analog input
Started by mtripolt, Aug 19 2011 09:16 PM
5 replies to this topic
Posted 19 August 2011 - 09:16 PM
hi folks,
i´m a beginner with programming and wan´t to know how i can read or convert input signals??
i conected a poti with the analog input, i will that the led from D0 by low voltage pegel shine and the led from D1 by high voltage pegel or so.
Please cam someone post some ideas for a code for c#.
Thanks a lot
Markus
Posted 19 August 2011 - 11:56 PM
hi folks,
Thanks a lot
Markus
This might help: http://wiki.netduino...ntiometers.ashx
Posted 22 August 2011 - 08:52 PM
Posted 25 August 2011 - 11:34 PM
Trying to use Arduino Sensor Shield (V5) with voltage sensor and 3 wire sensor connector cable (all from Emartee). Get solid 0 reading when using buckled A0 port. Read something about jumpering 3V3 to AREF but thought Version B of Netduino Plus avoided the need for that... any help greatly appreciated. Have sent post to vendor but thought I'd try here as well (English will probably be better ;-)
Posted 27 August 2011 - 07:36 AM
hi guys,
i have another question,..
i want to connect a bistable relay to the netduino,
when you switch the relay (+/-) it stays in the position, but you need (-/+) to switch back.
is it possible to connect for example: pin D08/ Ground at one sight of the inductor and Ground/ D09 at the other sight without smashing the netduino???
relais.tiff 36.76KB
12 downloads
hope you can see the attachment,
thank you
greeting markus
thank you
greeting markus
Posted 28 August 2011 - 06:16 AM
No, you should never connect any inductive load directly to any logic output, unless you'll take some precaution.
Here is a basic sample circuit to drive an inductive load, such as a relay coil, a DC motor, or something like that.
http://ecelab.com/lo...e-relay-led.htm
Refer to the first schematic.
Please, notice that the schematic includes a NOT-gate, such as 74HC04. This gate might not be included, but there is an issue related to the Netduino start-up. When the Netduino is powered, it begins its reset process, that takes about 1-2 seconds. During that delay all the outputs are disabled, and they are configured as pullup-inputs, instead.
Without any smart trick, the pullup resistors may polarize the transitor, thus activate the relay coil. By adding a NOT-gate, the default/startup state will have no effect, and the coil must be activated only by setting LOW the Netduino output. This condition cannot be achieved without an explicit code, and the relay activation will work perfectly.
