Serial port data transfer code and connection help !!!
Started by Beowolf, Aug 18 2011 01:54 PM
Posted 18 August 2011 - 01:54 PM
I am want to transfer the string (say "hello world") to my pc using the serial port (Com1). But i don't have any idea how to make the connection. I have a female socket in my PC for this COM1 port through which i want to send this string. I also need your help to code this solution. if you can give me the c# code and the hardware connection details i'll be great full to you.
Regards
Posted 18 August 2011 - 02:02 PM
With a netduino classic or plus you need a TTL to RS232 converter. I used two successfully:
http://wiki.netduino...hifter-SMD.ashx
http://wiki.netduino...-to-Serial.ashx
perhaps this thread could help you with code:
http://forums.netdui...rt-code-review/
Posted 18 August 2011 - 06:22 PM
You can also wire up a USB->Serial adapter directly to the serial pins on the Netduino. But be very careful. Some USB->Serial adapters output 12v and that will cook your Netduino (unless you use a level shifter). The USB->Serial adapter I have happens to put out TTL levels.
-dan
Posted 02 September 2011 - 09:34 AM
As per your suggestions i did the following:
I connected the digital I/O pins 0 and 1 to the MAX232 ic's to convert the rs323 signal to ttl standard for the incoming receive signal and ttl signal to rs232 standard for the netduino's outgoing transmit signal. then i connected the GND from the netduino to the GND of the rs232 cable(with female connector) and the respective receive and transmit signal pins of the cable to the max 232's respective pins.
Then i connected the other end of the cable to my pc with the following code:
Netduino Code:
PC code:
But inspite of trying the above, data is not transmitting from the netduino to the PC
Netduino Code:
using System; using System.Text; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.Netduino; using System.IO.Ports; namespace RFCOM { public class Program { public static void Main() { SerialPort port = new SerialPort("COM1", 9600, Parity.None, 8, StopBits.One); port.Open(); OutputPort o1 = new OutputPort(Pins.ONBOARD_LED, false); string message = "Hello World"; byte[] bytes = Encoding.UTF8.GetBytes(message); while (true) { o1.Write(true); port.Write(bytes, 0, bytes.Length); System.Threading.Thread.Sleep(1000); o1.Write(false); System.Threading.Thread.Sleep(1000); } } } }
PC code:
using System; using System.Linq; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Text; using System.Windows.Forms; using System.IO.Ports; namespace SmartDeviceProject1 { public partial class Form1 : Form { public Form1() { InitializeComponent(); } private SerialPort port = new SerialPort("COM1",9600, Parity.None, 8, StopBits.One); private void button1_Click(object sender, EventArgs e) { textBox1.Text="Incoming Data:"; // Begin communications port.Open(); textBox1.Text = "Port Opened"; // Attach a method to be called when there // is data waiting in the port's buffer port.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived); textBox1.Text = "Data recieve function called"; // Enter an application loop to keep this thread alive } private void port_DataReceived(object sender, SerialDataReceivedEventArgs e) { // Show all the incoming data in the port's buffer Console.WriteLine(port.ReadExisting()); textBox1.Text = port.ReadExisting().ToString(); } } }
Edited by Stefan, 02 September 2011 - 10:10 AM.
Added [code]-tags
Posted 02 September 2011 - 01:34 PM
Wow...there are many points where to investigate!
The code seems OK.
Here is a checklist:
For the opposite direction check these additional points:
Also, take care about the RS232 connector (DB9 or DB25) pinout: I always find confusing, and it is very easy to mistake the correct pins.
The code seems OK.
- here are the MAX232 specs, and the circuit is depicted in figure 5;
- if you own a multimeter, check the voltages as indicates in the Max232 schematic;
- the TX data output of the Netduino is on I/O #3, it must be connected to the pin 10 (or 11) of the Max232;
- the related TXD (RS232 side) is on pin 7 (or 14) of the MAX232, and must be connected to the RXD of the PC RS232 connector.
- the RX data input of the Netduino is on I/O #2, it must be connected to the pin 12 (or 9) of the MAX232;
- the related RXD (RS232 side) is pin 13 (or 8) of the MAX232, and must be connected to the TXD of the PC RS232 connector.
