Can't get com1 uart to work on Mini
1 reply to this topic
#1 Nissim
Nissim
  • 54 posts
  • LocationNew Zealand
Posted 18 September 2011 - 07:06 AM
Hi There I used application MFDeploy.exe to erase Mini and I reloaded ER_Config and ER_Flash COM 2 RS232 is functioning as expected but I get no data from COM1 Do I need to upload any file to get it to work? using System; using System.Threading; using System.IO.Ports; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.NetduinoMini; namespace NetduinoMiniApplication1 { public class Program { public static void Main() { var serialPortGPS = (SerialPort)null; var serialPortCP5200 = (SerialPort)null; Thread.Sleep(1000); byte[] testByte = new byte []{0x65,0x66}; serialPortCP5200 = new SerialPort("COM2", 9600, Parity.None, 8, StopBits.One);//" COM2" RS232 Pin 1,2 serialPortGPS = new SerialPort("COM1", 4800, Parity.None, 8, StopBits.One);//" COM1" TTL Pin 11,12 serialPortCP5200.Open(); serialPortGPS.Open(); serialPortCP5200.Write(testByte, 0, 1); // this line is working and i get data from comport // serialPort.Close(); byte[] dataReadFromGPS = new byte []{}; while (true) { var numberOfBytesToRead = serialPortGPS.BytesToRead; if (numberOfBytesToRead > 0) { dataReadFromGPS = new byte[numberOfBytesToRead]; var numberOfBytesRead = serialPortGPS.Read(dataReadFromGPS, 0, numberOfBytesToRead); } serialPortCP5200.Write(dataReadFromGPS, 0, numberOfBytesToRead);// * No data is received on COM 2 !! } } } }
#2 Fred
Fred
  • 302 posts
  • LocationUK
Posted 18 September 2011 - 07:38 PM
The mini had two com ports but you need to use one of them to deploy and debug your application. If com 1 is working I assume you're deploying on com 2. Once you're finished debugging it's possible to use both in you're application.
