Socket errors after time
Posted 10 August 2011 - 06:17 AM
Posted 11 August 2011 - 05:36 AM
Once either are done the socket.Connect() method blocks. I see the issue posted is listed as Closed and included in Beta2, so we should have the corrected code now?
Posted 13 August 2011 - 06:58 AM
Replace the normal socket.Connect(endPoint) with:
bool connected = false; new Thread(delegate { ConnectSocket(socket, endPoint, ref connected); }).Start(); DateTime timeoutAt = DateTime.Now.AddSeconds(10); while (connected == false) { Thread.Sleep(10); if (connected == false && DateTime.Now > timeoutAt) { return null; } }
ConnectSocket:
private static void ConnectSocket(Socket s, EndPoint ep, ref bool connected) { try { s.Connect(ep); connected = true; return; } catch { } connected = false; }
Posted 24 August 2011 - 07:53 PM
When I load my web browser to call up the Netduino served pages, all ok; If I hold down the F5 key (for about 30secs), to refresh the page continually, I get the error: Failed allocation for 39 blocks, 468 bytes
Do I perhaps need to marshall the sockets? Only allow x to be active at a time?
Rebooting...
TinyCLR (Build 4.2.0.0)
Starting...
Found debugger!
Create TS.
Loading start at 14dd04, end 165970
Attaching file.
Assembly: mscorlib (4.2.0.0) (4144 RAM - 39988 ROM - 21098 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Native (4.2.0.0) (1124 RAM - 6672 ROM - 4328 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware (4.2.0.0) (1880 RAM - 12636 ROM - 7940 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) (704 RAM - 5060 ROM - 2452 METADATA)
Attaching file.
Assembly: System (4.2.0.0) (900 RAM - 6324 ROM - 3291 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) (740 RAM - 4620 ROM - 2522 METADATA)
Attaching file.
Assembly: System.IO (4.2.0.0) (1548 RAM - 13296 ROM - 5862 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) (512 RAM - 3488 ROM - 1543 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0) (580 RAM - 3740 ROM - 1844 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Hardware (4.2.0.0) (260 RAM - 1120 ROM - 501 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0) (180 RAM - 440 ROM - 166 METADATA)
Attaching deployed file.
Assembly: GSIOTServerTest (1.0.0.0) (564 RAM - 2800 ROM - 1308 METADATA)
Assembly: Gsiot.Server (1.0.0.0) (1344 RAM - 16192 ROM - 5098 METADATA)
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.2.0.0) (268 RAM - 816 ROM - 423 METADATA)
Resolving.
Total: (12820 RAM - 117192 ROM - 58376 METADATA)
Ready.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Diagnostics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:\System Data\My Documents\Dropbox\HomeBug\development\GSIOTServerTest\Gsiot.Server\bin\Debug\le\Gsiot.Server.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:\System Data\My Documents\Dropbox\HomeBug\development\GSIOTServerTest\GSIOTServerTest\bin\Debug\le\GSIOTServerTest.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.2\le\SecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded.
DHCP enabled: False
Device address: 192.168.1.109
Gateway address: 192.168.1.50
Primary DNS address: 192.168.1.50
Base Uri: http://192.168.1.109/
connect...
The thread '<No Name>' (0x6) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x7) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x8) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x9) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xa) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xb) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xc) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xd) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xe) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0xf) has exited with code 0 (0x0).
connect...
memory available: 33516
The thread '<No Name>' (0x10) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x11) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x12) has exited with code 0 (0x0).
GET /time -> 200
connect...
memory available: 33000
The thread '<No Name>' (0x13) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x14) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x15) has exited with code 0 (0x0).
GET /favicon.ico -> 404
connect...
The thread '<No Name>' (0x16) has exited with code 0 (0x0).
connect...
memory available: 33204
The thread '<No Name>' (0x17) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x18) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x19) has exited with code 0 (0x0).
connect...
GET /time -> 200
The thread '<No Name>' (0x1a) has exited with code 0 (0x0).
memory available: 33324
connect...
The thread '<No Name>' (0x1b) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x1c) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x1d) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x1e) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x1f) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x20) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x21) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x22) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x23) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x24) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x25) has exited with code 0 (0x0).
memory available: 33348
connect...
The thread '<No Name>' (0x26) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x27) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x28) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x29) has exited with code 0 (0x0).
memory available: 34392
connect...
The thread '<No Name>' (0x2a) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x2b) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x2c) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x2d) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x2e) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x2f) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x30) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x31) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x32) has exited with code 0 (0x0).
connect...
memory available: 33084
The thread '<No Name>' (0x33) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x34) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x35) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x36) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x37) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x38) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x39) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x3a) has exited with code 0 (0x0).
GET /time -> 200
connect...
The thread '<No Name>' (0x3b) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x3c) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x3d) has exited with code 0 (0x0).
connect...
GET /time -> 200
The thread '<No Name>' (0x3e) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x3f) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x40) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x41) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x42) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x43) has exited with code 0 (0x0).
connect...
The thread '<No Name>' (0x44) has exited with code 0 (0x0).
connect...
An unhandled exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll
Uncaught exception
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Failed allocation for 16 blocks, 192 bytes
Failed allocation for 13 blocks, 156 bytes
Failed allocation for 10 blocks, 120 bytes
Failed allocation for 8 blocks, 96 bytes
Posted 13 September 2011 - 07:38 PM
Posted 30 September 2011 - 08:48 PM
Posted 08 November 2011 - 11:44 PM
No one else have this network reliability issues?
Is it al least posible to reset the network interface by code?
Carlos.
I'm having the exact same issue. Very simple code, using almost no CPU, plenty of RAM free, but when plugged into my university's LAN the board locks up after a few minutes. (Lasts for days on a simple home LAN with little traffic.)
Also, as someone else posted, rebooting internal routers also cause the same freeze.
