Driving a Motor That Needs 95mA
9 replies to this topic
#1 Vontux
Vontux
  • 5 posts
Posted 08 August 2011 - 09:23 PM
Hello I have a 3VDC vibration motor that requires 95mA. I am a programmer, but I am new to working with the netduino and connecting electronic components using anything other than USB, RS232 or RJ-45. Any insight that could be provided I would greatly appreciate.
#2 Chris Seto
Chris Seto
  • 405 posts
Posted 08 August 2011 - 11:40 PM
You'll want to use something like an NPN transistor or H bridge. You will also need a diode and a current limiting resistor to hook up in between the Netduino and the base of the transistor.
#3 Dan Morphis
Dan Morphis
  • 188 posts
Posted 09 August 2011 - 05:52 PM
Use the Arduino relay schematic replacing the relay in the circuit with your motor. As Chris Seto mentioned, you need a diode and resistor, both of which are in the schematic. If you neglect to put them in the circuit, there is a very very good chance you will burn up the IO port on the Netduino board.
-dan
#4 Vontux
Vontux
  • 5 posts
Posted 11 August 2011 - 02:54 AM
Use the [url="http://www.arduino.c...ys.pdf"]Arduino relay schematic{/url] replacing the relay in the circuit with your motor. As Chris Seto mentioned, you need a diode and resistor, both of which are in the schematic. If you neglect to put them in the circuit, there is a very very good chance you will burn up the IO port on the Netduino board.
-dan
Thanks greatly for that, I certainly don't want to burn up my netduino on my first project that does more than blink an led in morse code :)
#5 Vontux
Vontux
  • 5 posts
Posted 11 August 2011 - 02:59 AM
Using something like these should work shouldn't it?
http://www.robotsimp...ller_and_Driver
#6 Mustang
Mustang
  • 26 posts
  • LocationDetroit, Michigan
Posted 14 August 2011 - 03:00 PM
I drive two NXT motors with this; http://www.sparkfun.com/products/9457 Works perfectly. Very easy to use as well.
#7 Vontux
Vontux
  • 5 posts
Posted 16 August 2011 - 05:17 AM
This driver looks good. Would you mind providing some info on / pictures of your wiring?
#8 Mustang
Mustang
  • 26 posts
Posted 16 August 2011 - 06:13 AM
I just used Solid core cut to length (8"), stripped 1/8" from one end, pushed it through and soldered. Was really easy. I'll get some pictures, but be warned, It's not industry-level soldering.
#9 Vontux
Vontux
  • 5 posts
Posted 17 August 2011 - 12:41 AM
Thanks, I would greatly appreciate that. I'm sure your soldering couldn't be any worse than mine is.
#10 Mustang
Mustang
  • 26 posts
Posted 17 August 2011 - 02:20 AM
I warned ya. Here ya go. I am only using one channel right now because It's just in testing. I'll solder up the other channel once I need it. The supply is a standard 9v battery.
Posted Image
Posted Image
