Set the Netduino Date & Time
#1 Robert L.
Robert L.
  • 100 posts
Posted 26 August 2011 - 05:03 PM
I wanted to set the Netduino Plus System Date and Time from a string I receive from a server. The code is pretty straight forward, once you know the right methods to use. But it took more time than I care to admit to get this to work (Hey I am new to C# & .NET micro framework), so perhaps the code below will help someone else. This was tested on 4.2 RC1. It should be pretty easy to modify if your data is in a different format.
    // set the system's date and time from a string in this format:  "mm/dd/yyyy hh:mm:ss"
    public static void SetDateTime(string dts)
        var year   = Str2Int(dts, 6);      // convert each of the numbers
        var month  = Str2Int(dts, 0);
        var day    = Str2Int(dts, 3);
        var hour   = Str2Int(dts, 11);
        var minute = Str2Int(dts, 14);
        var second = Str2Int(dts, 17);
        System.DateTime dt = new System.DateTime(year, month, day, hour, minute, second);
        Microsoft.SPOT.Hardware.Utility.SetLocalTime(dt);
    // convert a string to an "int"  stops at the end-of-string, or at the first non-digit found
    public static int Str2Int(string input, int offset)
        int ret = 0;   // built the result here
        for( int i = offset; i < input.Length; i++)  // stop when all chars have been processed
            char c = input[i];      // get the next char
            if (c < '0') break;     // stop if a non-number is found
            if (c > '9') break;
            int n = (int)c - 48;    // convert the ascii value to a number, IE '1' = 49
            ret = n + 10 * ret;     // accumulate the result
        return ret;   // return the result to caller
#2 Valkyrie-MT
Valkyrie-MT
  • 315 posts
  • LocationIndiana, USA
Posted 26 August 2011 - 05:54 PM
I wanted to set the Netduino Plus System Date and Time from a string I receive from a server...
Nicely written! Looks like a great start! You also might want to look at this thread:
http://forums.netdui...ch__1#entry3515
-Valkyrie-MT
#3 Spork
Spork
  • 105 posts
Posted 14 September 2011 - 04:09 PM
Looks like I just had a syntax error. The syntax checking / error reporting in Visual C# often seems to send me in the wrong direction.
Oops... Posted this on the wrong discussion. Disregard.
