AnalogInput values fail to change
7 replies to this topic
#1 trustme
trustme
  • 12 posts
Posted 31 August 2010 - 10:39 PM
I have another issue. I have a MaxSonar which I've connected to Analog port 1-5... tried them all. The Read function always returns 1023. I've hooked up a multimeter and I can see the value is changing as objects are placed in front of the sensor. I've reset the board. I've created and disposed an Interrupt port to disable the resistor mode.
            InterruptPort test = new InterruptPort(Pins.GPIO_PIN_A0, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
            test.Dispose();
            //OutputPort p = new OutputPort(Pins.GPIO_PIN_A0, false);
            //p.Dispose();
            alarm2 = new AnalogInput(Pins.GPIO_PIN_A0);
            alarm2.SetRange(0, 100);
I'm on firmware 4.1.0.2 as I'm using Mac/Parallels to test.
It appears something is amiss. This seems like it should be a very trivial setup. 3 wires out of the MaxSonar, power, ground, and to one of the analog pins.
Is there something else I'm missing?
Posted 31 August 2010 - 11:10 PM
The Atmel ARM processors don't have a built-in AREF. Have you wired the 3.3V power header to the AREF pin (on the opposite side of the board)?
#3 greg
greg
  • 169 posts
  • LocationChicago, IL
Posted 31 August 2010 - 11:58 PM
            test.Dispose();
            //p.Dispose();
Like Chris said, cross connect the header to AREF.
Chris - just so you know while the MaxSonar can be powered 3.3V it's better to power it 5V (more range). Is there a problem hooking AREF up to 5V?
#4 Chris Walker
Posted 01 September 2010 - 12:36 AM
The AT91SAM7X (ARM) chip used on the Netduino is 3.3V--so it needs 0-3.3V analog inputs. You could always use an analog voltage conversion circuit which brings your 5V analog signals down to the 2.5V or 3.3V range--but it's probably best just to run it off of 3.3V in the first place (unless you need range, etc. for other reasons).
#5 greg
greg
  • 169 posts
Posted 01 September 2010 - 12:39 AM
$$$ turn into High Speed Robot, which needs max range on sensors to protect said $$$ from running into walls. :)
#6 trustme
trustme
  • 12 posts
Posted 01 September 2010 - 02:59 AM
Ahhh... thanks so much. Wiring the 3.3V header to the AREF header works. I still have so much to learn about hardware. Thanks for the lesson!
#7 Chris Walker
Posted 01 September 2010 - 03:15 AM
#8 Chris Seto
Chris Seto
  • 405 posts
Posted 01 September 2010 - 04:03 AM
(Greg is my partner on the high speed robot project. Only difference is that he has a brushless version of my truck :rolleyes: )
