MFDeploy Hangs on Network Configuration
#1 wjousts
wjousts
  • 22 posts
Posted 29 August 2011 - 01:41 PM
I just got the Netduino plus board and I opened up MFDeploy to try and configure the network. However, when I got to Target -> Configuration -> Network, the MFDeploy program just hangs and nothing happens. The on-board LED lights on the Netduino board and then goes out after a while, but the MFDeploy app fails to respond. Only when I disconnect the USB cable does it come up with an error message "Device had old or unsupported configuration". What gives?
Posted 29 August 2011 - 03:02 PM
Hi wjousts, This appears to be a driver or .NET Micro Framework SDK issue. Can you post a bug report over at netmf.codeplex.com? The .NET Micro Framework 4.2 core tech team is finishing up the annual .NET MF 4.2 release in the next two weeks... In the meantime, a few ideas: 1. If you try this on another PC, does that work well for you? 2. If you press and hold the pushbutton while plugging the Netduino Plus into your PC, are you then able to set the Network Configuration alright (in bootloader mode)? Chris
#3 wjousts
wjousts
  • 22 posts
Posted 29 August 2011 - 03:17 PM
Hi wjousts,
It seems to work if I hold the button down. Thanks.
