About reading IR signals from remotes
Posted 08 October 2011 - 06:34 PM
Posted 08 October 2011 - 07:57 PM
Although Netduino microcontroller is rather powerful, the performance of managed code is significantly lower, because it is interpreted (unlike in 'full' .NET Framework, where Just-In-Time (JIT) compiler translates IL opcodes into assembly). But in all likelihood, 50 kHz is the modulation frequency, you can easily use IR receiver with built-in demodulator or band-pass filter, so you don't have to sample the input signal at such rates. The demodulated output timing depends on particular IR protocol, it is usually slower (~milliseconds) and this can be recorded using interrupts. For example, there is already RC6 decoder and NEC protocol decoder.I want to record IR signals from my remotes. I measured the signals from an IR receiver diode at about 50 kHz, and saw from the ARM processor data sheet that the Netduino A/D channels can handle 384 KHz.
Posted 08 October 2011 - 08:11 PM
Although Netduino microcontroller is rather powerful, the performance of managed code is significantly lower, because it is interpreted (unlike in 'full' .NET Framework, where Just-In-Time (JIT) compiler translates IL opcodes into assembly). But in all likelihood, 50 kHz is the modulation frequency, you can easily use IR receiver with built-in demodulator or band-pass filter, so you don't have to sample the input signal at such rates. The demodulated output timing depends on IR particular protocol, it is usually slower (~milliseconds) and this can be recorded using interrupts. For example, there is already RC6 decoder and NEC protocol decoder.
Posted 08 October 2011 - 08:18 PM
