'AnalogInput' is an ambiguous reference after 4.2 RC1
10 replies to this topic
#1 maara
maara
  • 10 posts
Posted 04 September 2011 - 06:49 PM
I recently installed MF 4.2 RC1 and correcponding netduino sdk but now I am facing following issue while using analog inputs (even while running tutiorials - I am kind new to c#...)
var port1 = new AnalogInput(Pins.GPIO_PIN_A0);
Error 1 'AnalogInput' is an ambiguous reference between 'Microsoft.SPOT.Hardware.AnalogInput' and 'SecretLabs.NETMF.Hardware.AnalogInput'
Error 2 The best overloaded method match for 'Microsoft.SPOT.Hardware.AnalogInput.AnalogInput(Microsoft.SPOT.Hardware.Cpu.AnalogChannel)' has some invalid arguments
Error 3 Argument 1: cannot convert from 'Microsoft.SPOT.Hardware.Cpu.Pin' to 'Microsoft.SPOT.Hardware.Cpu.AnalogChannel'
What is wrong?
Posted 04 September 2011 - 09:29 PM
Hi maara, That is brand new in .NET MF 4.2 RC2. We will be replacing the current AnalogInput classes with the new ones. As a temporary workaround...when you declare your AnalogInputs, use "SecretLabs.NETMF.Hardware.AnalogInput" instead of just "AnalogInput". Chris
#3 Chris Walker
Posted 04 September 2011 - 09:34 PM
P.S. We plan to extend the AnalogInput class in .NET MF 4.2 so that your existing code will "just work." The only caveat is that the readings will now be Doubles instead of Ints -- so you will need to add (int) in front of the value if you're storing the data as an int... For instance: int reading = (int)analogInput.Read(); Chris
#4 Arbiter
Arbiter
  • 132 posts
  • LocationBrisbane, Australia
Posted 27 July 2012 - 01:06 AM
Chris, how has this panned out? Should I update my code?
Does this
Microsoft.SPOT.Hardware.AnalogInput(Cpu.AnalogChannel.ANALOG_0)
refer to the same pin as this
SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A0)
#5 Chris Walker
Posted 27 July 2012 - 01:13 AM
Hi Arbiter,
Does this
Yes, once we support the new AnalogInput class those will do the same thing. For now, please use the SecretLabs versions.
The plan is to move the Secret Labs PWM and AnalogInput classes to dedicated assemblies. That way they're available for existing applications to use but we also avoid the naming conflicts by defaults.
More on this coming soon...
#6 zemuss
zemuss
  • 69 posts
Posted 25 October 2012 - 06:18 PM
Chris, The SecretLabs.NETMF.Hardware name space doesn't include AnalogInput. I am getting the AnalogInput from the Microsoft.SPOT.Hardware and am wondering if that is correct or if not where else should I pull the Class from?
#7 Coding Smackdown
Coding Smackdown
  • 78 posts
  • LocationLewisville, TX USA
Posted 26 October 2012 - 01:16 PM
You need to add a reference to SecretLabs.NETMF.Hardware.AnalogInput and that should get you what you need. Hope this helps.
http://diybrewery.com
#8 zemuss
zemuss
  • 69 posts
Posted 30 October 2012 - 01:23 AM
I originally added that namespace, and received the following error: "Error 2 The type or namespace name 'AnalogInput' does not exist in the namespace 'SecretLabs.NETMF.Hardware' (are you missing an assembly reference?) C:\Development\Code Examples\Netduino-Aquarium-Controller\Plugin-Temperature\Temperature.cs 5 33 Plugin-Temperature " So it doesn't seem the SecretLabs.NETMF.Harware has AnalogInput namespace.
#9 zemuss
zemuss
  • 69 posts
Posted 30 October 2012 - 02:25 PM
After upgrading from .NET MF 4.1 to 4.2 you need to remove the references then re-add each reference. THe issue is the path seems to be slightly different. So after re-adding and added this code AnalogInput ain = new AnalogInput(AnalogChannels.ANALOG_PIN_A0); it works.
#10 fileark
fileark
  • 12 posts
  • LocationNM
Posted 28 November 2012 - 09:41 PM
I tried removing and adding SecretLabs.NETMF.Hardware and SecretLabs.NETMF.Hardware.NetduinoPlus but that did not help. I noticed that I could add a reference in my project for SecretLabs.NETMF.Hardware.AnalogInput so I did which improved things but after that my old analog inputs were ambiguous so I added SecretLabs.NETMF.Hardware. in front of each AnalogInput in the code.
#11 Rashaad
Rashaad
Posted 09 November 2013 - 11:51 PM
I had to add this reference(SecretLabs.NETMF.Hardware.AnalogInput) in the solution explorer,
and did what you suggested in my code :
 static SecretLabs.NETMF.Hardware.AnalogInput potentiometer =newSecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A0);
and it works...
thanks
