sure if I understand you correctly, but do you want to store a file.txt onto an SD card and read that from VB.NET?
I wanted to copy a txt file to the sd
Or the resources to sd
I hope you understand me!
Posted 11 October 2011 - 06:27 PM
Posted 12 October 2011 - 07:26 PM
Posted 13 October 2011 - 06:04 AM
Posted 13 October 2011 - 05:03 PM
You want to copy or append? Appending an existing text file is possible. Can you post the code for writing? Then I'll modify it for appending
I want to do a project to bring the files into sdcard without needing to use a usb readder.
example 1:
Dim myFile As String = Application.StartupPath & "\Myfile.txt"
or
Dim myFile As String = "c:\Myfile.txt"
Dim fs As System.IO.FileStream = New System.IO.FileStream(myFile, IO.FileMode.Create)
Write("\SD\Myfile.txt", 0, My.Myfile.txt.Length)
example 2:
Copy file to c:\ to SDCARD!
Posted 13 October 2011 - 06:47 PM
Posted 13 October 2011 - 08:35 PM
Ohh but from your Netduino you can't access you C: drive on your PC; it's not connected.
You can read/write/append/remove to the SD card, but not to the PC. Is that what you ment?
Ok
resources from vb?
