Behavior is different when network cabe is in
Posted 03 August 2011 - 09:12 AM
Posted 03 August 2011 - 11:40 AM
I wrote some netduino plus "driver" for ultrasonic rangefinder. It is rather simple, it uses interruptions, from the 0->1 timestamp to the 1->0 timestamp. It works only when network cable is not plugged in. When the cable is in, the output is allmost allways wrong - it tells that there is something in 150 cm ( instead of 400 cm which is mesure when cable is not plugged in ).
Are there some changes in timings/ frequency / latency when the cable is in?
Is there some kind of workaronds, as I bought the plus version so I could send measured data over LAN...
I recall a post in this forum that the analog inputs behave oddly when the network cable is plugged in ... do you have the input on an analog input port of the netduino plus?
Cheers,
Stefan
Posted 03 August 2011 - 01:06 PM
Cheers,
Stefan
No, all four rangefinders are connected to the D0 - D7 ports... So maybe "Interrupts on digital inputs behave oddly when network cable plugged in"
Posted 03 August 2011 - 02:43 PM
What firmware version are you using? If it's an older version, you might have the problem mentioned here.
If that is the problem, the workaround is to avoid using the D2 input. Or just upgrade the firmware.
-Valkyrie-MT
Posted 03 August 2011 - 02:44 PM
Posted 03 August 2011 - 03:11 PM
-Valkyrie-MT
Ive tried it in the default 4. something firmware, and later in 4.2. Still the same.
