ESC - Code Problem
8 replies to this topic
#1 Adamos
Adamos
  • 9 posts
Posted 26 August 2011 - 09:27 AM
Hello, i am having problems with controlling my ESC. I dont even hear the beep!!!!!
here is the code
namespace lets_start
                motorOnThenOff();
              //  motorTest();
        static void motorOnThenOff()
            OutputPort motor = new OutputPort(Pins.GPIO_PIN_D5, false);
            int onTime = 2500;  //the number of milliseconds for the motor to turn on for
            int offTime = 1000; //the number of milliseconds for the motor to turn off for
            motor.Write(true);       // turns the motor On
            Thread.Sleep(onTime);    // waits for onTime milliseconds
          //  motor.Write(false);      // turns the motor Off
          //  Thread.Sleep(offTime);   // waits for offTime milliseconds
            motor.Dispose();
        static void motorTest()
            PWM Motor = new PWM(Pins.GPIO_PIN_D5);
                Motor.SetDutyCycle(100);
                Thread.Sleep(500);
                Motor.SetDutyCycle(50);
                //Thread.Sleep(800);
                //Motor.SetDutyCycle(0);
Edited by Stefan, 26 August 2011 - 09:31 AM.
Added [code] tags
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 26 August 2011 - 09:31 AM
Hi Adamos and welcome to the Netduino community! Another member posted a somehow related question recently and found a solution, perhaps it'll help you? http://forums.netdui...oller-with-pwm/
#3 Adamos
Adamos
  • 9 posts
Posted 26 August 2011 - 09:44 AM
Thanks!! Well i have seen that code but i still got problems :/ using an arduino of a friend of me i hear the beeps!! but using the netduino nothing. Of course am a beginer!!
#4 Freeman4gu
Freeman4gu
  • 17 posts
Posted 26 August 2011 - 12:52 PM
Hey the other tread is from me ;) in my case you had first to set the throttle of the esc to 100% and then connect the esc and motor (esc and motor should not get any power input before), then set throttle to 0%. After that your esc should sound correct and you can control your motor ;) then set throtte to 20% to begin ^^
Don't know which motor you have, but start only with 20%, else this can happen:
Attached File  WP_000076.jpg   38.58KB   23 downloads
            OutputPort esc = new OutputPort(Pins.GPIO_PIN_D0, false);
            OutputPort relais = new OutputPort(Pins.GPIO_PIN_D1, true);
            InterruptPort button = new InterruptPort(Pins.ONBOARD_SW1, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptNone);
            SpeedController xl5 = new SpeedController(Pins.GPIO_PIN_D5, new TRAXXAS_XL5());
            #region initiate esc & motor
            // set max throttle
            Debug.Print("waiting");
            while (button.Read())
                if (xl5.Throttle != 100) xl5.Throttle = 100;
            // activate esc
            Debug.Print("activate esc");
            esc.Write(true);
            Thread.Sleep(500);
            // activate motor
            Debug.Print("activate motor");
            relais.Write(false);
            // set min throttle
            Debug.Print("set throttle min");
            if (xl5.Throttle != 0) xl5.Throttle = 0;
            Thread.Sleep(5000);
            #endregion
            bool end = false;
            bool oldspeedup = button.Read();
            DateTime dt = DateTime.Now;
            int i = 1;
                //if (!buttonInput.Read()) break;
                bool speedup = !button.Read();
                if (oldspeedup != speedup && speedup & end) break;
                if (speedup)
                    Debug.Print("speedup");
                    end = true;
                if (speedup && xl5.Throttle != 20 + (i * 2)) xl5.Throttle = 20 + (i * 2);
                if (!speedup && xl5.Throttle != 0) xl5.Throttle = 0;
                oldspeedup = speedup;
                if (DateTime.Now > dt)
                    dt = DateTime.Now.AddSeconds(3);
                    i++;
            Debug.Print("deactivate relais");
            esc.Write(false);
            Thread.Sleep(500);
            relais.Write(true);
            xl5.Throttle = 0;
#5 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 26 August 2011 - 01:04 PM
Oh dear! That did hurt I suppose? :o
#6 Adamos
Adamos
  • 9 posts
Posted 26 August 2011 - 02:54 PM
Thanks guys for ur help i will try it out i will let you now about my progress!!!!
Well i am always be carefull with this things coz am using a jet motor!!!! :P (i saw similar motor working)
#7 Adamos
Adamos
  • 9 posts
Posted 26 August 2011 - 03:05 PM
           **** SpeedController xl5 = new SpeedController(Pins.GPIO_PIN_D5, new TRAXXAS_XL5());
Well my ESC in not a TRAXXAS one. I have seen similar code and i thing so that need a another one class in order to instansiate
SpeedController() .
#8 Freeman4gu
Freeman4gu
  • 17 posts
Posted 26 August 2011 - 03:09 PM
Yeah I know, I also have no Traxxas one ;) but works :P I really didn't understand the whole code yet, so I used this at the moment.
#9 haxburgen
haxburgen
  • 21 posts
Posted 21 July 2012 - 03:41 PM
What is the pin configuration? I assume the D5 pin is the pin to the ESC. But where do D0 and D1 get connected to?
