HT1632 interface (alpha)
53 replies to this topic
#1 sweetlilmre
sweetlilmre
  • 62 posts
Posted 01 September 2010 - 09:53 AM
Attached is some code to drive the HT1632 LED Matrix chip as found in the Sure Electronics DE-DP13212 and similar boards (Sure Electronics).
The code is horribly slow at the moment as a raw bit-bang approach is used to communicate with the HT1632 (and I am sure my horribly un-optimsed code does not help :))
I will migrate this to SPI once variable SPI is available. At any rate here it is to look at.
This code was ported from Miles Burton's Arduino code and is released under the same GPL license.
Any pointers on optimisation would be great as C# on an embedded device is very new to me!
Connection is 5 wires:
Power and ground to 5V and GND pins.
ChipSelect to digital pin 4
Clock to digital pin 13
Data (WR) to digital pin 12
Hope this helps someone. I will attempt to optimise this to make it useful and to support the 2416 boards as well.
-(e)
Posted 01 September 2010 - 04:08 PM
Very cool! You've implemented "bit banged" variable-bit SPI using managed...doubly cool.
#3 sweetlilmre
sweetlilmre
  • 62 posts
Posted 01 September 2010 - 04:36 PM
I really can't take too much of the credit, its mostly Miles Burton's code, but thanks :)
I think that is definitely part of the speed issue as is the memory access on the buffer arrays.
I need to have a look at that...
-(e)
#4 RvBCrS
RvBCrS
  • 31 posts
  • LocationZutphen, Netherlands
Posted 23 September 2010 - 09:18 AM
-(e)
Cool stuff Sweetlilmre!
I'm trying your sample with some of my 0832 boards here but I can't seem to get anything displayed on it. I have to say it are the green 0832's from SureElectronics and not the red ones don't know if that makes any difference. Just to be sure this is how I mapped the pins
NetDuino -------------- Matrix
Pin4 -------------- Pin3
Pin13 -------------- Pin5
Pin12 -------------- Pin7
Is that correct? or did I screw up :)
Blog: Morrison Blog
Twitter: @rvbcrs
#5 sweetlilmre
sweetlilmre
  • 62 posts
Posted 23 September 2010 - 10:00 AM
Checking the 0832 Datasheet, your connections look good.
I assume you have also wired:
NetDuino GND to Matrix 11
NetDuino 5V to Matrix 12
Also that you have set the dip switches on the back of the matrix to 1=ON, 2=OFF, 3=OFF, 4=OFF?
Make sure you have the matrix connector orientation correct (I got it upside down the first time and wired 5V to GND... :))
-(e)
#6 RvBCrS
RvBCrS
  • 31 posts
Posted 23 September 2010 - 10:31 AM
-(e)
Very strange, I did connect GND to pin 11 and 5V to 12 on the matrix, I also checked the CS selection switch and only 1 is on.. I have also some 2416 boards I tried one of those still no luck! Do you have a picture or something on how you wired yours? Or do you have any other ideas?
Thanks!
Blog: Morrison Blog
Twitter: @rvbcrs
#7 sweetlilmre
sweetlilmre
  • 62 posts
Posted 23 September 2010 - 01:18 PM
Thanks!
Does this help at all?
Posted Image
I just rewired it and tested it out. It all seems to work OK?
On the ribbon side, the pins are:
Green: Chip Select, pin3
Orange: Clock, pin5
White: Data, pin 7
Black: GND, pin 11
Red: 5V, pin 12
The 2416 will not work as the addressing mode is different. (well it might display something, but certainly not what is intended, I must get one of those to play with though...)
HTH
-(e)
#8 RvBCrS
RvBCrS
  • 31 posts
Posted 23 September 2010 - 03:35 PM
Posted Image
Orange: Clock, pin5
White: Data, pin 7
Black: GND, pin 11
Red: 5V, pin 12
HTH
-(e)
Thanks for the picture! My configuration is exactly the same! So it can't be the wiring, you said the 2416 won't work because of a different pixel mapping.. I have read somewhere that the pixel mapping of the green 0832 is different from the red 0832 too just like the green 2416 pixel mapping is different from the red one.
The code runs just fine I have checked if the matrices are getting power. I really have no idea what is going wrong.
This is what is on the back of my 0832: Posted Image
Is that the same as yours?
Thanks again for your help! I really hope I can get it to work!
Blog: Morrison Blog
Twitter: @rvbcrs
#9 sweetlilmre
sweetlilmre
  • 62 posts
Posted 23 September 2010 - 09:56 PM
I can't imagine the mapping is different if they are using the same display driver... I have the Yellow one btw.
Here is a close up (sorry about the washed out look, but the lighting in my study is terrible at night)
Posted Image
The only other thing I can suggest is that you have a bad connection. My clock line was dodgy initially and nothing would display.
HTH
-(e)
#10 RvBCrS
RvBCrS
  • 31 posts
Posted 25 September 2010 - 11:10 AM
Well I'm going to give up for now I tried everything, I cut a connector from one of the cables and soldered the pins directly to it but I can't seem to get anything out of it.
Posted Image
I have 8 matrices and tried them all no luck with all of them. I really do not hope it is my netduino that is faulty or something.
I'm going to order a red 0832 matrix from sure to see if that one works for me..
One other thing I have thought of.. did you change anything in your firmware? maybe I have an older firmware or something? or isn't that possible, i'm such a newbee with Netduino :)
Blog: Morrison Blog
Twitter: @rvbcrs
#11 sweetlilmre
sweetlilmre
  • 62 posts
Posted 25 September 2010 - 12:44 PM
Damn this is frustrating! :)
I run custom firmware for the bitbanger mod I made but this should not be a issue (the code attached is the original code I developed on stock firmware).
Do you by any chance have an Arduino? If so try the code from Miles Burton (linked in the first post) with your matrix and see if that works.
As a last option I reflashed with the original firmware to make sure there were no funnies there:
4.1.0.3 firmware
Then rebuilt the attached code and deployed it, it runs as expected. Try and do the firmware update, just in case. I have a watch on this topic so post back when you get the red matrix. I'd love to see this resolved!
Now to reflash back to custom... :)
-(e)
#12 RvBCrS
RvBCrS
  • 31 posts
Posted 25 September 2010 - 01:40 PM
4.1.0.3 firmware
-(e)
Hmm that was a good suggestion to try it on my Arduino.. you can see the result below:
http://www.youtube.com/watch?v=Lmn4nZ0OKyE
I have downloaded the latest code from Miles Burton his site and as you can see it runs perfectly! strange stuff he!
Blog: Morrison Blog
Twitter: @rvbcrs
#13 RvBCrS
RvBCrS
  • 31 posts
Posted 25 September 2010 - 05:02 PM
Whoot Whoot! Solved it! I tried the link you provided with the 4.1.0.3 firmware flashed the firmware and after the upgrade was finished I instantly saw something displayed on my Matrix!! So the solution was flashing the updated firmware, now I have the same result as in the video posted earlier but the with my Netduino! Thanks a million for helping me out! I will now try to make some extra functionality to run more than one display for example.. or do you have more recent code?
Blog: Morrison Blog
Twitter: @rvbcrs
#14 sweetlilmre
sweetlilmre
  • 62 posts
Posted 26 September 2010 - 11:26 AM
YAYAYAYAY!! :) Awesome!
I have some more recent code that uses the custom bitbanger firmware to really blast the display (it so much faster its unbelievable).
I need to fix it up so that compilation is conditional i.e. you don't need special firmware, and I have optimised the font drawing and some other bits.
I'll take a look tonight and see if I can post it up.
-(e)
#15 RvBCrS
RvBCrS
  • 31 posts
Posted 26 September 2010 - 01:18 PM
-(e)
Wow that would be awsome! I have 4 displays connected now and as you said it is very slow, the text crawls across the displays ;) I really hope you can post your code tonight. My ultimate goal is to get the displays working in combination with a Ethernet Shield so you can send messages to the Netduino and displays it on the matrices.
One other thing, do you think it is possible to connect more then 4 displays? lets say for example 8?
I'm really looking forward to you code! Thanks!
Blog: Morrison Blog
Twitter: @rvbcrs
#16 Hauk
Hauk
  • 18 posts
  • LocationSan Diego, CA
Posted 11 December 2010 - 02:52 AM
Hey! Did you get a chance to post the code for this? Does it use the new variable-length SPI functions in the new firmware? Thanks! /Hakan
#17 Hauk
Hauk
  • 18 posts
Posted 17 December 2010 - 07:04 AM
I implemented my own version of the HT1632 interface using variable-length SPI on the Netduino using the latest alpha firmware. It was really tricky because the HT1632 interface is just spi-like, not 100% (it varies the word length, and expects CS to be active to do bulk write). I had to do bit-operations in the memory buffer to get it to work. It currently only supports the green 2614 from Sure Electronics (as it's the only one I have access to).
The source code is here: Netduino Stuff code, under LedMatrix.
The output to the displays is wicked fast (about 1 ms to do a full frame output), but the bit-access to the memory array isn't that fast. I wish we could modify the spi word length on the fly, and keep CS active between writes... WISH
#18 Chris Walker
Posted 17 December 2010 - 07:57 AM
Hauk,
Can you explain your wish in more detail? Not sure how much we can do here without shaking up the .NET MF architecture, but I'd like to look into it...
#19 CW2
Posted 17 December 2010 - 07:30 PM
I have hit the same issues: it is not possible to change configuration of SPI (and SerialPort etc.) because properties are read-only, so a new instance must be created with the new configuration values passed via constructor, which causes side effects like extra pulses due to initialization code - pins are being reserved, set-up etc. Additionally, every call to SPI write method always initializes (see Xaction_Start(...)) and then uninitializes (Xaction_Stop(...)) signal pins - this means it is not possible to have subsequent calls without extra transitions on clock and chip select lines. I hope in the next version such code will be moved from write method (e.g. to constructor), so it is performed only once. Alternatively, support of Chip Select Active After Transfer (CSAAT) would help too...
#20 Hauk
Hauk
  • 18 posts
Posted 17 December 2010 - 08:37 PM
Hauk,
I have three wishes, not sure how they would be implemented, I don't know much about the MF arch, but here they are:
  • Change the SPI word length on the fly, ie before each transfer. The HT1632-based displays need 14 bits for one data transfer, 15 for commands, and 14+8,8,8,etc for bulk transfer.
  • Hold CS/latch high between transfers. If I could do that then I think I could set the SPI word length to 14 bits, send the data transfer command and then bulk load with spi.Write(byte) to send out 8-bits for the bulk. But the bulk load gets interrupted when CS goes inactive in the HT1632 controller.
  • Change the CS pin for SPI on the fly (I need one pin per display module). Now I have to dispose/create an SPI instance before each transfer to each display (I have 4).
