Motor Shield alimentation
11 replies to this topic
#1 pxl357
pxl357
  • 18 posts
Posted 03 September 2011 - 05:27 AM
Hey Guys !
I'm continuing to work on my project and i face a kind of weird little issue.
I can't have my motors running backwards. I'm using the Dfrobot 1A shield and a 9v battery plug directly on the netduino.
I put a basic test :
//FWD
PWM Motor1Speed = new PWM(Pins.GPIO_PIN_D5);
PWM Motor2Speed = new PWM(Pins.GPIO_PIN_D6);
OutputPort Motor1Direction = new OutputPort(Pins.GPIO_PIN_D9, false);
OutputPort Motor2Direction = new OutputPort(Pins.GPIO_PIN_D10, false);
Motor1Direction.Write(false);
Motor1Speed.SetDutyCycle(100);
Motor2Direction.Write(false);
Motor2Speed.SetDutyCycle(100);
//BWD
Motor1Direction.Write(true);
Motor2Direction.Write(true);
Both test go forward.
I wonder if it's an alimentation issue or a code issue.
Any ideas or similar experience ?
PXL
Edited by Stefan, 03 September 2011 - 07:51 AM.
Added [code] tags
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 03 September 2011 - 07:53 AM
I have the same shield and wrote some code for it, as you can see at the wiki: http://wiki.netduino...tor-Shield.ashx Perhaps that could help?
#3 pxl357
pxl357
  • 18 posts
Posted 03 September 2011 - 06:21 PM
Hey Stephan ! I used the library and i have the same exact result the motor always go forward. That's why i start to think about an alimentation issue. How do you power the motors ? FOr now i have a 9v battery plug on the netduino
#4 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 03 September 2011 - 07:19 PM
Hey Stephan !
Did you place the jumpers correctly (PWM mode)? Also, if you measure the voltage on the output, does it switch from negative to positive? I powered them on a 12V power supply, but any direct current battery should work.
#5 pxl357
pxl357
  • 18 posts
Posted 04 September 2011 - 05:53 AM
Sorry i suxx a bit at electronic , is the jumper are the blue connector ? It was basically already solder when i get it. So i assume it ok. I wire everything following the shield wiki as well. I will check the voltage tomorrow see what i have !
#6 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 04 September 2011 - 08:12 AM
As you can see at the shield's own wiki:
http://www.dfrobot.c...RI0009)#Diagram
Control Mode Selection Jumpers: The shield supports PWM and PLL(Phased Locked Loop) control Modes. The PWM mode uses E1 and E2 to generate PWM signal. The PLL mode uses M1 and M2 to generate phase control signal.
The 4 jumpers should be at the right to let it drive via PWM.
#7 pxl357
pxl357
  • 18 posts
Posted 04 September 2011 - 07:42 PM
Oh ok i used the wrong shield !
I bought this one : http://www.dfrobot.c...d&product_id=59
SHould i buy the l298n ??
#8 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 05 September 2011 - 06:09 AM
Ah no, doesn't matter, that one should work the same, but only has PWM as option. I'm curious to your voltage measurement.
#9 pxl357
pxl357
  • 18 posts
Posted 05 September 2011 - 08:09 PM
ok here the informations :
Battery Display 7,43 volt
Using :
m1 Output : -2,65 v
m2 Output : 2,59
m1 Output :-2,54 v
m2 Output : 2,51 v
I'm surprise the voltage is sow low. The battery is directly plug to the netduino and not the motor shield.
Any idea? If it's too hard to figure i will order the other motor shield and a better battery !
Thanks for your help
PXl
#10 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 05 September 2011 - 09:06 PM
That is strange indeed. Could you try an AC Adapter? If a battery is getting low on power, well, your project gets low on power as well ;)
One thing I find rather curious. That shield of yours has two links, one in the DFRobot Shop and one on their wiki page. They both mention a different pin layout:
Pin 5,6,7,8 are used to drive two DC motor
http://www.dfrobot.c..._(SKU:_DRI0001)
Digital 4: Motor 2 Direction control
Digital 5: Motor 2 PWM control
Digital 6: Motor 1 PWM control
Digital 7: Motor 1 Direction control
*snap*
int IN2 = 4; //Latest version use pin 4 instead of pin 8
Perhaps you're driving the wrong pins...
#11 pxl357
pxl357
  • 18 posts
Posted 06 September 2011 - 01:44 AM
Yep that was the issue ! Now it's working !
Thanks a lot ! I will try to figure out a battery solution to have more volt and a separate alimentation probably !
Pxl
#12 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 06 September 2011 - 07:38 AM
Glad to read it's solved. Appairently you bought from an older stock of the shield. Not that it matters but it's useful to know how to drive it I suppose :)
I am currently revising some of my classes, including the one for DFRobot shields. I'll add a comment about this so others won't experience the same troubles.
