Query NTP server. Byte operations not supported?
6 replies to this topic
#1 Moskus
Moskus
  • 132 posts
  • LocationNorway
Posted 19 September 2011 - 12:25 PM
I tried to convert the NTP server query function found here to VB.NET in the .NETMF, but the byte operations fail.
Public Function GetNetworkTime() As DateTime
        Dim ep As New Net.IPEndPoint(Dns.GetHostEntry("time-a.nist.gov").AddressList(0), 123)
        Dim s As New Sockets.Socket(Sockets.AddressFamily.InterNetwork, Sockets.SocketType.Dgram, Sockets.ProtocolType.Udp)
        s.Connect(ep)
        Dim ntpData As Byte() = New Byte(47) {} ' RFC 2030'
        ntpData(0) = &H1B
        For i As Integer = 1 To 47
            ntpData(i) = 0
        Next
        s.Send(ntpData)
        s.Receive(ntpData)
        Dim offsetTransmitTime As Byte = 40
        Dim intpart As ULong = 0
        Dim fractpart As ULong = 0
        For i As Integer = 0 To 3
            intpart = CULng(256 * intpart + ntpData(offsetTransmitTime + i))
        Next
        For i As Integer = 4 To 7
            fractpart = CULng(256 * fractpart + ntpData(offsetTransmitTime + i))
        Next
        Dim milliseconds As ULong = CULng((intpart * 1000 + (fractpart * 1000) / &H100000000L))
        s.Close()
        Dim timeSpan__1 As TimeSpan = TimeSpan.FromTicks(CLng(milliseconds) * TimeSpan.TicksPerMillisecond)
        Dim dateTime As New DateTime(1900, 1, 1)
        dateTime += timeSpan__1
        Dim offsetAmount As TimeSpan = TimeZone.CurrentTimeZone.GetUtcOffset(dateTime)
        Dim networkDateTime As DateTime = (dateTime + offsetAmount)
        Debug.Print(networkDateTime.ToString())
        Return networkDateTime
    End Function
These lines are throing errors:
intpart = 256 * intpart + ntpData(offsetTransmitTime + i)
I get these errors:
Requested operation is not available because the runtime library function 'System.Convert.ToUInt64' is not defined.
Requested operation is not available because the runtime library function 'System.Decimal.Add' is not defined.
Requested operation is not available because the runtime library function 'System.Decimal.Divide' is not defined.
Requested operation is not available because the runtime library function 'System.Decimal.Multiply' is not defined.
The exact same code works without problem in a regular .NET Framework (console) application.
#2 baxter
baxter
  • 415 posts
Posted 19 September 2011 - 06:59 PM
Look at the Daytime server. You don't have to screw with this arithmetic. The NIST Daytime servers return an accii message on tcp port 13. See http://forums.netdui...rotocol-client/ I changed to this protocol because of the the difficulties you are citing. wwv.nist.gov is very reliable. Baxter
#3 Moskus
Moskus
  • 132 posts
  • LocationNorway
Posted 19 September 2011 - 07:11 PM
Great! I'm trying that. Thanks! :)
#4 Moskus
Moskus
  • 132 posts
  • LocationNorway
Posted 20 September 2011 - 07:04 AM
... but I still would like simple bitoperations to work... ;)
#5 AdamS
AdamS
  • 8 posts
Posted 11 January 2012 - 04:22 PM
Moskus, Did you ever Get this working?
#6 Moskus
Moskus
  • 132 posts
  • LocationNorway
Posted 13 January 2012 - 08:50 PM
No, but I haven't had the chance to play with my Netduinos lately. I haven't installed the latest firmware either...
#7 AdamS
AdamS
  • 8 posts
Posted 14 January 2012 - 01:31 PM
thats ok i found a bit of a workaround for the time being by putting the ntp class into a separate C# class library attached to the solution :)
