Build Error 0xfd000000
Posted 07 September 2011 - 05:14 PM
Posted 07 September 2011 - 05:29 PM
Do you have a space or underscore in the assembly name (in AssemblyInfo.cs)?I keep getting this error whenever I try and build my project. The error code is all there is, there is no other information other than the "file" column which says MMP(?). Does anybody know what the problem here is?
Posted 07 September 2011 - 05:35 PM
Well stone me. That appears to have done it. Thanks.
What a silly restriction and what an unhelpful error message!
Posted 07 September 2011 - 05:48 PM
I am glad it works, it was really wild guess (based on a quick google query). Admittedly, MetaDataProcessor.exe (MMP) output can benefit from some improvementsWell stone me. That appears to have done it. Thanks.
Posted 30 November 2011 - 06:13 PM
I've the same problem, but there are no underscores or anythingelse in the file.
The content is:
using System.Reflection; using System.Runtime.CompilerServices; using System.Runtime.InteropServices; // General Information about an assembly is controlled through the following // set of attributes. Change these attribute values to modify the information // associated with an assembly. [assembly: AssemblyTitle("NetduinoPlusWebServer")] [assembly: AssemblyDescription("")] [assembly: AssemblyConfiguration("")] [assembly: AssemblyCompany("")] [assembly: AssemblyProduct("NetduinoPlusWebServer")] [assembly: AssemblyCopyright("Copyright©2011")] [assembly: AssemblyTrademark("")] [assembly: AssemblyCulture("")] // Version information for an assembly consists of the following four values: // // Major Version // Minor Version // Build Number // Revision // [assembly: AssemblyVersion("1.0.0.0")] [assembly: AssemblyFileVersion("1.0.0.0")]
The program worked fine until yesterday, I tried to combine two projects (WebServer and LCD-Shield)
and now it shows me this error, 2 hours of googling couldn't help me
Any idea?
Thanks !
Posted 01 December 2011 - 03:10 AM
Posted 01 December 2011 - 07:00 AM
Posted 01 December 2011 - 07:19 AM
When you build your application and deploy, the size of the app will appear in the same window where the compilation messages appear. [Hopefully the error doesn't clear that output.]hm, perhaps it is too big; how to find out?
Which of the files in the debug-directory it flashes to my netduino?
If you combine programs together and then get an error...I'd always start with looking at size
Posted 01 December 2011 - 07:32 AM
Posted 01 December 2011 - 07:51 AM
Posted 16 June 2012 - 10:03 PM
Posted 07 December 2012 - 11:57 PM
